configure the port for sniffer pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-14-2003 06:54 PM - edited 03-02-2019 11:01 AM
Is that normal that the F0/10 interface change to up/down after I config the f0/10 as monitor destination port?
monitor session 1 source interface Fa0/2
monitor session 1 destination interface fastEthernet 0/10
switch#sh int f0/10
FastEthernet0/9 is up, line protocol is down
- Labels:
Other Networking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2003 06:42 AM
No this shouldnt be the case, but from your info above you have issued the command
sh int fa0/10 and shown us and fa0/9 is up/down?
you're not running spanning tree on these ports are you? it should be up up even when you have a sniffer attached.
email me if you have any more problems and/or repost new info on here..
Kindest Regards...
Kai Nicholls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2003 02:36 PM
Hi, Kai
Sorry, I means interface F0/10 is up/down, not the interface F0/9. My typo.
If I removed the monitor destination interface F0/10 command, then the F0/10 become up/up.
Interface F0/2 and Interface F0/10 are using default spanning-tree setting.
So you think the interface f0/10 should always up/up. Is that right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2003 03:19 PM
Yes. It is Normal.
When you configure a SPAN session, the line protocol on the destination port is shown as down.
If you have a newer IOS version, you can actually see that it is in monitoring state as below
morpheus#show int fa0/16
FastEthernet0/16 is up, line protocol is down (monitoring)
You should be able to verify the SPAN operation, if you are seeing traffic on Sniffer that means that it is working fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2003 04:54 PM
Thanks!
So the sniffer pro is working on Layer 2 and Layer 1. Is that right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-16-2003 08:55 AM
Considering the fact that the Sniffer doesn't have an IP Address , you can say its working at Layer1 and Layer 2.
But it should be showing packet information upto Layer 7. If you are not seeing that info, maybe your SPAN is not setup correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-16-2003 07:11 PM
Now, It is getting intresting.
I have annother switch with port monitor on. But the interface is showing up/up.
S1#sh run int f0/22
Building configuration...
Current configuration:
interface FastEthernet0/22
no logging event link-status
duplex full
speed 100
port monitor FastEthernet0/1
no snmp trap link-status
end
S1#sh run int f0/1
interface FastEthernet0/1
description Link to B1
duplex full
speed 100
end
S1#sh int f0/22
FastEthernet0/22 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.b98a.8e96 (bia 0002.b98a.8e96)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 11/255, rxload 1/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 11w6d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute output rate 4638000 bits/sec, 1335 packets/sec
420621 packets input, 304841791 bytes
Received 48891 broadcasts, 4 runts, 0 giants, 0 throttles
6446 input errors, 6442 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast
4064102928 packets output, 1822920745 bytes, 0 underruns
0 lost carrier, 0 no carrier
S1#sh ver
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)XU, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 03-Apr-00 16:37 by swati
Image text-base: 0x00003000, data-base: 0x00301398
ROM: Bootstrap program is C2900XL boot loader
S1 uptime is 3 years, 5 weeks, 3 days, 23 hours, 28 minutes
System restarted at 15:21:04 NZT Fri Sep 8 2000
System image file is "flash:c2900XL-c3h2s-mz-120.5-XU.bin"
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
Processor board ID 0x0E, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:02:B9:8A:8E:80
Configuration register is 0xF
The switch show up/down is cisco 2950. Why?
S2#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(12c)EA1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 24-Nov-02 23:31 by antonino
Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is CALHOUN boot loader
S2 uptime is 23 weeks, 4 days, 23 hours, 33 minutes
System restarted at 15:27:26 NZST Sun May 4 2003
System image file is "flash:/c2950-i6q4l2-mz.121-12c.EA1.bin"
cisco WS-C2950T-24 (RC32300) processor (revision H0) with 21002K bytes of memory
Processor board ID FOC0710W1RX
Last reset from system-reset
Running Enhanced Image
2 Gigabit Ethernet/IEEE 802.3 interface(s)
Base ethernet MAC Address: 00:0C:85:12:61:40
Motherboard assembly number: 73-6114-08
Power supply part number: 34-0965-01
Motherboard serial number: FOC07100MN9
Power supply serial number: DAB070821XG
Model revision number: H0
Motherboard revision number: A0
Model number: WS-C2950T-24
System serial number: FOC0710W1RX
S2#
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-17-2003 08:15 AM
The behaviour has changed in the newer switches.
E.g. in 3500XL switches, where you had to use "port monitor" commands to configure a SPAN port, it will show the line protocol as UP.
With newer switches e.g. 3550 series, where a SPAN session is configured using "monitor session.." command the line protocol will be shown as down (but it will also tell you that its monitoring).
This doesn't effect the functionality, only gives you more info.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-18-2003 09:41 PM
Thanks, That is what I want to know.
So for the new 3550 switch, if I want remotely control the sniffer PC. Then I have to added the second network card.
