03-04-2019 04:55 AM - edited 07-05-2021 09:58 AM
We have purchased new WLC 5520 and some access points we have configured Service Port, management port, and AP management port of WLC, but when we are trying to join APs to WLC we are receiving below errors.
[*03/04/2019 05:19:01.0166] CAPWAP State: DTLS Teardown
[*03/04/2019 05:19:01.0221] Dropping dtls packet since session is not established. Peer 10.10.23.1-5246, Local 10.10.12.108-5264, conn (nil)
[*03/04/2019 05:19:05.7685]
[*03/04/2019 05:19:05.7685] CAPWAP State: Discovery
[*03/04/2019 05:19:05.7697] Discovery Request sent to 10.10.23.1, discovery type STATIC_CONFIG(1)
[*03/04/2019 05:19:05.7738] Discovery Request sent to 10.10.23.1, discovery type STATIC_CONFIG(1)
[*03/04/2019 05:19:05.7756] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/04/2019 05:19:05.7756] Discovery Response from 10.10.23.1
[*03/04/2019 05:19:15.0002] Discovery Response from 10.10.23.1
[*03/04/2019 05:19:15.0000]
[*03/04/2019 05:19:15.0000] CAPWAP State: DTLS Setup
[*03/04/2019 05:19:15.0302] dtls_load_ca_certs: LSC Root Certificate not present
[*03/04/2019 05:19:15.0327]
[*03/04/2019 05:19:15.0327] CAPWAP State: Join
[*03/04/2019 05:19:15.0339] Sending Join request to 10.10.23.1 through port 5264
[*03/04/2019 05:20:12.0166]
[*03/04/2019 05:20:12.0166] CAPWAP State: DTLS Teardown
[*03/04/2019 05:20:12.0221] Dropping dtls packet since session is not established. Peer 10.10.23.1-5246, Local 10.10.12.108-5264, conn (nil)
[*03/04/2019 05:20:16.7685]
[*03/04/2019 05:20:16.7685] CAPWAP State: Discovery
[*03/04/2019 05:20:16.7698] Discovery Request sent to 10.10.23.1, discovery type STATIC_CONFIG(1)
[*03/04/2019 05:20:16.7734] Discovery Request sent to 10.10.23.1, discovery type STATIC_CONFIG(1)
[*03/04/2019 05:20:16.7772] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/04/2019 05:20:16.7773] Discovery Response from 10.10.23.1
[*03/04/2019 05:20:26.0011] Discovery Response from 10.10.23.1
[*03/04/2019 05:20:26.0000]
[*03/04/2019 05:20:26.0000] CAPWAP State: DTLS Setup
[*03/04/2019 05:20:26.0295] dtls_load_ca_certs: LSC Root Certificate not present
[*03/04/2019 05:20:26.0296]
[*03/04/2019 05:20:26.0329]
[*03/04/2019 05:20:26.0329] CAPWAP State: Join
[*03/04/2019 05:20:26.0340] Sending Join request to 10.10.23.1 through port 5264
[*03/04/2019 05:20:38.4351] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*03/04/2019 05:20:38.9820] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
Please advise Thank you,
03-04-2019 05:53 AM - edited 03-04-2019 05:54 AM
Hi have you configured the licenses and accepted the EULA? You can go to Management > Software Activation > Licenses and type in the amount of licenses purchased to activate them. You should be prompted to accept the EULA and I recommend restarting the WLC after this so they remain permanent. After that, see if your APs join.
If licenses are all good, confirm the WLC is configured for Europe (E) and not US. You can do this under Controller -> Country or "show country".
What version of software are you running?
Ric
03-07-2019 04:08 AM
Check:
1. Security > AAA > AP Policies .. here only "Accept Manufactired Installed Certificate "MIC cert check box must be ticked.
2. Date and Time must be correct
3. Must accept the EULA for license
if still failing then paste the output of these commands:
From WLC: sh sysinfo
From AP: Sh version
Also boot the AP and paste the complete bootup process here.
Dont forget to rate helpful posts
