08-24-2015 12:50 PM - edited 03-05-2019 02:08 AM
I am looking for some help solving a problem with a Cisco 1921 and the Verizon 4G EHWIC card. I have configured the router and it is working and was looking to add the 4G as a backup to the primary connection G0/0. The cell interface is at Cellular0/0/0. If I add the following command ip address negotiated to the cellular interface then the G0/0 basically stops working and I loose all internet connectivity until that startment is removed. I don't understand why this is occurring. Any help would be appreciated. The only item I can think of is adding the additional something with NAT not configured correctly for that interface. Does not seem that the cellular interface "dials" when the G0/0 interface goes down. I have researched and have tried many different changes but nothing is fixing this issue. The firmware is up to date on the modem and the IOS is 15.5.3. Thanks in advance for any advice. Below is the snippet of the config with sections removed to keep size down that does not pertain I believe. Also included below is the cellular interface info.
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.155-3.M.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
aaa new-model
aaa authentication login local_access local
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ethernet lmi ce
clock timezone EST -5 0
clock summer-time EDT recurring
no ip source-route
ip dhcp excluded-address 10.7.20.1 10.7.20.120
ip dhcp pool LAN
import all
network 10.7.20.0 255.255.255.0
dns-server 71.243.0.12 71.250.0.12
default-router 10.7.20.1
no ip bootp server
ip name-server 71.243.0.12
ip name-server 71.250.0.12
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ips config location flash:ips retries 1
ip ips notify SDEE
ip ips name IOS-IPS
ip ips signature-category
category all
retired true
enabled false
category ios_ips basic
retired false
enabled true
ip cef
no ipv6 cef
flow record nbar-appmon
match ipv4 source address
match ipv4 destination address
match application name
collect interface output
collect counter bytes
collect counter packets
collect timestamp absolute first
collect timestamp absolute last
flow monitor application-mon
cache timeout active 60
record nbar-appmon
parameter-map type inspect global
max-incomplete low 18000
max-incomplete high 20000
nbar-classify
chat-script lte "" "AT3CALL" TIMEOUT 60 "OK"
password encryption aes
cts logging verbose
crypto pki trustpoint TP-self-signed-2901148831
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2901148831
revocation-check none
rsakeypair TP-self-signed-2901148831
license udi pid CISCO1921/K9 sn XXXXXXXXX
license boot module c1900 technology-package datak9
object-group network local_lan_subnets
username XXXXX privilege 15 secret 5
username XXXXX privilege 12 secret 5
redundancy
controller Cellular 0/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
ip tcp synwait-time 10
policy-map type inspect LAN-WAN-POLICY
policy-map type inspect WAN-LAN-POLICY
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
zone-pair security LAN-WAN source LAN destination WAN
service-policy type inspect LAN-WAN-POLICY
zone-pair security WAN-LAN source WAN destination LAN
service-policy type inspect WAN-LAN-POLICY
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly in
shutdown
interface GigabitEthernet0/0
description PrimaryWANDesc_FiOS
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip ips IOS-IPS in
zone-member security WAN
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description Home LAN
ip address 10.7.20.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nbar protocol-discovery
ip flow monitor application-mon input
ip flow ingress
ip flow egress
ip nat inside
zone-member security LAN
load-interval 30
duplex auto
speed auto
no mop enabled
interface Cellular0/0/0
description BackupWANDesc_LTE
no ip address
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
async mode interactive
ip forward-protocol nd
ip http server
ip http upload enable path flash:
ip http upload overwrite
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no ip ftp passive
ip nat inside source list nat-list interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 253
ip route 8.8.8.8 255.255.255.255 GigabitEthernet0/0
logging trap debugging
dialer-list 1 protocol ip permit
control-plane
banner incoming ^CCisco 1921 K9/Security^C
banner login ^C
*** UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED ***
For Authorized Offical Use Only
You must have explicit permission to access
or configure this device. All activities performed
on this device are logged, and violations of
this policy may be reported to law
enforcement authorities.
