Create Port Channel on Cisco NCS 540 Router with Non-Cisco Switch
Cisco Support
We are going to aggregate two GIG ports of NCS router and connect to the Non -Cisco Layer 03 core switch stack. Please refer to the below mention diagram for more understanding
As per above diagram
Configuration already made on Cisco NCS 540 1 Router:
interface Bundle-Ether1
 description Link to HQ_LAN_CORE
 ipv4 address 172.16.7.161 255.255.255.248
interface GigabitEthernet0/0/0/18
 bundle id 1 mode active
interface GigabitEthernet0/0/0/19
NCS router has been configured in the above manner and link aggregation has been configured in the same manner in the non cisco switch. But after connecting the cables, the gig ports of the router are up, but the ports of the non-cisco switch are not up. That mean port channel in operational between NCS router and non-cisco switch
Please note:  aggregate port of the non-cisco switch is in switch port state, but the NCS router's gig port are not specify as switchports
What could be the issue, NCS router unable to aggregate their ports with layer 2 interface or if their any specific method to do that?
17 Replies 17
friend start NO SHUT the PO
then  NO SHUT the port member
Yes did but not work
OK, here is L1 issue or L2 issue
NO SHUT PO
then only NO SHUT ONE port member
