Unable to enter "Conf T" on Cisco Aironet 1310
shabali52
Hello Experts,
I have a question about Cisco Aironet 1310 AP, the problem I am getting is that I am unable to enter the conf t mode to configure the AP. I am not sure what could be the problem. I have IOS 12.3 running on it.
Please help
14 Replies 14
Stephen Rodriguez
When you connected did you have to login?
Did you type "enable" prior to trying to type conf t?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
shabali52
Hi Steve,
Thanks for your reply, I am consoled in and in enable mode, I had to put a password to get to enable mode.
harvisin
Level 3
Level 3
you need to first type command enable and then it will ask for ht epassword if the enable password is set, once you are into it you can type the command configure terminal. This is how it all works.
shabali52
Yes, I am in enable mode.
do a show ver.  make sure your software is k9w7(aIOS) and not k9w8(CUWN)
HTH,
Steve
HTH,
Steve
Hey Steve,
Its k9w8, this is what I see on sh ver
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:45 by alnguyen
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
AP1310-MASJID uptime is 1 week, 2 days, 9 hours, 38 minutes
System image file is "flash:/c1310-rcvk9w8-mx/c1310-rcvk9w8-mx"
cisco AIR-LAP1310G-A-K9    (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FTX1536U060
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
this means you are using a lightweighted AP and by default it does not support config mode.
Convert it to a k9w7 (aIOS) AP then you should be able to configure it.
Is there a way to configure it without converting the ISO? Like may be via web based interface?
there is no need to enter config t mode in lightweighted ap... all config is done on wlc...
debug capwap console cli
above cmd will open config t mode.
We dont have a WLC yet. Can it be used as an inpedenpent AP? If so, should it be converted to a regular IOS to do that?
shabali52
Ok let me check
Ravi Singh
Level 7
Level 7
I think you are using LWAP mode and In this mode config T does not supported. Please check the same.
shabali52
Could you please guide me to a document to convert it to an autonomous IOS
Check this link out
https://learningnetwork.cisco.com/thread/14405
