Cisco 2960XR routing support
shantanu
HI ,
Can you please help me whether Cisco Catalyst 2960XR-24TD-I supports PBR, RIPv2, OSPFv2,RIPng, OSPFv3
IPV6 First hop security, Static routing and also Dual stack mode to run both IPv4 & IPv6 RIP and RIPng..
If yes then what will be the part number / sku in support line item will be ...
With Regards,
Shantanu
balaji.bandi
2960XR-24TD-I - means IP Lite
Software :
All Cisco Catalyst 2960-X and 2960-XR Series Switches use a single universal Cisco IOS Software image for all SKUs. Depending on the switch model, the Cisco IOS image automatically configures the LAN Lite, LAN Base, or IP Lite feature set.
Note that each switch model is tied to a specific feature level; LAN Lite cannot be upgraded to LAN Base, and LAN Base cannot be upgraded to IP Lite.
BB
Deepak Kumar
This Switch is having IPLite Image and IP Lite introduced enterprise access Layer 3 features to the 2960-XR switch models. IP Lite is the subset of IP Base features. Some of the IP Lite features are:
   Routing Information Protocol (RIP) v1
   Routing Information Protocol (RIP) v2
   Open Shortest Path First (OSPF) v2 Routed Access
   Open Shortest Path First (OSPF) v3 Routed Access
   Enhanced Interior Gateway Routing Protocol (EIGRP) stub
   Equal-cost routing
   Hot Standby Router Protocol (HSRP)
   Protocol Independent Multicast PIM (Sparse Mode, Dense Mode, Sparse-Dense Mode, Source Specific Multicast) stub
   Virtual Router Redundancy Protocol (VRRP) for IPv4
   Private VLAN
   IPv6 First Hop Security source guard
   Per-VLAN and per-port policers
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
saif akbar
