Add new VLAN
paul.tim681
Hi all
I need help to create one new vlan that should not be reachable with any other vlan. All traffic from this vlan should be routed to dsl-internet router
vlan subnet - 192.168.200.0 255.255.255.0
DSL Router IP : 192.168.200.253 255.255.255.0
users on this subnet wil only access internet
current configuration
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname HQSACOREGW
! service timestamps debug uptime
hostname BB0
interface Loopback0
ip address 172.20.20.1 255.255.255.255
interface Loopback1
ip address 172.20.20.2 255.255.255.255
interface Vlan2
description IT Users
ip address 172.20.25.254 255.255.255.0
ip helper-address 192.168.1.100
interface vlan3
description Server
ip address 192.168.1.254 255.255.255.0
interface vlan 4
description network devices
ip address 192.168.2.254 255.255.255.0
interface vlan 5
description vpn_router
ip address 172.20.26.1 255.255.255.248
interface vlan 6
description Connected to Building2
ip address 172.20.26.9 255.255.255.248
interface vlan 7
descripiton connected to IDN
ip address 172.20.26.17 255.255.255.248
interface vlan 8
description connected to Firewall
ip address 172.20.26.25 255.255.255.248
router ospf 5
redistribute connected subnets
redistribute static subnets
network 172.20.25.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 172.20.26.1 0.0.0.0 area 0
network 172.20.26.9 0.0.0.0 area 0
network 172.20.26.17 0.0.0.0 area 0
network 172.20.26.25 0.0.0.0 area 0
network 172.20.20.1 0.0.0.0 area 0
network 172.20.20.2 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 172.20.26.26
ip route 10.10.10.0 255.255.255.0 172.20.26.2
ip route 10.10.20.0 255.255.255.0 172.20.26.2
ip route 10.10.100.0 255.255.255.0 172.20.26.2
thank you all
Paul
5 Replies 5
John Blakley
Paul,
Is a standard acl acceptable to you? You could deny access from this subnet to any other private subnet and then allow them to go anywhere else. You'd apply it on the vlan interface:
vlan 500
ip address 192.168.50.1
ip access-group 101 in
access-list 101 deny ip any 10.0.0.0 0.255.255.255
access-list 101 deny ip any 172.16.0.0 0.15.255.255
access-list 101 deny ip any 192.168.0.0 0.0.0.255
access-list 101 permit ip any any
HTH,
John
HTH, John *** Please rate all useful posts ***
rizwanr74
Level 7
Level 7
Hi Paul,
Please read this thread, there is a working solution already found on this below thread.
https://supportforums.cisco.com/thread/2131688
Please rate helpful post
thanks
Hi all
rizwanr74 -> my requirement is different then the link
John  thanks mate for supporting the post, my default route is to send all traffic to firewall-box then how to send new vlan traffic to new DSL Router.  i also dont want new vlan to use our existing local dns server in vlan3 but use ISP DNS or DSL router ip as dns resolver.  If I add new vlan then i need to update the access-list 101, so standard or extended acl easy to change.
thank you all
Paul
does your IOS support VRFs?
If yes, I'd create a new VRF for the new subnet. You could use a separated routing table for it then.
HTH,
Milan
VRF not supported. New subnet hits the firewall-box but traffic is not routed to new-DSL-router.
