Inter VLAN Routing Non-Operational?
NicP270591
Hi all,
I have set up a 2811 with seperate VLANs for phones, and another for computers/printers. Fa0/0 is trunked to a 3560 switch, which has all end devices plugged in. I have enabled the IP Routing commands on both devices, and from advice turned off proxy-arp on the VLANs on the router (unsure if this is causing the issue). The setup is as follows
Computer VLAN = 192.168.20.0
Phone VLAN = 192.168.50.0
Both on the same subnet, along with a router loopback address in the same subnet, at 192.168.10.1.
I am having an issue understanding why, but if I try to ping a phone from a PC it times out. Or if I try to type the phone's IP into an internet browser to get the phone's GUI on screen, it fails. This should not be happening as IP routing has been enabled on both, and everything is in the same subnet, correct? PC's can ping other PC's and network printing works fine. Phones register and operate fine, but the two VLAN's will not interoute.
Furthermore if I try and ping the router's loopback from the switch, it fails. But the trunk is up and operational because DHCP and devices work within their own VLAN. If I try to ping end devices from the switch, it returns 100%. There seems to be an issue with the router looping the different networks together.
What am I missing here?
Nic.
35 Replies 35
Raju Sekharan
You have mentiond that your PC and Phone VLAN are using same subnet.
If you need to have routing, both needs to be in different subnets
Raju
kcnajaf
Level 7
Level 7
HiNic,
Could you confirm what are the ip address you are using on phone and PC? Also the switch port configuration for these two devices would be ideal to see.
Najaf
Please rate when applicable or helpful !!!
Hi Raju,
The computer currently has an IP of 192.102.20.2. The Phone beside me is currently on 192.102.50.4. No problems there.
Config requested as per below:
no aaa new-model
vtp domain aume-campus
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 20
name VLAN-20-LAN
vlan 50
name VLAN-50-VOICE
interface FastEthernet0/1
switchport access vlan 20
switchport mode access
switchport voice vlan 50
spanning-tree portfast
(Port with BOTH phone and PC)
interface FastEthernet0/8
(Port with a PC only)
interface FastEthernet0/48
switchport trunk native vlan 12
switchport trunk allowed vlan 12,20-22,30,40,41,50,51,60,99
switchport mode trunk
(Trunk to 2811 FE0/0)
interface Vlan20
ip address 192.102.20.20 255.255.255.192
interface Vlan50
ip address 192.102.50.50 255.255.255.192
(Tried these vlan IP's just to make sure)
ip classless
ip http server
ip http secure-server
control-plane
line con 0
end
Hi Nic,
Switch configuration seemsto be ok,postr routerconfiguration.
On the switch config there are a lot of Vlans configured on the trunk. Are there subnets associated with those? You are showing pieces of code for the devices so its a little hard to tell. Is it possible that one of those other vlans/subnets has an address overlap with your phone vlan?
Praveen AR
Hi Nic,
Could you post router configuration ,router on stick configuration.
Praveen
Hi Praveen,
Please see below. Also, note switch config above if that helps.
no ip dhcp use vrf connected
ip dhcp excluded-address 192.102.50.50 192.102.50.55
ip dhcp excluded-address 192.102.20.20 192.102.20.40
ip dhcp excluded-address 192.102.99.1 192.102.99.10
ip dhcp excluded-address 192.102.10.1 192.102.10.10
ip routing
ip dhcp pool VLAN-20-LAN
   network 192.102.20.0 255.255.255.192
   default-router 192.102.20.1
   lease 7
ip dhcp pool VLAN-50-VOICE
   network 192.102.50.0 255.255.255.192
   default-router 192.102.50.1
   option 150 ip 192.102.10.1
   lease 7
interface Loopback0
ip address 192.102.10.1 255.255.255.192
interface FastEthernet0/0
no ip address
no ip redirects
ip flow ingress
duplex full
speed 100
no cdp enable
interface FastEthernet0/0.20
description VLAN-20-LAN
encapsulation dot1Q 20
ip address 192.102.20.1 255.255.255.192
no ip redirects
no ip proxy-arp
ip flow ingress
interface FastEthernet0/0.50
description VLAN-50-VOICE
encapsulation dot1Q 50
ip address 192.102.50.1 255.255.255.192
no ip redirects
no ip proxy-arp
ip flow ingress
no ip redirects
no ip proxy-arp
ip flow ingress
ip forward-protocol nd
ip http server
ip http authentication local
logging esm config
no cdp run
line con0
end
Hi Nic,
Problem i found in your configuration is that you have given native vlan as 12  in your switch configuration and no router configuration for native vlan.Could you plese add one more sub interface as below
interface FastEthernet0/0.12
encapsulation dot1q 12 native
Ip addres .....(give any ip address in your native vlan range)
or
remove native  vlan 12 from switch means native vlan 1 by default.
and create below subinterface in router
encapsulation dot1q 1 native
Ip addres .....(give any ip address in your native vlan  1 range)
Hope it should work
Praveen
Hi Nic,
Please let me know if it helps to solve your problem
Praveen
Hi Praveen,
Thank you for pointing that out! It has, however not solved the problem, I added VLAN 12 native to the router config but cannot ping my phone from a PC, etc. Any ideas?
Nic.
Hi Nic,
No worries ,  we can solve it.
I want you  to do some testing from your side.
create  interface vlan 12 ( for native vlan) on switch.
  give  ip address.
Afterwards from switch
Ping 192.102.20.1
ping  192.102.50.1
and
ping new ip you gave for native vlan sub interface.
If ping results are fine, no issues with trunk.
Please do ping's and let me know
Praveen
Hi Nic,
Have you created vlan 12 on switch ,I think it is missing in your configuration.
Praveen
Hi Praveen,
I have completed the above and pinged from the switch. Pings to the 20.1, 50.1 and now the 12.1 network are successful.
I still cannot get to the IP Phone GUI from a net browser, or ping anything from the PC if it is not on the 20 network.
Nic.
Hi Nic
Now you need to test same from any PC.
Ping  192.102.20.1
         192.102.50.1
         192.102.12.1
If these work, try ping any of the phone ip
I think you are running CME,you can get ip of phones from cme.
Try ping  phone ip once you tested above from pc.
Let me know results
Try shut no shut  ethernet router inferace.
Please paste your updated router configuration
