Cisco 837 ADSL Router (WAN Issue)
reb999000
To All,
I  am having an issue attempting to  connect to my ISP Bt  Internet (ISP Provider in UK) I have copy/pasted the input from show  running-config, please view the input and please point out to me of anything incorrect?
Router#show run
Building configuration...
Current configuration : 1628 bytes
version 12.3
no service pad
hostname Router
enable secret 5 $1$xJ8e$hhR8op6B/LxC4bXNTkI0d.
no aaa new-model
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description Ethernet
ip address 192.168.1.1 255.255.255.0 (Default Gateway)
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
   encapsulation aal5mux ppp dialer
   dialer pool-member 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ***************@adsl.btinternet.com
ppp chap password 0 adsl**************
ppp pap sent-username *************** password 0 **************
ppp ipcp mask request
ppp ipcp address accept
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
access-list 1 permit 192.168.0.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Here is also an input from show ip int brief:
Router#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
Dialer0                    172.16.68.234   YES IPCP   up                    up
Ethernet0                  192.168.1.1     YES NVRAM  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
I would br very greatful of any help in resolving this problem
Much Appreciated!
Bob.
this feature is only available in  12.3(11)T and 12.4 images.
I wonder how it could prevent you from being given a private IP
Regards.
Alain
18 Replies 18
cadet alain
you got an IP from the ISP so now can you try pinging 8.8.8.8 from the router and tell us the result.
if it is working then do the same from a host and  post the output of sh ip nat translation on the router, also post ipconfig/all from the PC.
Regards.
Alain
cadet alain,
Please find below the output from ping 8.8.8.8: (which appears uncommunicative)
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Also please find below the output from show ip nat translation:
Router#show ip nat translation
Router#
Also please find below the output from my PC (I am using Win XP Pro) ipconfig/all:
(As you will see that I am using static ip addresses and I have reseved both 192.168.1.9 & 192.168.1.10 for my two HP network printers)
C:\Documents and Settings\Robert Brindle>ipconfig/all
Windows IP Configuration
        Host Name . . . . . . . . . . . . : robertbrindle
        Primary Dns Suffix  . . . . . . . :
        Node Type . . . . . . . . . . . . : Unknown
        IP Routing Enabled. . . . . . . . : No
        WINS Proxy Enabled. . . . . . . . : No
        DNS Suffix Search List. . . . . . : 192.168.1.1
Ethernet adapter Local Area Connection:
        Connection-specific DNS Suffix  . : 192.168.1.1
        Description . . . . . . . . . . . : 3Com 3C920 Integrated Fast Ethernet
Controller (3C905C-TX Compatible)
        Physical Address. . . . . . . . . : 00-06-5B-57-05-39
        Dhcp Enabled. . . . . . . . . . . : No
        IP Address. . . . . . . . . . . . : 192.168.1.30
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . : 192.168.1.1
        DNS Servers . . . . . . . . . . . : 192.168.1.1
Bob.
mass raja
Please check with your ISP about the ip address assigned to you.
172.16.68.234 is not a routable ip address. its a private ip address.
mass raja,
I have spoken to my ISP and they are a total waste of time, they had supplied me an address 192.168.1.254 I had tried and absolutly no luck whatsoever.
Bob.
why are they providing you private addressing for ADSL connection ? You should really investigate with them.
Regards.
Alain
cadet alain,
please have a look at input from "show ip int d0"
Router#show ip int d0
Dialer0 is up, line protocol is up
  Internet address is 172.16.68.244/32
  Broadcast address is 255.255.255.255
  Address determined by IPCP
  MTU is 1452 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is enabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
  BGP Policy Mapping is disabled
Bob
Hi Bob,
can you do this:
logging buffered 100000 debug
no service timestamp debug
do debug aaa negotiation
int atm0
shut
no shut
do sh log
and post the results.
Regards.
