Eigrp bandwidth percent cntrl
feroz syed
Level 3
Level 3
I have very big confusing in eigrp bandwitdh allocate,actually i have two eigrp topology using frame-relay switch one is hub and spoke
scenario another one is point-to-point connection from hub to spoke,
Now in first topology hub has connection with two spokes R1--R2 and R1--R3, hub using serial interface with default bandwitdh 1.544kbps and both spokes aslo the same bw.  how i have to calculate to reduce the bandwidth for eigrp to use 25% bw on hub interface, by default eigrp take 50% of bw so (1.544 /2 = 0.772  25% = 0.193kb), is this right ??, please any one make it clear for me,it would be greatly appreciated
1544/4 = 386
193 would be 1/8 which is 12.5%
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
daniel.dib
Level 7
Level 7
So you have one physical interface with two spokes connected to it?
The default is to use a MAXIMUM of 50% which would be 772 kbit/s. If you set it to 25% then it would be 386 kbit/s.
It's not very likely that you have this much EIGRP traffic running though. Is this for production or labbing?
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Hi, i just practice on lab, how did you get 386kbps value, it should be 0.193 ??
1544/4 = 386
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
