Bookmark
Subscribe
1050
RV016 not working correctly.....
NickMay89
We've setup an RV016 to run with 2 internet lines and load balanced, the problem I seem to be facing is relating to browsers.
People are connected to things such as MSN but when trying to browse the net it just seems to be extremely slow or non-responsive.
This is definitely not an actual internet connection issue as if I change my personal machines details to by-pass the RV016 then everything works as it should.
Any advice?
riroe
Level 3
Level 3
Try disabling the following function under the Firewall and see if this corrects the speed.
SPI (Stateful Packet Inspection) :
Enable
Disable
THANKS
