Cisco VSOM 6.3.1 Health Monitor not showing alarms
gregl_2
I have a new installation of Cisco VSM and VSOM 6.3.1  VSOM and VSM running on 1 server and a second server running just VSM.  The health monitor doesnt show any alarms even when i know i have some cameras and streams down.  Anyone else seen this and no the fix for it.
Problem Resolved.
jfiranzi
I think I know what's going on with your Health Monitoring Dashboard
issue.  Let me start by providing some background on how this system
works.
The Health Monitoring Dashboard is a GUI representation of SNMP traps
received by the VSOM server.  As such, it only changes device states if
it receives a SNMP trap for a degraded, failed or offline condition.
VSOM does not poll the devices, it only listens. The end devices
(cameras) do not send these SNMP traps, instead relying on the VSMS
server to communicate a change in status of the proxy for a camera.
It is likely the VSMS server could not resolve the hostname of the
VSOM server, so the VSOM server and Health Monitoring Dashboard did
not receive the trap.
The receipt of SNMP traps is further complicated by the fact that
registration of VSOM to the media servers is not by IP address, rather
hostname, and if the media server cannot resolve the host name, traps
are not received by the VSOM console.  This has the potential to leave
us in a position where the end user may not be aware of offline devices
as the default state is UP rather than UNKNOWN.
There is a defect written to address this scenario through a redesign
such that VSMS can use the IP address rather than hostname to send SNMP
traps ( CSCtj68042).  From each media server, ensure that the VSOM
hostname is resolvable to an IP address.   This can be done by updating
the DNS server (if your network is using one) or by editing the
"/etc/hosts" file on each of the media servers to including a hostname
to IP address mapping for the VSOM server.   Alternatively, the media
server's /usr/BWhttpd/conf/snmpd.conf can be manually updated to replace
the VSOM hostname with the IP address.
Here is an example of the hosts file on the media server:
  ese-mediasvr-cc1:/usr/BWhttpd/etc # cat /etc/hosts
    [snip]
  172.26.157.7    ese-mediasvr-cc1.cisco.com
  192.0.2.137     ese-mediasvr-cc1.cisco.com ese-mediasvr-cc1
Using Yast, manually enter the host for the VSOM server into /etc/hosts
on the media server
  ese-mediasvr-cc1:/usr/BWhttpd/etc # cat /etc/hosts | grep 192.0.2.138
  192.0.2.138     ese-vsom-vm-cc1.cisco.com
After adding the entry into /etc/hosts and restarting the server through
the management console, the alarms should once again be received by VSOM
and Health Monitor should report cameras which are offline.
So in summary, verify by pinging the hostname of the VSOM server from
each VSMS server in the network.  For any which are unresolved by
hostname, either change DNS entry to map hostname to IP, or using Yast
or vi, edit /etc/hosts to map IP to hostname for VSOM on each media
server, (or the media server's /usr/BWhttpd/conf/snmpd.conf can be
manually updated to replace the VSOM hostname with the IP address.)
I hope that helps,
Jim
12 Replies 12
I have seen this problem similar to the configuration you described. I have VSOM 6.3.1 running on a 1RU and VSM running on twelve 4RU servers and the alarms particularly end point errors doesn't show up either. Oddly enough I have a remote site with a 4RU running VSOM and VSM and the alarms show up in this configuration.
Jim,
Thank you very much for the very detailed response. I understood most of what you outlined but I got lost with the commands where you manually enter the hostname for the VSOM server into /etc/host on the media server. I am new to linux so I am mostly working mostly through YaST. As per your instructions I SSH into each media server and tried to ping the hostname of the VSOM and received no responses. I am going to give your recommendation a try so if possible can you please outline how to do it through the YaST GUI? I believe I am in the right spot when I checked in YaST (Network Services>Hostnames) but I am not sure.
Ainsley,  yes you are in the right spot.
Yast menu----  then in the Hostnames.   Click add---   enter name of server then ip address then the alias name  ie....  vsms1    10.1.2.3     vsms1
Click save or add i cant remember for sure and dont have one in front of me righ this second.
Try that and let me know
Greg,
Thank you for following up. I was added the VSOM information (IP/Hostname) to the VSMS and I was able to ping the VSOM from the media server however the endpoint errors from known offline cameras did not show up in VSOM. I also added the hostname of the VSMS to VSOM and still nothing. Any ideas what I am missing? I also looked for the snmpd.conf file and did not find it in the conf folder. I noticed that there is a SNMP trap configuration screen in the camera (CIVS-IPC-2531) menu, does this have to be configured first in order for it to work?
Thanks.
Ainsley,
Try this
-Check to make sure the "VSOM SERVER HOST" is configured under Trap 0 on your servers.  This is located at http:///vsmc  ---> under SNMP Trap Destinations.
-Make sure the /etc/hosts file on your servers contain an entry for the VSOM host.
SSH to your Vsom and VSMS
Stop and Start the SNMP service.
/usr/BWhttpd/bin/init_snmp stop
/usr/BWhttpd/bin/init_snmp start
Let me know after that
You are the man Greg. It worked!
Thank you so much!
No im not "the man"   Jim is the man  it took a TAC case with him yesterday for it to work for me.  I guess he posted to this after our TAC case.
Maybe this will help others out there.  so they can get it quickly resolved also like yourself
jfiranzi
works.
    [snip]
on the media server
I hope that helps,
Jim
Yes Jim was "the man" that gave me the fix for this.
Also i think the snmp stop restart also.
Thanks for the vote of confidence, Greg.  You are correct, I saw this thread shortly after assisting in your TAC case.  The purpose of the Cisco Support Community is to help foster community support to help spread knowledge and solutions to common issues.  Your reply in this thread is demonstration that this support community is working.
Thank you Sir!
Jim
And a very special thanks to you Jim for the top notch explanation and resolution.
mcwalter
Level 3
Level 3
Do you guys know if this issue was fixed in VSM6.3.2 or 6.3.3? Going throught the release notes now.
Thx
