Routing and SD-WAN
Labels
Welcome to the Cisco Community Ask Me Anything EventWe invite you to participate in our Ask Me Anything (AMA) conversation. Please submit your questions from Monday, June 1, 2026, through Tuesday, June 30, 2026. Our experts Ashwin Murali (Engineering...
So it seems that applying Group Policies on Anyconnect using SAML is no longer supported ?Silently dropped from MX 19.2.7(ish) ....What the absolute *beeeeeeeeb* !!!!!! (sorry for cursing).Can anyone with inside knowledge expand on this ?Why was it d...
Hi Team,We are deploying a Cisco 8000V (8KV) VNF running IOS XE 17.4.x in an OpenStack environment. During the VNF instantiation process, we create four interfaces on the device.Our requirement is to convert the device to SD-WAN mode while retaining ...
amitsin8 by Cisco Employee
  • 129 Views
  • 0 replies
Good day all,I am trying to extended PTP form one data center to another but not sure if the way it is set up it is possible to do so. The flow looks like this:NX9K-C93108TC-FX3P(L3) 192.168.105.33 --> NX9K-C93180YC-EX(L2) vlan2300 --> Sw Stack C9500...
wgranada by Level 3
  • 750 Views
  • 8 replies
Hello,My client has an MX85 with the 2x copper WAN ports used for redundant internet services, both are enterprise static IP services.The WAN2 port has never worked, after some troubleshooting I determined the carriage service is operating fine and t...
I know this is not a putty forum, but I thought that some of you may be using this. I am trying to use Putty pscp to transfer files to and from my routers. I can pull files from the router with no problem. When I try to push a file to the router, it ...
holt0202 by Community Member
  • 19186 Views
  • 10 replies
  • 1 Helpful votes
Hi,My customer used Tenable with login username/pass to scan 8200L. Tenable finds some unexpected open TCP ports below. Port 1720 > Voice and Video Signaling (H.323)Port 2000 > SCCP (Skinny Client Control Protocol) Cisco IP Phone Registration and Con...
Hello,I have a design question, we are planning to implement a new Meraki infrastructure with the following devices :- 2 x MX450- 2 x C9300X-12Y-M- 2 ISP- some access switches - some Access Pointswe have been asked to add 2 additional and dedicated «...
aleopoldie by Level 7
  • 3862 Views
  • 23 replies
