Cannot ping different subnet
parisvcisco
Until now we haven't had much config on our switches so everything is running on vlan1. I've been setting up a new vlan but wanted to give the switch an ip address on vlan1 for now so I did:
interface Vlan1
 ip address 192.168.120.240 255.255.192.0
ip default-gateway 192.168.120.248
Once I did this our monitoring server which is on a different site - ip 10.1.1.20 cannot see/ping the switch anymore.
It's a Cisco 2960 layer 2 switch.
What do I need to do in order for this switch to be able to see the 10.1.1.0/24 subnet?
I'm a bit of a beginner so excuse me if I have explained it in the most technical way!
22 Replies 22
Have a look here:
http://www.cisco.com/c/en/us/support/docs/ip/routing-information-protocol-rip/16448-default.html
"The ip default-gateway command differs from the other two commands. It should only be used when ip routing is disabled on the Cisco router."
"Creating a static route to network 0.0.0.0 0.0.0.0 is another way to set the gateway of last resort on a router. As with the ip default-network command, using the static route to 0.0.0.0 is not dependent on any routing protocols. However, ip routing must be enabled on the router. "
so after adding ip route 0.0.0.0 0.0.0.0 192.168.120.248 should I do a no default gateway?
Correct
thanks that worked!
Hi dear,
you have problem with ACL and specially subnatting /supernatting
AS you mention below in description:
interface Ethernet1
 description Internal Network (192.168.113.0/18)
 speed 100
 duplex full
 nameif inside
 security-level 90
 ip address 192.168.120.248 255.255.192.0 standby 192.168.120.249
interface Ethernet1.1
 vlan 20
 nameif guest
 security-level 80
 ip address 192.168.1.248 255.255.255.0 standby 192.168.1.249
access-list inside-vpn extended permit ip 192.168.113.0 255.255.192.0 10.1.1.0 255.255.255.0
access-list site-to-site extended permit ip 192.168.113.0 255.255.192.0 10.1.1.0 255.255.255.0
access-list split-tunnel standard permit 10.1.1.0 255.255.255.0
actually the real sub-net is: 192.168.64.0  255.255.192.0
so you have to change the ACL as well then it will work
kazim
"please rate me it post helpful"
Hello
The 2960 only support one active svi interface, So if you  did have a an ip address assigned in a different svi then it would have been over wrote.
I suggest the easiest way to get this back it to reload the switch, assuming  you didn't write your changes to the switch.
Also if you can post you core switch config it would be much easier to understand your current setup.
res
Paul
Kind Regards
Paul
Julio E. Moisa
Hi Parisvcisco,
You must have a device L3 to communicate both vlans or subnets. Cisco 2960 doesn't support L3 capabilities.
Can you provide a topology as it is connected (no details)? just to have an idea.
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
 hi Parisvcisco,
Make sure you do these two things:
1)
interface Vlan1
no shutdown (by default it is administratively  down)
2)
Switch's Port connected to ASA (default gateway) in vlan 1
and try to ping 192.168.120.248
kazim
"please rate me, if post helpful'
