PIX506E Need Help in Setting up PDM
r.docuyanan
I got an instruction from the cisco website on how to install PDM. I got the following error
pixfirewall# copy tftp://192.168.1.254/pdm-301.bin flash:
copying tftp://192.168.1.254/pdm-301.bin to flash:image
Received 3126944 bytes
No PIX image found in downloaded file
Image not installed
pixfirewall#
Can anyone help me on this?
pixfirewall# sh flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1925176
file 1: origin: 1966080 length:3005
file 2: origin: 0 length:0
file 3: origin: 2097152 length:3126944
file 4: origin: 0 length:0
file 5: origin: 8257536 length:308
pixfirewall#
pixfirewall# sh ver
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 19-Mar-03 11:49 by morlee
pixfirewall up 36 days 2 hours
Hardware: PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz
Flash E28F640J3 @ 0x300, 8MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is XXX irq 10
1: ethernet1: address is XXX, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: XXX
Running Activation Key: XXXX
Configuration last modified by enable_15 at 15:17:20.642 UTC Thu May 13 2004
pixfirewall#
For running PDM from your desktop, two commands are required.
http server enable
http 192.168.1.X 255.255.255.255 inside
PDM is a bookkeeping command, not used to mention the PC who can run PDM.
One more point, it has to the https://192.168.1.1
Give the above mentioned commands and it will work fine.
prasadrp
You need to use the following command
copy tftp://192.168.1.254/pdm-301.bin flash:pdm
flash:pdm parameter should be mentioned otherwise it will be taken as FW image
Regarding my previous upload to the pIX, did it fill the flash memory? Im afraid the flash memory might get full. And also, the show flash command is a bit difficult to understand unlike the show flash command in routers.
I was able to download the file,
saying PDM file installed.
Follow up,
how come I cannot access the pdm?
http://192.168.1.1 the address of pix
even though i put in
pix(config)# pdm location 192.168.1.X 255.255.255.255 inside <--ip of my desktop
Any more commands that I lack? JVM already installed in my pC
RJ
http server enable
Thanks alot, It solved my problem. Btw, do you know
some Useful cisco links where I can study about useful administration commands for the PIX? CLI commands?
Rj
