01-31-2024 09:29 AM - edited 01-31-2024 09:31 AM
I have a XPS 2200 on hand and I was wondering if power supply PWR-C1-715WAC-P is compatible with the XPS 2200 as we dont have the correct part number/power supply referenced in the doc for the XPS. The PWR-C1-715WAC-P is for a C9300.
XPS Correct Power Supply / Part Number
IE : C3KX-PWR-1100WAC= , C3KX-PWR-715WAC= , C3KX-PWR-350WAC=
01-31-2024 11:16 AM
check the below guide :
01-31-2024 03:10 PM
this is what I found:
C3KX-PWR-715WAC: It is designed to be used with the Cisco Catalyst 3K-X series switches and is not compatible with Catalyst 9300 switches.
PWR-C1-715WAC-P: It is designed for the Cisco Catalyst 9300 Series switches and is not compatible with Catalyst 3K-X series switches.
02-01-2024 11:51 PM
Throw it out.
As far as possible.
XPS does not work in real world scenario.
02-01-2024 11:56 PM
Hello!
Short answer - NO. The power supply in question would be compatibile with the C3750X series switches and not with the newer catalyst 9000 series.
BR
