do cisco support
sudhir.rai
do cisco  now support the IOS c2950-i6q4l2-mz.121-22.EA6.bin do is it recommended to upgarde the IOS , since the mention IOS have not given any issues so far???
paolo bevilacqua
Very old switch, very old software, it does not make a difference if you update or not.
Thanks for your reply ,
But do you mean cisco 2950C 24 port switch is not supported by cisco .
Also do you think  software should not  be upgraded .
Please share the reason as i have to give the strong reason to client to not to upgrade the software
12.1(22) EA13 is the latest software for that platform. You can certainly
ask your client to upgrade the software if there is a need to upgrade the
software. The device is still supported by Cisco. The last date of support
is October 20, 2013.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps628/prod_end-of
-life_notice0900aecd806ea1da.html
NT
