Bookmark
Subscribe
914
cancel switch renumber
ippolito
Hi, I issued the command:
switch 1 renumber 2
The change won't take effect until a reload; wondering if there is a way for me to cancel that operation as I made the change in error.  For that matter, is there a command to show all pending operations that won't take effect until the next reload?
Thanks in advance,
Mike
johnlloyd_13
Level 9
Level 9
hi mike,
are you referring to stacking command?
you can use the 'no' keyword and save (wr mem).
SW(config)#no switch 1 ?
  priority   Set the priority of the specified switch
  provision  Configure Switch provision / offline config
  renumber   Renumber the specified switch number
johnlloyd_13
Level 9
Level 9
hi mike,
ippolito
That worked, thank you!
Mike
