Bookmark
Subscribe
1230
ASR1001-X EoGRE tunnel issues.
Kinh
Hi Guys,
I want to use EOGRE tunneling  between two cisco ASR1001-X in point to point.
Tunnel is up but i haven't received Eogre packet when i send icmp.
Do you have any suggestion on this?
My configuration:
Cisco IOS XE Software, Version 17.03.05
Cisco IOS Software [Amsterdam], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.5, RELEASE SOFTWARE (fc2)
#Router 1
interface Tunnel3
mac-address 0000.0000.0001
ip address 10.133.1.1 255.255.255.0
tunnel source BDI1
tunnel mode ethernet gre ipv4 p2p
tunnel destination 172.10.10.2
tunnel key 1
interface GigabitEthernet0/0/0
no ip address
ip nbar protocol-discovery
negotiation auto
service-policy input WEBUI-MARKING-IN
service-policy output WEBUI-QUEUING-OUT
service instance 1 ethernet
encapsulation dot1q 1
bridge-domain 1
interface BDI1
ip address 172.10.10.1 255.255.255.0
encapsulation dot1Q 1
#Router2
interface Tunnel3
ip address 10.133.1.2 255.255.255.0
tunnel source BDI1
tunnel destination 172.10.10.1
tunnel key 1
no ip address
negotiation auto
bridge-domain 1
interface BDI1
mac-address 0000.0000.0002
ip address 172.10.10.2 255.255.255.0
5 Replies 5
marce1000
 - You may need to lower MTU values , check this article : https://community.cisco.com/t5/networking-knowledge-base/gre-tunnel-mtu-interface-mtu-and-fragmentation/ta-p/3673508
 M.
Kinh
Thanks for this articles.
I change my MTU (1450 bytes).
However Icmp packets don't go through tunnel gre.
I think, there are mistakes in my configuration but i don't understand where...
Kinh.
Kinh
Up, nobody try this solution (EOGRE ?)
I will run lab check your config
I tried another configuration Interface and Hardware Component Configuration Guide - Ethernet over GRE Tunnels [Cisco ASR 1000 Series Aggregation Services Routers] - Cisco
But packets doesn't go through Eogre tunnel. i don't  see inner ethernet header.
