Does a 9404 catalyst chassis NEED to be grounded ?
I have installed a 9404 switch and cant see in the documentation that earthing the switch is a MUST. We need to know if grounding the switch is absolutely required as we are migrating our distribution to this switch this week.
Please advise as soon as you can.
Best Regards,
Sabeel
5 Replies 5
Its not must. device will work even without that. but it is extremely recommended to do so. that will protect internal components of switch.
check this for guide
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/hardware/install/b_c9400_hig.pdf
Good luck
KB
Joseph W. Doherty
Well, if you don't, when you touch the device, it's then more likely for you to become the conduit to ground.  So, that's one reason, as @Kasun Bandara notes, it's extremely recommended (even though it's unlikely).
balaji.bandi
yes always suggested to do - if not you see different outcome and also failures of modules and other components.
BB
Leo Laohoo
Those line cards are pretty expensive.
It is too bad if the chassis was not grounded and fries the line card due to static discharge.
Thank You all. I have managed to push our onsite electricians to get it done today. The reason i asked was to build a justification as to why I needed it done earlier that the date they have me.