Alain
cadet alain,
This is the output as you had asked:
(Unfortunately the 837 will not accept "debug aaa negotiation" command)
Router#
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#logging buffered 1000000 debug
Router(config)#no service timestamp debug
Router(config)#debug aaa negotiation
% Invalid input detected at '^' marker.
Router(config)#int atm0
Router(config-if)#shut
Router(config-if)#
%LINK-3-UPDOWN: Interface Virtual-Access2, changed state to downn
%DIALER-6-UNBIND: Interface Vi2 unbound from profile Di0
% Incomplete command.
Router(config-if)#
%LINK-5-CHANGED: Interface ATM0, changed state to administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
Router(config-if)#no shut
Router(config-if)#
%LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
%DIALER-6-BIND: Interface Vi2 bound to profile Di0
%LINK-3-UPDOWN: Interface ATM0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
Router(config-if)#end
Router#
This the output from "show log"
Router#show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 43 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 11 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 49 message lines logged
Log Buffer (100000 bytes):
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
%SYS-5-CONFIG_I: Configured from console by console
Bob.
int atm0
shut
no shut
do sh log
Regards.
Alain
cadet alain,
Please find below the command output below:
Router#
Router#debug aaa negotiation
Router#conf t
Router(config-if)#
Router(config-if)#
Router(config-if)#
Router(config-if)#exit
Router(config)#exit
Router#
Router#show log
    Console logging: level debugging, 52 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
    Buffer logging: level debugging, 52 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 58 message lines logged
Log Buffer (16256 bytes):
*Mar  1 00:00:05.487: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Mar  1 00:00:05.491: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*Mar  1 00:00:05.491: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*Mar  1 00:00:05.491: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*Mar  1 00:00:17.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to up
*Mar  1 00:00:17.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to up
*Mar  1 00:00:17.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to up
*Mar  1 00:00:17.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
*Mar  1 00:00:17.283: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up
%LINK-3-UPDOWN: Interface ATM0, changed state to down
%LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
%LINK-3-UPDOWN: Interface FastEthernet3, changed state to down
%LINK-3-UPDOWN: Interface FastEthernet4, changed state to down
%SYS-5-CONFIG_I: Configured from memory by console
%LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
%SYS-5-RESTART: System restarted --
IOS (tm) C837 Software (C837-K9O3SY6-M), Version 12.3(2)XC2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(1.6)T
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 04-Mar-04 01:03 by ealyon
%SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router#
Bob.
I'm so sorry I just noticed I had put a wrong command, the correct one is debug ppp negotiation.
Really sorry wasting your time like this.
Regards.
Alain
cadet alain,
Router#debug ppp negotiation
PPP protocol negotiation debugging is on
Router#conf t
Router(config-if)#
Vi2 IPCP: Remove link info for cef entry 81.146.178.2
Vi2 PPP: Sending Acct Event[Down] id[2]
Vi2 IPCP: State is Closed
Vi2 PPP: Phase is ESTABLISHING, renegotiate LCP
Vi2 PPP: No remote authentication for call-out
Vi2 LCP: O CONFREQ [Closed] id 5 len 10