There is no right to privacy on this device. ^C
line con 0
login authentication local_access
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 131.107.13.100 prefer source GigabitEthernet0/0
end
Cellular Info Below:
Cellular 0/0/0 Interface Info
show cellular 0/0/0 network
Current System Time = Mon Aug 24 2:57:48 2015
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = Verizon Wireless
Mobile Country Code (MCC) = 311
Mobile Network Code (MNC) = 480
Packet switch domain(PS) state = Attached
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 14595
Cell ID = 14598913
show cellular 0/0/0 radio
Radio power mode = ON
LTE Rx Channel Number = 5230
LTE Tx Channel Number = 23230
LTE Band = 13
LTE Bandwidth = 10 MHz
Current RSSI = -83 dBm
Current RSRP = -116 dBm
Current RSRQ = -17 dB
Current SNR = -2.0 dB
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = LTE
show cellular 0/0/0 profile
Profile password Encryption level: 7
Profile 1 = INACTIVE **
PDP Type = IPv4
Access Point Name (APN) = vzwinternet
Authentication = None
Profile 2 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwadmin
Profile 3 = INACTIVE*
PDP Type = IPv4
Profile 4 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwapp
Profile 5 = INACTIVE
PDP Type = IPv4
* - Default profile
** - LTE attach profile
show cellular 0/0/0 security
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
show cellular 0/0/0 all
Hardware Information
Modem Firmware Version = SWI9600M_03.05.10.06ap
Modem Firmware built = 2012/11/12 15:07:45
Hardware Version = 10
Device Model ID: MC7750
Package Identifier ID: MC7750_03.05.10.06_00_vzw_033.011_000
International Mobile Subscriber Identity (IMSI) = 311480039061020
International Mobile Equipment Identity (IMEI) = 990000820070961
Integrated Circuit Card ID (ICCID) = 89148000000384557279
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) = 7745030447
Current Modem Temperature = 34 deg C
PRI SKU ID = 9900853, PRI version = 00.05, Carrier = 5
Profile Information
PDP Type = IPv6
Access Point Name (APN) = vzwims
PDP Type = IPv4v6
PDP Type = IPv4
PDP Type = IPv4v6
PDP Type = IPv4
* - Default profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Network Information
Current System Time = Mon Aug 24 3:1:8 2015
Cell ID = 14598913
Radio Information
LTE Band = 13
Current RSRP = -117 dBm
Current SNR = -3.3 dB
Modem Security Information
SIM Status = OK
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 23
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 23
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status = 0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
Reference Number = 0
Result Code = 0x0
Diag Code = 0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on this platform.
Modem Crashdump Information
Modem crashdump logging: off
08-25-2015 03:35 PM
I am NO expert at this but just seems weird. Does all the other info look correct to you? So it might be a problem that I stumbled upon? The IOS version could be the issue? I am looking at document after document verifying config and making sure there is not something stupid that is being missed.
08-25-2015 03:38 PM
I don't see anything that stands out. Adding that command to the cell interface should not cause other traffic to fail unless traffic is attempting to be routed out the cell when the interface comes up. If I were you I would just open up a TAC case. These Cellular interfaces can be very tricky.
08-25-2015 03:38 PM
Will do....thanks again for your insight!
-Fred
08-25-2015 04:12 PM
Chris,
When I remove the 'ip address negotiated' from the cellular int 0/0/0 then remove the 'ip nat inside source list nat-cell interface Cellular0/0/0 overload' then connectivity is restored immediately. Ideas? Just trying to t/s a little more so I have a bunch of info to provide.
08-25-2015 04:24 PM
More in depth....
Added the nat statement left...waited....change ip address negotiated then eventually the cell profile 3 became active....even though the primary interface was still up. Seemed to start flapping. Curious...at least headed in the right direction at this point just need to figure out. By the way the Verizon APN on profile 3 was set to static not VZWINTERNET. I was never given a static IP by them. I might try to change profile 3 over to VZWINTERNET and see what happens then. Anyway I guess figure out how to have the cell interface only come up on failure of primary interface might stop the falling of the interface?
