how to reset a QoS counter?
Support Albakom
Level 3
Level 3
With the command "sh policy-map interface <interface-name> I've got a list of the matched packets and bytes of my configured QoS class maps and so on. How I can reset these counters to zero? A clear counters doesn't help.
IOS is 12.4(13r)T at Cisco 2821.
royalblues
Level 10
Level 10
Clear counters should reset the MQC counters.
Is it possible that the counters that you are seeing are valid QoS counters beacuse of the traffic u see at the interface.
attached is an output from a 3825
MS_MIL_MET_R02#sh policy-map interface g 0/1
GigabitEthernet0/1
Service-policy output: WAN-parent-policy
Class-map: class-default (match-any)
15566531 packets, 5973079397 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
45000000/45000000 281250 1125000 1125000 25 140625
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 15565877 1677201992 29844 22988691 no
Service-policy : WAN-Metro
Class-map: VOICE (match-all)
387050 packets, 68922574 bytes
Match: ip dscp ef (46)
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 20 (%)
Bandwidth 9000 (kbps) Burst 225000 (Bytes)
(pkts matched/bytes matched) 2140/235380
(total drops/bytes drops) 0/0
15179481 packets, 5904156823 bytes
Match: any
MS_MIL_MET_R02#clear cou
MS_MIL_MET_R02#clear counters
Clear "show interface" counters on all interfaces [confirm]
MS_MIL_MET_R02#
GigabitEthernet0/1
0 packets, 0 bytes
Match: any
Traffic Shaping
- 0 0 0 0 0 no
0 packets, 0 bytes
Queueing
Strict Priority
Bandwidth 20 (%)
(pkts matched/bytes matched) 0/0
0 packets, 0 bytes
Match: any
MS_MIL_MET_R02#
Narayan
