DMVPN Phase 1 Hub to Spoke connection
Sunny Banks
Hi all,
Hopefully you can help me out. I'm trying to configure a DMVPN phase 1 Hub to Spoke connection (only mGRE and NHRP). On the hub my tunnel 0 interface is up/down and i'm unsure why. I've triple checked the tunnel config. (NBMA and tunnel IP's etc.) and it all looks good. I'm using a default route on the hub and spokes and have full connectivity site to site using the underlay network. I've added the relevant config. below :-
HUB
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
no ip redirects
ip nhrp network-id 10
tunnel source 15.0.0.1
tunnel mode gre multipoint
interface Serial0/0
ip address 15.0.0.1 255.255.255.0
clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
SPOKE
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
ip nhrp map 10.1.1.1 15.0.0.1
ip nhrp nhs 10.1.1.1
tunnel source 25.0.0.2
tunnel destination 15.0.0.1
interface Serial0/1
ip address 25.0.0.2 255.255.255.0
clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1
I'm not using any routing protocols, only default routes on the hub and spokes but (as mentioned above) have full connectivity yet still can't get the hub tunnel 0 to move from up/down. The spoke is looking good in terms of the tunnel 0 being up/up and output from sh ip nhrp.
Any help is much appreciated,
Sunny
24 Replies 24
Sunny Banks
Gents,
Suggested changes made to no avail. Issue still persists. Full configs as requested :-
HUB
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
ip audit po max-events 100
no ip domain lookup
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
no ip redirects
ip nhrp map multicast dynamic
tunnel source Serial0/0
interface FastEthernet0/0
duplex auto
speed auto
interface Serial0/0
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface FastEthernet3/0
no ip address
shutdown
interface FastEthernet3/1
no ip address
shutdown
interface FastEthernet3/2
no ip address
shutdown
interface FastEthernet3/3
no ip address
shutdown
interface FastEthernet3/4
no ip address
shutdown
interface FastEthernet3/5
no ip address
shutdown
interface FastEthernet3/6
no ip address
shutdown
interface FastEthernet3/7
no ip address
shutdown
interface FastEthernet3/8
no ip address
shutdown
interface FastEthernet3/9
no ip address
shutdown
interface FastEthernet3/10
no ip address
shutdown
interface FastEthernet3/11
no ip address
shutdown
interface FastEthernet3/12
no ip address
shutdown
interface FastEthernet3/13
no ip address
shutdown
interface FastEthernet3/14
no ip address
shutdown
interface FastEthernet3/15
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
no ip http server
no ip http secure-server
no cdp log mismatch duplex
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SPOKE
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip nhrp map multicast 15.0.0.1
tunnel source Serial0/1
interface Tunnel1
no ip address
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
spoke# ping 10.1.1.1 source 10.1.1.2
SPOKE
R2#ping 10.1.1.1 source 10.1.1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.2
Success rate is 0 percent (0/5)
R2#ping 10.1.1.1
HUB
R1#ping 10.1.1.2 source 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.1
R1#ping 10.1.1.2
UUUUU
The tunnel interface is tied to the physical interface including reachability to the destination tunnel. Conditions that can cause the Tunnel to be up/down include:
1. Physical interface is shutdown
2. No ip route to the destination
I guess this is a lab that you're doing. I would suggest the following
1. Shut/No shut the tunnel interface
2. Change the clock rate on the serial interface
3. Use the Fastethernet interface. If it works, then it's an issue with the Serial interface.
4. Delete R1 (Hub) and configure a fresh router
Nice one for the suggestions. I'll give them a go. I'm beginning to think it is a weird gns3 issue. I've had a good few second opinions and the tunnel configuration, by all accounts, looks good.
show the network topology
just try to create ordinary p2p gre  tunnel and check if it works...
Added the topology earlier in the thread.
Already did p2p and worked (specifying a single destination at both hub and spoke). I'm trying out Phase 1 but it looks as though it could be a gns3 issue. I'll give Phase 2 a go and see how that works out. Appreciate your time.
Just a quick update to finish off. Turns out it was a GNS3 issue. Deleted the hub router and re-applied config to a new hub using a different ios. Everything now working as intended. Bloody GNS3. Appreciate the help all around.
oh we were in impression this was live environment, glad you clarified. and working.
BB
