Can't access just one site. Desk.com from Salesforce
NInja Black
Hi guys,
  I am having this issue since forever but never got to it as it wasn't critical.
From our office I can access everything but the one site i.e. <domainname>.desk.com  (IP Address 50.18.xx.xx)
This was frustrating in the beginning but putting in a static route solved the issue.
ip route 50.18.0.0 255.255.0.0 50.2xx.xx.xx
But 50.2xx.xx.xx is already the default gateway.
ip route 0.0.0.0 0.0.0.0 50.2xx.xx.xx
 Why is it that it works when I put in the spefic static route and doesn't when I remove it. Is it cause the next hop ip has the 50. address?
I am guessing the issue is with Comcast?
Guru Mysoruu
hi,
did you check putting the website ip address in url and tried..i think it will be working.
this might be a issue with dns..not able to resolve to fully qualified domain name.
kindly explain the setup and is that website hosted internally
Gurudath K S
The website is desk.com, a ticketing system from the company 'Salesforce'.
For our company the URL changes to <Domain>.desk.com
This URL doesn't seem to have a static IP. I tried pinging it and it seemed to jump around 3 IPs.
The samething is no problem when I try to login to it from home. Its in out company the problem is.
As you said I will try and find out of the DNS name and see if it is something linked internally.
e.ciollaro
Level 4
Level 4
Default route will be used if you haven't any match in routing table for a network. Are you sure there is no match for 50.18.0.0 255.255.0.0 before you configure the static route ? Could you post the routing table before and after the static rout has been configured ?
Enrico
Sure Enrico.
Will get it tonight after office hours and share.
