06-22-2012 12:20 AM - edited 07-03-2021 10:20 PM
Hi!
I have a WLC 5508 and 25 LAP 1041. I use two wifi, one with RADIUS for data and other with wpa-psk for voip. The problem is the voip conectivity is broken.
How can i improve the handover?
The NEC recomendation does not help me anything.
thanks!
06-22-2012 02:15 AM
Thanks for your support,
tăng rank alexa , tăng thứ hạng website , tăng traffic , dịch vụ seo, tăng thứ hạng alexa, máy đo huyết áp, http://dungcuykhoakimminh.com/san-pham-42/MAY-DO-TIEU-DUONG-PRODIGY-PREFERED-USA_43.htm ">may do tieu duong, Thực phẩm chức năng, sữa ong chúa, nhau thai cừu, thuốc bổ tổng hợp, thuốc giảm cân, truyện online
06-22-2012 02:43 AM
not sure what type of voip handsets you are using???
In genreal you have to make sure that adjacent coverage areas should overlap by at least 20 % with good RSSI on your client .
Please let me know what handset you are using to give you some hints.
06-26-2012 09:05 AM
I think the problem is the coverage and overlap. But, the NEC device, or any Smartphone, is associated with a AP (for example, in front of office on the first floor), When I enter the building, the NEC can not associate with other APs, or is slow to associate, until he entered the office, on the first floor.
Two differents wifi affects on the performance of associate or handover?
