x25 idle issue
etamara
I configured the "x25 idle 42" command on a serial interface so that X25 SVC time out after 42 minutes of inactivity.
However, I´ve found that this does not seem to work fine:
interface Serial1/2
description Enlace-ip-x25switch2
bandwidth 2048
ip address 130.207.10.13 255.255.255.252
no ip directed-broadcast
encapsulation x25
no ip mroute-cache
x25 address 1111
x25 htc 1650
x25 accept-reverse
x25 idle 42
x25 map ip 130.207.10.14 2222 broadcast
SVC 1, State: D1, Interface: Serial1/2
Started 7w3d, last input 00:43:41, output never
Connects 2222 <-> ip 130.207.10.14
Call PID ietf, Data PID none
Window size input: 2, output: 2
Packet size input: 128, output: 128
PS: 0 PR: 4 ACK: 4 Remote PR: 0 RCNT: 0 RNR: no
P/D state timeouts: 0 timer (secs): 0
data bytes 0/23509699 packets 0/303996 Resets 0/0 RNRs 0/0 REJs 0/0 INTs 0/0
As you can see, this SVC is in the idle state for longer than the configured threshold.
Any idea or suggestion?
IOS version is 12.0(14)
raymong
Level 4
Level 4
It is the responsibility of either the originator or receipient of a X.25 call to disconnect the call. If the router is acting as a switch and is neither the source of the call or the destination, the x25 idle command will not disconnect the call.
If the X.25 is being sourced from the router, then the "x25 idle" command should automatically request disconnection after a period of idle traffic.
Well, actually we have a router which receives X25 WAN connections through several serial interfaces towards a couple of servers with 2 X.25 cards ( directly connected to the router ). Some connections are pure X.25 and others are XOT. Should the "x25 iddle" command enforce VC deletion in this scenario?
Enrique
