HSRP
ashz14387
Hi @All
I made a demo HSRP lab with the below setup:
R1 connected to Switchport E0
R2 connected to Switchport E1
VPC connected to Switchport E2
R1 connected to a tap interface tap1 (192.176.1.1)
R2 connected to a tap interface tap2 (168.172.1.1)
Conf of R1 as follow,
! Last configuration change at 10:45:29 UTC Thu Mar 7 2024
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
username admin password 0 Network@123
ip tcp synwait-time 5
track 1 interface FastEthernet0/0 line-protocol
ip address 192.176.1.2 255.255.255.0
ip nat outside
duplex full
interface FastEthernet1/0
ip address 10.10.10.2 255.255.255.0
ip nat inside
standby 1 ip 10.10.10.1
standby 1 priority 150
standby 1 preempt delay minimum 20
standby 1 track 1 decrement 60
duplex full
interface FastEthernet2/0
no ip address
shutdown
duplex full
interface FastEthernet3/0
no ip address
shutdown
duplex full
interface FastEthernet4/0
no ip address
shutdown
duplex full
interface FastEthernet5/0
no ip address
shutdown
duplex full
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static 10.10.10.5 192.176.1.2
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.176.1.1
access-list 1 permit 10.10.10.0 0.0.0.255
snmp-server community privat RW
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
password Network@123
login local
transport input telnet
end
Conf of R2 as follow,
! Last configuration change at 07:55:09 UTC Thu Mar 7 2024
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 168.172.1.2 255.255.255.0
ip nat outside
duplex full
ip address 10.10.10.3 255.255.255.0
ip nat inside
standby 1 priority 110
standby 1 preempt
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
ip nat inside source static 10.10.10.5 168.172.1.2
no ip http server
ip route 0.0.0.0 0.0.0.0 168.172.1.1
ip route 10.10.10.0 255.255.255.0 168.172.1.1
snmp-server community private RW
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
end
HSRP is working fine when i tried trace with R1 present and Without R1 Present.
My question is i am unable to ping 8.8.8.8 from the r1 and r2 but able to do that from vpc why?
Torbjørn
I suspect that this is a NAT issue. Are you trying to ping from your "inside" interface of your router?
Could you try to remove the following line of configuration and try again?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
nict
Hi @ashz14387
Just so I understand:
So your Router is Connected to a switch, and behind that switch is your VPC, correct?
What is the IP address of the VPC?
The ip address of VPC is 10.10.10.5 with default gateway of 10.10.10.1
That makes sense why it works then for the VPC. See what Torbjørn wrote in his reply about the ip nat inside source static.
Torbjørn
