Nexus 3548 subinterface statistics missing
raitech12
I am trying to get statistics for subinterfaces on a Cisco Nexus3500 C3548P-10GX switch.
The subinterface is configured for a port channel as shown below.
interface port-channel3.1802
  encapsulation dot1q 1802
  ip address 192.168.1.165/30
There is nothing shown as statistics for VLAN or subinterface.
NEXUS(config)# sh interface port-channel3.1802
port-channel3.1802 is up
admin state is up,, [parent interface is port-channel3]
  Hardware: Port-Channel, address: xxxx.xxxx.7641 (bia xxxx.xxxx.7608)
  Description: vlan for internet
  Internet Address is 192.168.1.165/30
  MTU 1500 bytes, BW XXXX000 Kbit, DLY 10 usec
  Encapsulation 802.1Q Virtual LAN, Vlan ID 1802, medium is broadcast
  Auto-mdix is turned off
  Switchport monitor is off
  EtherType is 0x8100
NEXUS(config)# sh interface vlan 1802
Vlan1802 is up, line protocol is up, autostate enabled
  Hardware is EtherSVI, address is XXX.XXX.XXX
  Description: MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  ARP type: ARPA
  L3 in Switched:
    ucast: 14385814 pkts, 1951146757 bytes
For other interfaces, I have these statistics:
 RX
    285716197370 unicast packets  1725784 multicast packets  1273 broadcast packets
    285717924427 input packets  279284980293540 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    10240494209194 unicast packets  0 multicast packets  0 broadcast packets
    10240494209298 output packets  14411966319769316 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  12372589734 output discard
    0 Tx pause
show version:
Software
  BIOS: version 5.3.1
  NXOS: version 7.0(3)I7(7)
  BIOS compile time:  06/04/2019
  NXOS image file is: bootflash:///nxos.7.0.3.I7.7.bin
  NXOS compile time:  8/28/2019 16:00:00 [08/29/2019 00:41:42]
Is there any way to enable statistics for subinterfaces?
raitech12
I have recently upgraded it to NXOS 9.3(8) but still no luck.
Software
  BIOS: version 5.4.1
 NXOS: version 9.3(8)
  BIOS compile time:  03/30/2020
  NXOS image file is: bootflash:///nxos.9.3.8.bin
  NXOS compile time:  8/4/2021 13:00:00 [08/04/2021 22:25:26]
Looks for me bug,
BB
