03-16-2004 01:36 AM - edited 03-02-2019 02:18 PM
I want to judge which type cisco device is . Whether it is IOS or CATOS ? Is it version early 12.0 or later ?
Which OID can I use ?
thanks very much!
03-16-2004 11:31 AM
Try using .1.3.6.1.2.1.1.1 (sysDescr)
03-16-2004 01:45 PM
sysDescr or system will give you the info you need.
03-16-2004 06:28 PM
thanks for your reply.And I have another question,How can I know which mib the cisco device support? Like this ,some IOS device support CISCO-CONFIG-COPY,and another support OLD-CISCO-SYSTEM-MIB. When I code snmp program to copy cisco running-config to my tftp server,how did I know which OID I can use ? If I can get the device support CISCO-CONFIG-COPY,I can use 1.3.6.1.4.1.9.9.96.1.1.1.1,else I can use 1.3.6.1.4.1.9.2.1.55. .
thanks !
03-16-2004 07:01 PM
For devices MIB support, use mib toolkit and MIB locator.
http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
For copying config to tftp server, see this.
http://cisco.com/en/US/customer/tech/tk648/tk362/technologies_tech_note09186a0080094aa6.shtml
You also wanna bookmark following url
http://cisco.com/en/US/customer/tech/tk648/tk362/tk605/tech_protocol_home.html
03-16-2004 10:14 PM
thanks for your reply!
Are there any automatic methods to know devices MIB support ?I mean I want to code program to get devices MIB support infomation. I can't use mib toolkit and MIB locator.
So How can ?
thanks!
03-17-2004 04:47 AM
check if you receive a not empty snmp reply
