AIM-VPN/SSL-3 Module not detected
ronald.ramzy
I have Cisco 3845 Router, installed AIM-VPN/SSL-3 module on slot 1 but doesnt detects the card.
We have IOS (C3845-ADVSECURITYK9-M), Version 12.4(3d)
sh crypto engine brief
crypto engine name: Virtual Private Network (VPN) Module
crypto engine type: hardware
State: Enabled
Product Name: Onboard-VPN
FW Version: 01100200
Time running: 209 seconds
Compression: Yes
DES: Yes
3 DES: Yes
AES CBC: Yes (128,192,256)
AES CNTR: No
Maximum buffer length: 4096
Maximum DH index: 0700
Maximum SA index: 0700
Maximum Flow index: 1400
Maximum RSA key size: 2048
crypto engine name: Cisco VPN Software Implementation
crypto engine type: software
serial number: C112234
crypto engine state: installed
crypto engine in slot: N/A
Any Help
Jon Marshall
Ronald
You need to upgrade your IOS to the T train, specifically you need a minimum of 12.4(9)T. See this link for more details -
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htvpnssl.html#wp1066359
Jon
You are right, I needed IOS upgrade.
Using the Configurator Tool the Router 3845 shows AIM-VPN/SSL-3 but in reality its a built in on board not external AIM-VPN/SSL-3 module.
what is the difference between build in and external.