08-26-2015 08:05 AM
A static APN is different than a static IP. The APN is just basically the gateway for the cellular network. IP address negotiated is basically DHCP but not technically since it is assigned via PPP.
08-26-2015 08:38 AM
So I got an IP using the following APN last night for the first time with it set to
NE01.vzwstatic
The funny this is when I got the SIM card the rep never said anything about nor did I pay for a static which I believe this is when you are suppose use APN. Every document I have read even from Cisco regarding the LTE 4g module says the APN should be:
vzwinternet
Totally confused now because trying different things last night seemed to have gotten an IP from the cell network but then disappeared.
You can have 2 NAT statements correct for 2 different interfaces right but in doing additional reading some say that the first statement is the one the router pays attention to and even if there is a second it ignores it.
I am attaching the updated config for you to take a peek at.....
! Last configuration change at 21:43:21 EDT Tue Aug 25 2015 by cisco
! NVRAM config last updated at 21:43:21 EDT Tue Aug 25 2015 by cisco
version 15.5
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$nueg$QZd6E4mnpkyKEADDw5Cru0
aaa new-model
ethernet lmi ce
no ip source-route
ip dhcp pool LAN
import all
ip dhcp pool Dell Precision Workstation 690 Wireless
host 10.7.20.7 255.255.255.0
client-identifier 001e.c144.4823
client-name PW690
lease infinite
ip dhcp pool Ceton InfiniTV
host 10.7.20.8 255.255.255.0
client-identifier 0100.222c.ffff.ff
client-name Ceton
lease infinite
ip dhcp pool Dell Precision Mobile 4500 LAN
host 10.7.20.9 255.255.255.0
client-identifier 015c.260a.03f8.18
client-name M4500_E
lease infinite
ip dhcp pool Dell Precision Mobile 4500 Wireless
host 10.7.20.10 255.255.255.0
client-identifier 0024.d737.684c
client-name M4500_W
lease infinite
ip dhcp pool Dell Inspiron 1018 Wireless
host 10.7.20.11 255.255.255.0
client-identifier 1c65.9d9f.a663
client-name I1018_W
lease infinite
ip dhcp pool WHS
host 10.7.20.16 255.255.255.0
client-identifier 0100.155d.0230.05
client-name WHS
lease infinite
ip dhcp pool MacBook Pro 1
host 10.7.20.27 255.255.255.0
client-identifier 6c40.089d.c6d6
client-name MACPRO1
lease infinite
ip dhcp pool MacBook Pro 2
host 10.7.20.29 255.255.255.0
client-identifier 2cbe.08ef.a5c0
client-name MACPRO2
lease infinite
ip dhcp pool Verizon VMS-1100 Media Server
host 10.7.20.40 255.255.255.0
client-identifier 01cc.65ad.d677.64
client-name VMS1100
lease infinite
ip dhcp pool Verizon IPC-1100_1
host 10.7.20.41 255.255.255.0
client-identifier 011c.1b68.8cfd.60
client-name IPC1100_1
lease infinite
ip dhcp pool Verizon IPC-1100_2
host 10.7.20.42 255.255.255.0
client-identifier 011c.1b68.8cfb.38
client-name IPC1100_2
lease infinite
ip dhcp pool Verizon IPC-1100_3
host 10.7.20.43 255.255.255.0
client-identifier 011c.1b68.8cfb.05
client-name IPC1100_3
lease infinite
ip dhcp pool Verizon 4G Network Extender
host 10.7.20.44 255.255.255.0
client-identifier 0100.1632.965b.67
client-name 4GNETXTDR
lease infinite
ip dhcp pool Verizon MOCA Adapter Interface
host 10.7.20.45 255.255.255.0
client-identifier 0100.2662.d0a7.fd
client-name MOCA_INT
lease infinite
ip dhcp pool Chamberlain MyQ Internet Gateway
host 10.7.20.93 255.255.255.0
hardware-address 6452.9901.ff91
client-name MYQ
lease infinite
ip dhcp pool Honeywell RedLink Internet Gateway
host 10.7.20.95 255.255.255.0
hardware-address 00d0.2d25.c005
client-name REDLINK
lease infinite
ip dhcp pool Panasonic CF-53
host 10.7.20.96 255.255.255.0
client-identifier e8b1.fca2.780d
client-name CF53
lease infinite
no ip bootp server
ip ips notify SDEE
ip ips name IOS-IPS
category all
retired true
enabled false
retired false
enabled true
ip cef
no ipv6 cef
record nbar-appmon
nbar-classify
