hello i have a router 2901 and
i have a problem in my eigrp configuration that the other branch only see the network that i am advertised in eigrp and can't see the the redistibuted static route inside eigrp .. i dunno why is that
and that's my running
aaa new-model
aaa session-id common
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name andalusia.loc
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 41.32.188.36 255.255.255.248
ip nat outside
ip virtual-reassembly
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.3.180 255.255.255.0
ip nat inside
ip policy route-map redirect
interface GigabitEthernet0/0.110
encapsulation dot1Q 110
ip address 10.21.176.180 255.255.240.0
ip nat inside
interface GigabitEthernet0/0.150
encapsulation dot1Q 150
ip address 10.21.160.180 255.255.240.0 secondary
ip address 192.168.150.180 255.255.255.0
interface GigabitEthernet0/0.240
encapsulation dot1Q 240
ip address 10.21.240.180 255.255.240.0
ip nat outside
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1.1
interface Serial0/0/0
description LinkDotNet_MPLS
no ip address
ip flow ingress
encapsulation frame-relay IETF
no fair-queue
clock rate 2000000
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description Mgt
ip address 10.193.7.54 255.255.255.252
ip flow ingress
frame-relay interface-dlci 80
interface Serial0/0/0.2 point-to-point
description Data1
ip address 10.193.7.58 255.255.255.252
ip flow ingress
frame-relay interface-dlci 81
interface Serial0/0/1
description TEdata_MPLS
no ip address
ip flow ingress
clock rate 2000000
frame-relay lmi-type q933a
interface Serial0/0/1.16 point-to-point
ip address 172.16.2.2 255.255.255.252
ip flow ingress
frame-relay interface-dlci 16
router eigrp 100
network 10.21.160.180 0.0.0.0
network 172.16.2.2 0.0.0.0
redistribute static
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source route-map To-101 interface GigabitEthernet0/0.240 overload
ip nat inside source route-map To-102 interface GigabitEthernet0/0.1 overload
ip nat inside source static 10.21.176.50 41.32.188.37
ip route 10.21.0.0 255.255.0.0 10.21.160.1
ip route 0.0.0.0 0.0.0.0 41.32.188.33
ip route 0.0.0.0 0.0.0.0 10.21.240.101 200
ip route 10.1.0.0 255.255.0.0 10.193.7.57 200
ip route 10.2.0.0 255.255.0.0 10.193.7.57 200
ip route 10.3.0.0 255.255.0.0 10.193.7.57 200
ip route 10.22.0.0 255.255.0.0 10.193.7.57 200
ip route 213.131.65.192 255.255.255.224 10.193.7.53
ip route 213.131.66.0 255.255.255.0 10.193.7.53
ip access-list extended To-101
permit ip host 192.168.3.8 any
permit ip 10.21.176.0 0.0.15.255 any
ip access-list extended To-102
permit ip host 192.168.3.7 any
access-list 10 permit 10.21.0.0 0.0.255.255
access-list 15 deny 0.0.0.0
access-list 15 permit any
route-map test permit 10
match ip address 10
route-map redirect permit 10
match ip address To-101
set ip next-hop 10.21.240.101
set interface GigabitEthernet0/0.240
route-map redirect permit 20
match ip address To-102
set ip next-hop 41.32.188.33
set interface GigabitEthernet0/0.1
route-map To-102 permit 10
route-map To-101 permit 10
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
password 7 09764F1B170C1C1A5A5957
transport input ssh
scheduler allocate 20000 1000
end
i need to advertise the subnet 10.21.0.0/16 inside the eigrp ..
anyone can help with this problem ?
Solved! Go to Solution.
Youssef,
I know that this thread is pretty old. Nevertheless . . .
Could it be as simple as the network is not included in the list of networks in your router eigrp section?
router eigrp 100
redistribute static
Neither of those network statements will cover 10.21.0.0/16. I'd try adding:
network 10.21.0.0 0.0.255.255
And see what that does.
This is because you missing the metric
Use the default metric under eigrp confignas bellow
default-metric 10000 100 255 1 1500
Or use it with redistribute command like
Redistribute static metric 10000 100 255 1 1500
See the bellow link for more details
http://www.ciscopress.com/articles/article.asp?p=27839&seqNum=7
Hope this help
If helpful rate
tx but i tried this also yesterday and it didn't solve the problem .
another ideas ?
is 10.21.0.0/16 made it to RIB?
sh ip route 10.21.0.0 255.255.0.0
is this marked by red subnet missing, or the other statics as well?
what is the configuration on the other side? stubs won't accept externals for example.
HTH,
Ivan.
Can you run a debug and see if it's even being advertised out towards the remote destination? If so, it could be getting blocked down the yellow brick road by some other security measure or routing manipulation? Also, do you see any other routes that are being redistributed on this remote router?
Also. Under eigrp config add
No auto-summary
And you have to use the metric for redistribution to work in eigrp it is not optional
Hope this help
Hello Marwan,
It has been my experience - but I may be wrong here or the IOS default may have changed! - that when redistributing specifically static or connected routes, the seed metric is not necessary as it will be derived from the EIGRP metrics of the egress interface of the redistributed route. I did not need to specify a seed metric when redistributing static/connected routes into EIGRP. However, having the seed metric specified is a safe bet, certainly.
Just my two cents...
Best regards,
Peter
Hi Peter,
Is there some document that indicates "that when redistributing specifically static or connected routes, the seed metric is not necessary as it will be derived from the EIGRP metrics of the egress interface of the redistributed route"?
Thanks in advance,
David
Hello David,
I have not found any document so far that would explicitly confirm that for redistribution of connected or static routes into EIGRP, the metric will be computed automatically using the metric of egress interface. I have found this simply by experimenting. I remember noticing that even though I did not specify the seed metric, the static and connected routes always got redistributed, and after a couple of experiments and paying close attention to the metrics of redistributed routes, I have come to this conclusion.
Best regards,
Peter
I hate to say it, but while you should not require a metric for redistributed statics, i've taught at networkers for the past dozen years that you should only leave the metric off if you don't care whether it works or not. It's quite buggy deriving the metric and it always just works if you define it. Why leave it off? What value is there in leaving it off.
Also did you ever supply the output of show ip route on the static. I didn't see it. Which interface do you reach the next hop through? Is it a recursive route?
I know this is an old post and all, but this one comment of yours saved me while troubleshooting some old IOS issues today. Thank you!
The statics were NOT being distributed, I was starting to suspect VRFs being the culprits, but then I read this and just tried configuring the default metrics.
Voila!
no the red subnet is shown in the routing table but it's not advertised .. that the main route that i need to advertise the other routes is not important for me ..
the other side is not a stub i think it's normal eigrp and reditibution working great from the other side ..
to marwan
i read before the metric issue and it should be written but from the practical side i did that and it doesn't differ and in the other branch the redistiburion is working great without the metric commnd
also the no auto-summary is the default option in this ios that's why it doesn't appear hear ..
i need to know the command to see the advertised routes from eigrp from my router
" debup ip eigrp "or their is another commands coz that's the first time for me to troubleshoot using debug in eigrp
or their is another comand
I'd start looking into 'sh ip eigrp topology'
deb ip routing
HTH,
Ivan.
Youssef,
Check the "show ip eigrp topology
In the advertising router you must see the route as being redistributed (via Redistributed)
In the received router you must see this route as being received from its neighbors (via next hop)
Then check which of the received routes will get into the routing table and why?
And static routes doesnot need a metric to be redistributed into EIGRP as it would take interface's parameters just like connected routes.
