can not enable embedded-Service-Engine on 2911
hello, i cann't enable embedded-Service-Engine on cisco2911 router
this is the output:
ALGER#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 192.168.216.1   YES unset  up                    down
GigabitEthernet0/0         192.168.216.1   YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  down                  down
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
ALGER#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ALGER(config)#interface embedded-Service-Engine 0/0
ALGER(config-if)#service-module enable
Memory size does not meet the requirements of Embedded-Service-Engine0/0
ALGER(config-if)#
ALGER#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 16:37 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
GW-DE-ALGER uptime is 3 weeks, 2 days, 18 hours, 9 minutes
System returned to ROM by reload at 15:37:21 GMT Thu Nov 8 2012
System restarted at 15:38:56 GMT Thu Nov 8 2012
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M5_2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL162012UH
3 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FGL162012UH
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
dumesh
It clearly states that it requires more memory.
You can check the below link for the memory requirements for your module.
http://www.cisco.com/en/US/prod/collateral/modules/ps10598/data_sheet_c78-553913.html
-Dheeraj
paolo bevilacqua
Suppose you can enable it, what would be the use you intend to do with it ?
will be used for Cisco Unity Express ,
we have another cisco2921 with CUE and NME-UMG with 512MB memory and work fine !
