Bonjour/Apple Printing on Aironet 1240AG without Controller
MARTIN FUNKE
For a customer we need to configure a couple of Aironet 1240AG Access Points  for Bonjour/Apple Printing. I have seen some documents on cisco.com how to configure this (enabling multicast) on a controller. Unfortunately the customer does not own a controller at all.
Question: Is it possible to configure the needed items using the WebGUI of the APs without using a controller?
Best regards,
Martin Funke
K&K Networks
5 Replies 5
Scott Fella
For those AP's, running v12.4 and having multicast enabled on the network side is all you need. The devices have to be on the same subnet or else you will have to deploy a bonjour gateway like Avahi.
Here is a doc that show the setup for the Avahi.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_tech_note09186a0080bb1d7c.shtml#deploy
-Scott
Hi Scott,
does that mean that I have to configure some IGMP on the switches? In case that is the fact: No further configuration on the APs is neccessary?
Best regards,
Martin.
Not on the autonomous. There are a few post regarding this. I will have to try to find it.
-Scott
Scott Fella
See this post
https://supportforums.cisco.com/thread/2121969
-Scott
Hi Scott,
I have red the post you mentioned.
But as far as I understood, the whole scenario in the post is based on a setup with a WLC (correct me if I am wrong).
Our customer does not have any WLC (Controller).
Best regards,
Martin.
