CW2K Device Attribute Errors
sutternsg
I have several Cisco routers and switches that I have verified the read/write community strings on the devices and in CW2K but I continue to receive "INCORRECT" in the Device Attribute Errors Report. Any known fixes ???
rmushtaq
Level 8
Level 8
RMe 3.3 or 3.4?. There are some known issues related to this if you do a CCO Bug Toolkit search.
I also had this problem and installed RME 3.4 at Cisco's suggestion. I still have this problem. The TAC said it was a cosmetic problem and not to worry about it.