Vi2 LCP:    MagicNumber 0x17107A35 (0x050617107A35)
Di0 IPCP: Remove route to 81.146.178.2
Vi2 LCP: State is Closed
Vi2 PPP: Phase is DOWN
Router(config-if)#
Vi2 PPP: Using dialer call direction
Vi2 PPP: Treating connection as a callout
Vi2 PPP: Phase is ESTABLISHING, Active Open
Vi2 LCP: O CONFREQ [Closed] id 6 len 10
Vi2 LCP:    MagicNumber 0x1710F572 (0x05061710F572)
Vi2 LCP: TIMEout: State REQsent
Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Vi2 LCP: I TERMREQ [REQsent] id 1 len 4
Vi2 LCP: O TERMACK [REQsent] id 1 len 4
Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Vi2 LCP: I CONFREQ [REQsent] id 66 len 19
Vi2 LCP:    MRU 1500 (0x010405DC)
Vi2 LCP:    AuthProto CHAP (0x0305C22305)
Vi2 LCP:    MagicNumber 0x623C5F81 (0x0506623C5F81)
Vi2 LCP: O CONFACK [REQsent] id 66 len 19
Vi2 LCP: I CONFACK [ACKsent] id 9 len 10
Vi2 LCP: State is Open
Vi2 PPP: Phase is AUTHENTICATING, by the peer
Vi2 CHAP: I CHALLENGE id 1 len 37 from "bras-red10.l-nws"
Vi2 CHAP: Using hostname from interface CHAP
Vi2 CHAP: Using password from interface CHAP
Vi2 CHAP: O RESPONSE id 1 len 34 from "RobertBrindle"
Vi2 CHAP: I SUCCESS id 1 len 43 msg is "CHAP authentication success, unit 22522"
Vi2 PPP: Phase is FORWARDING, Attempting Forward
Vi2 PPP: Queue IPCP code[1] id[162]
Vi2 PPP: Phase is ESTABLISHING, Finish LCP
Vi2 PPP: Phase is UP
Vi2 IPCP: O CONFREQ [Closed] id 1 len 32
Vi2 IPCP:    VSO OUI 0x00000C kind 1 (0x000A00000C0100000000)
Vi2 IPCP:    Address 0.0.0.0 (0x030600000000)
Vi2 IPCP:    PrimaryDNS 62.6.38.125 (0x81063E06267D)
Vi2 IPCP:    SecondaryDNS 62.6.38.125 (0x83063E06267D)
Vi2 PPP: Process pending packets
Vi2 IPCP: Redirect packet to Vi2
Vi2 IPCP: I CONFREQ [REQsent] id 162 len 10
Vi2 IPCP:    Address 81.146.178.2 (0x03065192B202)
Vi2 IPCP: Accept the peer address 81.146.178.2
Vi2 IPCP: O CONFACK [REQsent] id 162 len 10
Vi2 IPCP: I CONFREJ [ACKsent] id 1 len 14
Vi2 IPCP: O CONFREQ [ACKsent] id 2 len 28
Vi2 IPCP:    SubnetMask 0.0.0.0 (0x900600000000)
Vi2 IPCP: I CONFREJ [ACKsent] id 2 len 10
Vi2 IPCP: O CONFREQ [ACKsent] id 3 len 22
Vi2 IPCP: I CONFNAK [ACKsent] id 3 len 10
Vi2 IPCP:    Address 172.16.68.168 (0x0306AC1044A8)
Vi2 IPCP: O CONFREQ [ACKsent] id 4 len 22
Vi2 IPCP: I CONFACK [ACKsent] id 4 len 22
Vi2 IPCP: State is Open
Di0 IPCP: Install negotiated IP interface address 172.16.68.168
Di0 IPCP: Install route to 81.146.178.2
Vi2 IPCP: Add link info for cef entry 81.146.178.2
Router#
Router#show log
    Console logging: level debugging, 127 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
    Buffer logging: level debugging, 127 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 45 message lines logged
*Mar  1 00:00:05.455: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Mar  1 00:00:05.455: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*Mar  1 00:00:05.455: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*Mar  1 00:00:05.455: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*Mar  1 00:00:17.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to up
*Mar  1 00:00:17.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to up
*Mar  1 00:00:17.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to up
*Mar  1 00:00:17.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
*Mar  1 00:00:17.251: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
Router#
Bob.
can you try this:
int dialer 0
no ppp ipcp mask request
no ppp ipcp address accept
then redo the test like before but first in config t: do clear log
Regards.
Alain
cadet alain,
I have removed the two above commands in the d0 interface and did the clear log and performed the test commands in the atm0 interface and show log.
I am afraid no joy at all.
Bob.