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
cts logging verbose
license udi pid CISCO1921/K9 sn FGL18182393
object-group service INTERNAL_UTM_SERVICE
object-group network diskstation_dst_net
any
object-group network diskstation_src_net
any
object-group service diskstation_svc
tcp source range 5000 5001 range 5000 5001
object-group network energy_detective_dst_net
any
object-group network energy_detective_src_net
any
object-group service energy_detective_svc
tcp source eq 1080 eq 1080
tcp source eq 1080 eq 1443
tcp source eq 1443 eq 1080
tcp source eq 1443 eq 1443
object-group network lan_dst_net
any
object-group network lan_src_net
any
object-group service lan_svc
ip
object-group network local_cws_net
object-group network mobile_net_extender_dst_net
any
object-group network mobile_net_extender_src_net
any
object-group service mobile_net_extender_svc
tcp source eq 4125 eq 4125
tcp source eq 4125 range 5443 5444
tcp source range 5443 5444 eq 4125
tcp source range 5443 5444 range 5443 5444
object-group network rdp_server_dst_net
any
object-group network rdp_server_src_net
any
object-group service rdp_server_svc
tcp source eq 3389 eq 3389
object-group network vpn_remote_subnets
any
FE3F0C87 89BCB7BB 994AE74C FA9E481D F65875D6 85EAF974 6D9CC8E3 F0B08B85
50437722 FFBE85B9 5E4189FF CC189CB9 69C46F9C A84DFBA5 7A0AF99E AD768C36
006CF498 079F88F8 A3B3FB1F 9FB7B3CB 5539E1D1 9693CCBB 551F78D2 892356AE
2F56D826 8918EF3C 80CA4F4D 87BFCA3B BFF668E9 689782A5 CF31CB6E B4B094D3
F3020301 0001
quit
no cdp run
track 1 ip sla 1 reachability
class-map type inspect match-any INTERNAL_DOMAIN_FILTER
match protocol msnmsgr
match protocol ymsgr
class-map type inspect match-all energy_detective
description TED Energy Monitor
match access-group name energy_detective_acl
class-map type inspect match-all rdp_server
description Remote Desktop Protocol
match access-group name rdp_server_acl
class-map type inspect match-all lan
description Outbound
match access-group name lan_acl
class-map type inspect match-all mobile_net_extender
description Verizon Network Extender
match access-group name mobile_net_extender_acl
class-map type inspect match-all diskstation
description Synology DiskStation
match access-group name diskstation_acl
class type inspect lan
inspect
class type inspect INTERNAL_DOMAIN_FILTER
inspect
class class-default
drop log
class type inspect energy_detective
inspect
class type inspect mobile_net_extender
inspect
class type inspect diskstation
inspect
class type inspect rdp_server
inspect
inspect
class class-default
drop log
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
ip address dhcp
ip nat outside
ip ips IOS-IPS in
duplex auto
speed auto
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
duplex auto
speed auto
no mop enabled
no ip address <---- This will be ip address negotiated but for t/s I changed
no ip unreachables
ip flow ingress
ip flow egress
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer string lte
dialer-group 1
ip http server
no ip ftp passive
ip nat inside source list nat-cell interface Cellular0/0/0 overload <----This is not in the config right now
ip access-list extended diskstation_acl
permit object-group diskstation_svc object-group diskstation_src_net object-group diskstation_dst_net
ip access-list extended energy_detective_acl
permit object-group energy_detective_svc object-group energy_detective_src_net object-group energy_detective_dst_net
ip access-list extended lan_acl
permit object-group lan_svc object-group lan_src_net object-group lan_dst_net
ip access-list extended mobile_net_extender_acl
permit object-group mobile_net_extender_svc object-group mobile_net_extender_src_net object-group mobile_net_extender_dst_net
ip access-list extended nat-cell
permit ip object-group local_lan_subnets any
deny ip any any
