Serial lines has alot of Input about errors
danny_ng
I have faced alot of input error with abort #. I did change the cable but the error still occurs. Can the Cisco 2611 router configure the "invert txclock" to compensates for phase shifts between the data and clock signals without relying to the DSU. Because the carrier provider has claimed that the lease circuit is good after test with the bert tester. The lease line speed is 128Kbps. Please advise any solution can resolve this and thanks alot in advance.
6 Replies 6
pmichel
Aborts mean illegal sequence of one bits- typically
a bad ckt, CSU/DSU, or sending interface on remote router.
I would do loopback testing w/ HDLC encapsulation
to try to isolate where the failure is.
1- clear int serial x
2- put local loop on csu/csu back to router(DTE loop)
3- int serial x should say up/up (looped)
4- verifyy there are no input errors. if you can , out a loop at the other end of the DSU/CSU(closest to
D-marc & also put loop back towards router).
5- take loop off, and have telco put a loop back to
router at the DACS or another point in the ckt.
6- use extended ping command with data pattern of
0x0000 repeat count of 100- this will determine if
line coding is provisioned correctly.
7- do the same, with data patterns of 0xffff, again look for input errors.
8- if clean, have telco put a loop farther away, and
repeat same steps.
9- you can also do this from remote router, if you
manage it.
somewhere along these loopback tests, you'll see
input errors, and you should be to isolate where the
failure is at.
You shouldn't have to invert the clocking.
regards, Philippe
Hi, Thanks alot for your input. I'm not too sure about item 5 as you mentioned earlier. Can you plase elaborate more. Is it after the local loop and there is no input errors, i'll need to proceed to take off the loop and perform the remote loop ? can I use step 6 & 7 in local loop ? please advise. Thanks alot.
Welcome.
On each of these loopback tests, continue to do loops farther away from the router
, as long as you see no input errors. If you see any input errors(clear int s x before doing
ping tests), then stop there-this is where you are having a failure.
Step 5- on some dsu/csu, you can do a loop at the DTE port(closest to router)-also try
to put a loop at the other end of the dsu/csu(closest to ckt)-this will test the entire dsu/csu unit.
step 6&7- don't believe you have to do the extended pings with data patterns-those are more
useful to test the integrity of the ckt. You should be able to just send a ping on an ip address
that is on the same subnet as the serial ip-send 50-100 pings- the return of the ping will let
you know if there are any problems, in the form of input errors.
Hope that helps-Philippe
Thanks for your reply. I manage to solve the problem finally and the problem was actually related to the clocking (not stable-the wave form sometime show spite) from the telco site. Still wonder why the problem was solved after changing the interfaces from Aync/Sync module (NM-8AS) to Sync module (WIC-2T). Is it any different ? I've tried to change form different Async/sync to another Async/sync module but the problem still exist.
Are you sure that your modems are setup for 128K ??
If faster than you're making a mistake. The 8A/S module will go up to 128k Sunc without errors, and the Wic-1T is up to 2M. So if your modems are setup for lats say 512K and you are trying this on 8A/S module it just wont work. Hope this helps
Velimir
The modem is supplier by our carrier provider (telco). It is suppose configured to 128Kbps by telco site and it should be correct because we only paid for 128Kbps. Anyway, thank for your info and hope you have additional ideas on it.
