Bookmark
Subscribe
1848
new vlan creating problem in FWSM Context
goutam_04
We need to add a new IP range in the Network.  In my network there are lot of Context in FWSM.  Now to add a new network, I have created a new vlan and allowed to FWSM and same created in Context.  but the vlan is not getting up in FWSM and Context.
Please help me out on this.
6 Replies 6
Jennifer Halim
First, vlan needs to be active on the switch (sh vlan - will show you if the vlan has been configured).
Secondly, you would need to assign the vlan to the firewall (sh run | i firewall - will show you if the vlan has been assigned to the firewall).
Thirdly, you should see that vlan in the system context, and you would need to assign them into the context (show run context - will show you if the vlan has been allocated to the context yet).
Hope that helps.
All these process has been done and fine.  in the context the new vlan is showing down.  its not getting up.
What to do to make this vlan up.
find the output in RED.
FWSM-1/CDR# show int ip brief
Interface                  IP-Address      OK? Method Status                Prot
Vlan101                    172.19.60.4     YES CONFIG up                    up
Vlan112                    10.128.112.254  YES CONFIG up                    up
Vlan301                    172.16.11.254   YES CONFIG up                    up
Vlan302                    172.16.12.254   YES CONFIG up                    up
Vlan303                    172.16.13.254   YES manual down                  down
Please go back to system context, and "no shut" the interface.
System context:
interface vlan 303
     no shut
You need to have a least one host in that vlan for it to come up.
I hope it helps.
PK
What does it mean that one host need to have in that vlan.  I did not get you.  I am creating a vlan in FWSM context,  can you give me the configuration pls. how do I allowed a host to that vlan in context.
in case of switch, if create a vlan and that vlan is not allowed in any access port or trunk port then the vlan must be in down mode.  But in case of FWSM how do i do that.
Please it will be big help for me.  if you can give me the configuration.
Config on the switch
vlan 10
firewall vlan-group 1 10
firewall module 1 vlan-group 1
So FWSM in slot 1 will now see vlan 10. But if there is no switchport in vlan 10, the interface will be down in the FWSM also.
PK
