06-23-2022
12:29 AM
- last edited on
02-13-2023
09:23 PM
by
Translator
Good Day All,
I am experiencing issues with my Cisco 4321 router which keeps restarting,
ISO isr4300-universalk9.17.03.05.SPA.bin.
Please advise on the possible causes of this.
Solved! Go to Solution.
07-27-2022 11:32 PM
Hi Paul,
No, I logged a ticket with cisco and after some troubleshooting, they advised I should send back the device for replacement.
Salom
06-23-2022
01:23 AM
- last edited on
02-13-2023
09:50 PM
by
Translator
Do you have any Logs captured ? looks for me router is crashing.
Question here, what was the OLD Version, is that working as expcted before with out any reloads ? what is the reason of upgrade to new Code.
if you upgrade as fancy, then i would go back to stable version which was working and engage with TAC for your issue.
if you upgraded due to some bug, and TAC advised to go with
- then i still engage with TAC here too.
06-23-2022 01:52 AM
It's a new router, I have two other routers in the environment running the same IOS but there are no rebooting issues. I tried replacing the power cable with CAB-PWR-MIEC-CLVR power code as the router was restarting frequently. I have also observed that when I prepped the router at some point it went into romon mode.
06-23-2022
03:04 AM
- last edited on
02-13-2023
09:51 PM
by
Translator
Connect console and capture the Logs if you have any ?
can you post below output :
show version
show boot
06-23-2022
03:16 AM
- last edited on
02-13-2023
10:04 PM
by
Translator
Hi BB,
Please see below logs
show boot
BOOT variable = flash:isr4300-universalk9.17.03.05.SPA.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
show ver
uptime is 10 hours, 43 minutes
Uptime for this control processor is 10 hours, 45 minutes
System returned to ROM by PowerOn at 15:19:32 NAM Fri Jun 10 2022
System restarted at 01:31:02 NAM Thu Jun 23 2022
System image file is "flash:isr4300-universalk9.17.03.05.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 50000 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ISR4321/K9 (1RU) processor with 1714631K/3071K bytes of memory.
Processor board ID FDO2617M075
Router operating mode: Autonomous
1 Virtual Ethernet interface
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
Standby not ready to show bootvar
06-23-2022
05:15 AM
- last edited on
02-13-2023
10:05 PM
by
Translator
>....Last reload reason: PowerOn
- Normally this is powering problem 'only' , check power supplies and check if (external) power-feed is stable
M.
06-23-2022
01:54 AM
- last edited on
02-13-2023
10:06 PM
by
Translator
See below logs
Log Buffer (16000 bytes):
01:31:44.374 NAM: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 23 01:31:44.406 NAM: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Wed 09-Feb-22 10:37 by mcpre
Show ver
Uptime for this control processor is 9 hours, 24 minutes
06-23-2022
04:01 AM
- last edited on
02-13-2023
10:06 PM
by
Translator
power on ..boot.
do you see the image in flash - when you issue command -
dir flash:
when it ROMMON, what are you doing to boot ?
you may need console logs to capure when the next reboot accours to understand the issue.
not sure you have RP here ?
Can you post :
#show platform
06-23-2022
05:52 AM
- last edited on
02-13-2023
10:07 PM
by
Translator
show platform
Chassis type: ISR4321/K9
Slot Type State Insert time (ago)
0 ISR4321/K9 ok 13:21:38
0/0 ISR4321-2x1GE ok 13:20:24
0/1 NIM-ES2-8 ok 13:20:24
R0 ISR4321/K9 ok, active 13:21:38
F0 ISR4321/K9 ok, active 13:21:38
P0 PWR-4320-AC ok 13:21:02
P2 ACS-4320-FANASSY ok 13:21:02
Slot CPLD Version Firmware Version
0 19040541 17.6.2
R0 19040541 17.6.2
F0 19040541 17.6.2
06-23-2022 05:35 AM
06-24-2022 04:28 PM
DO you check the bug I share ?
06-27-2022 07:41 AM
I replaced the faulty router