ip access-list extended nat-list
deny ip any any
ip access-list extended rdp_server_acl
permit object-group rdp_server_svc object-group rdp_server_src_net object-group rdp_server_dst_net
ip sla 1
icmp-echo 8.8.4.4 source-interface GigabitEthernet0/0
frequency 1800
ip sla schedule 1 life forever start-time now
control-plane
banner login ^C
line con 0
line aux 0
line 2
no exec
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
line vty 0 4
access-class 23 in
privilege level 15
ntp update-calendar
end
08-26-2015 08:59 AM
Your config looks fine. We have multiple nat statements for each interface we NAT to. Here is ours:
ip nat inside source route-map RM_NAT_CELL interface Cellular0/0/0 overload
ip nat inside source route-map RM_NAT_LAN interface GigabitEthernet0/1 overload
ip nat inside source route-map RM_NAT_SAT interface GigabitEthernet0/2 overload
instead of directly calling an access-list in our NATs, we just use a route-map which then calls the access-list. All of the NAT statements/interfaces are using the same ACL to define which traffic to NAT.
By the way, our APN is vzwinternet and we do not have a statically defined one.
P.S. It looks like based on your config that you work in DoD.
08-26-2015 11:35 AM
Changed APN profile 3 over to vzwinternet.
I like your idea on this. Have not done this before using routes. Explanation or easy way to configure?
Removed the ACL nat-cell out of the config to start I guess is a good place to begin. I am guessing but I should remove the NAT statement for G0/0?
08-26-2015 12:05 PM
I wouldn't change your config, just add that extra NAT statement and use the same source list ACL for both.
08-26-2015 12:49 PM
So I try to add that additional NAT statement for the cellular interface and not matter what the config does not take it. Basically it only takes one statement and that is it. Weird. I also have now tries using CCP Express v3.1.1 to do the same. There it says when you enable NAT from the primary interface that it will enable NAT on both interfaces but the CLI in the GUI does not show the same. I am trying everything to figure this out.....looks like a TAC job now.
08-27-2015 04:31 AM
So after some additional digging found the following. You cannot do 2 NAT statement without using route-map.
Adding the following to the config:
ip nat inside source route-map NAT1 interface GigabitEthernet0/0 overload
ip nat inside source route-map NAT2 interface Cellular0/0/0 overload
route-map NAT2 permit 10
match ip address 100
match interface Cellular0/0/0
route-map NAT1 permit 10
match interface GigabitEthernet0/0
access-list 100 permit ip 10.7.20.0 0.0.0.255 any
Seems now that I can get the cellular interface to come up on profile 3 and it becomes active.
The next issue as it seems the cellular interface comes up when the primary WAN goes down but flaps using the ip sla configuration. Although I get an IP address from the wireless network via the APN vzwinternet. I have to figure out why that is but at least making progress.
08-27-2015 06:28 AM
I didn't know that you couldn't have two NAT statements without using a route-map. We also tried using an SLA in our config but we experienced the same flapping problem. We just decided not to use the SLA. Let me know if you figure out how to get the SLA to work!
08-27-2015 07:35 AM
Here is a question you might be able to shed some light on. When I do a show arp, I not only get address for LAN but I get many from all different addresses but all the same MAC. I believe it should only show the internal LAN. Something miss configured or missing?
08-28-2015 05:24 AM
Fixed the ARP problem by changing the following commands:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 dhcp
Now the ARP table only show internal LAN.
I am working on the SLA portion now to figure out a ay to make this work.
