1800 series router configuration
vikramjit060
I have cisco 1800 series router, with 2 isp connectivity (intenet Leased Line).
1 isp ----> 2mb serial link
2 isp-----> 8mb fiber (ethernet termination ) link.
I need to configure load balancing and automatic failover between these to links.
can someone help on this ?
Vikram
2 Accepted Solutions
vikramjit duhan wrote:
Hey Poala,
Those were correct ratings according to your reply anyways sorry.
Absolutely not, and you answer demonstrate your lack of understanding and poor attitude.
You wanted NAT load-balance and I sent you the correct link for that.
Then you wanted bandwidth-proportional load-balance, without knowing that router cannot do that, but you left poor rating anyway.
Also, please learn to spell people's names correctly when addressing them.
Okay, I think we should leave this thread as is. I don't think its fair that users have the ability to delete/erase other peoples posts over others, with all respect due (my posts in particular). I can understand if I had content in there that I shouldn't have had.
As far as I know ratings are for users (poster's who ask questions) to mark if information provided if it is helpful/useful to them and how much by with rating system, its not the repliers to determine if it was helpful or not.
Anyhow, I do believe Paolo's link would have been helpful.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
13 Replies 13
paolo bevilacqua
I have deleted my 100% correct answer due to the low rating unfairly received, and will refrain from participating again. Good. luck.
Hey Poala,
how comes my posts got deleted?
Hey bilal,
Poala Deleted all of your useful replies & I am stucked with configuration again.
Hey Poala,
those were not poor ratings i asked you for sorry as i dint knew this. you could have told me. rating is not evrything, I asked you for help as I am not an Expert & thought that you guys who are experts can help.
Hmm okay I agree Bilal,
And really sorry to both of you.
& thanks for helping.
Thank you for your cooperation and ratings.
hello Bilal,
route-map & ip sla monitor command is not working on my 1841 router. please help
You might have the wrong feature set on your router, if you are able to get hold of advanced enterprise IOS image then this should support all commands we need. Or even advanced ip services should have the feature set.
You need to have minimum 12.4(22)T IOS version.
REgards
Inayath
Okay searched for you.
For Route Maps and IP Sla use need to have Advanced Services license installed on your device.
Example:
Software 12.4(4)T2 + Advanced  services license. will do.
Inayath
*Plz rate all usefull posts.
