Home lab unable to ping PC and laptop either side of a router
kimoak75
I am having a strange issue.  Strange because I have set this lab up at my colleges network and had no problems.  Packet tracer also is ok... I'm starting to think that there is a problem with the router.
Topology screenshot attached
Basically I have PC-A Connected to a 2960 Switch
Switch connected to a 2811 Router
The 2800 Router connected to PC-B
So 2 end devices and 1 router with 1 switch.
IP addresses have been configured to the ports on the router.
Switch is clean.
Local Firewalls off both PC's
I can ping from router to both PC's and the other way
Both PC's ping to interfaces directly.(But not interface other side)
Router Ip info below...
Router#show ip interface brief
FastEthernet0/0 192.168.0.1 YES manual up up
FastEthernet0/1 192.168.1.1 YES manual up up
Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.0.0/24 is directly connected, FastEthernet0/0
L 192.168.0.1/32 is directly connected, FastEthernet0/0
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, FastEthernet0/1
L 192.168.1.1/32 is directly connected, FastEthernet0/1
Show run command
Router#show run
Building configuration...
Current configuration : 966 bytes
! Last configuration change at 22:51:49 UTC Sat Mar 23 2019
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1441AJJP
redundancy
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Hopefully I am doing something really stupid.
Simon
21 Replies 21
Thanks for the reply, Deepak
I will test this out as soon as I get home.
Simon
Fantastic!  We are golden now!  That worked like a charm!
Many thanks for everyones help!  Very VERY much appreciated!
Thank you for the update. I am glad to know that our suggestions did point you toward the solution. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful content. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Rick
is your 'real' router a 2811 as well ? What happens if you take the switch out of the topology and connect both PCs directly to the router ?
Sorry I missed this reply. :(
Yes, the router is the same one.  I also have just bought a 2821 which is what I am working on right now.  I have tested without the switch with the same results.
Deepak Kumar
Please attach your topology (PT file).
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
luis_cordova
Hi @kimoak75 ,
I insist that the problem can be the firewall of some PC or some rule of the firewall. I suggest you check this.
