01-12-2013 08:34 PM - edited 03-04-2019 06:41 PM
Hi all,
I have set up a 2811 with seperate VLANs for phones, and another for computers/printers. Fa0/0 is trunked to a 3560 switch, which has all end devices plugged in. I have enabled the IP Routing commands on both devices, and from advice turned off proxy-arp on the VLANs on the router (unsure if this is causing the issue). The setup is as follows
Computer VLAN = 192.168.20.0
Phone VLAN = 192.168.50.0
Both on the same subnet, along with a router loopback address in the same subnet, at 192.168.10.1.
I am having an issue understanding why, but if I try to ping a phone from a PC it times out. Or if I try to type the phone's IP into an internet browser to get the phone's GUI on screen, it fails. This should not be happening as IP routing has been enabled on both, and everything is in the same subnet, correct? PC's can ping other PC's and network printing works fine. Phones register and operate fine, but the two VLAN's will not interoute.
Furthermore if I try and ping the router's loopback from the switch, it fails. But the trunk is up and operational because DHCP and devices work within their own VLAN. If I try to ping end devices from the switch, it returns 100%. There seems to be an issue with the router looping the different networks together.
What am I missing here?
Nic.
01-13-2013 02:31 AM
Praveen,
I have tested from PC, all pings fail except the 192.102.20.1 network (because it is the same as the computer VLAN). I am running CME yes. I have obtained and IP of a phone through the settings menu on the phone, the IP is 192.102.50.4. Pinging from a PC to this address also times out. Shut and no shut were tried on both the router ethernet 0/0 and the switch ethernet 0/48, and this did not have any affect. Updated part of the router config for the native VLAN is as below:
interface FastEthernet0/0.12
description VLAN-12-NATIVE,OPQ4022ISW01
encapsulation dot1Q 12 native
ip address 192.102.12.1 255.255.255.192
no cdp enable
Thank you,
Nic.
01-13-2013 02:43 AM
Hi Nic,
Can you connect any pc in voice vlan and ping from that pc all router iinterfaces as you tested before for Computer VLAN.
Can you disable ip routing on switch , you dont need to enable routing on switch .In your scenario routing is done by router.
send me below output
SWITCH
sh int trunk
sh vlan bruef
Router
sh ip int brief
01-14-2013 03:33 AM
Hi Praveen,
Please see below output. Also note, I connected a PC into a spare port on the switch which I configured to access the voice VLAN as requested. Successful pings on the Voice VLAN from PC, 100% to all devices - 192.102.50.1, 192.102.50.4, 192.102.20.1, 192.102.20.25 and 192.102.50.12.1 - no problems there! If the PC is in the voice VLAN I can also type the phone IP into a browser and have the GUI come right up. Pings from the 20 network (proper PC VLAN) still do not work. I have also disabled IP Routing on the switch as per your request.
RTR:
sh ip int brief
FastEthernet0/0 unassigned YES NVRAM up up
FastEthernet0/0.10 unassigned YES unset deleted down
FastEthernet0/0.11 unassigned YES manual deleted down
FastEthernet0/0.12 192.102.12.1 YES manual up up
FastEthernet0/0.20 192.102.20.1 YES NVRAM up up
FastEthernet0/0.21 192.102.21.1 YES NVRAM up up
FastEthernet0/0.22 192.102.22.1 YES NVRAM up up
FastEthernet0/0.30 unassigned YES unset administratively down down
FastEthernet0/0.40 192.102.40.1 YES NVRAM up up
FastEthernet0/0.41 192.102.41.1 YES NVRAM administratively down down
FastEthernet0/0.50 192.102.50.1 YES NVRAM up up
FastEthernet0/0.51 192.102.51.1 YES NVRAM up up
FastEthernet0/0.99 192.102.99.1 YES manual up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/2/0 unassigned YES NVRAM administratively down down
ATM0/2/0.1 unassigned YES unset administratively down down
Service-Engine1/0 unassigned YES NVRAM administratively down down
Dialer1 unassigned YES NVRAM up up
Loopback0 192.102.10.1 YES manual up up
NVI0 192.102.10.1 YES unset up up
SWITCH
sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0/47 on 802.1q trunking 1
Fa0/48 on 802.1q trunking 12
Port Vlans allowed on trunk
Fa0/47 21-22,40-41,51
Fa0/48 12,20-22,30,40-41,50-51,60,99
Port Vlans allowed and active in management domain
Fa0/48 12,20-22,30,40-41,50-51,99
Port Vlans in spanning tree forwarding state and not pruned
sh vlan brief
VLAN Name Status Ports
1 default active Fa0/4, Fa0/5, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24, Fa0/25, Fa0/26
Fa0/27, Fa0/28, Fa0/29, Fa0/30
Fa0/31, Fa0/32, Fa0/33, Fa0/34
Fa0/35, Fa0/36, Fa0/37, Fa0/38
Fa0/39, Fa0/40, Fa0/41, Fa0/42
Fa0/43, Fa0/44, Fa0/46, Gi0/1
Gi0/2, Gi0/3, Gi0/4
12 VLAN-12-NATIVE active
20 VLAN-20-LAN active Fa0/1, Fa0/2, Fa0/3, Fa0/6
Fa0/7, Fa0/8, Fa0/45
21 VLAN-21-WLAN active
22 VLAN-22-GUEST-WLAN active
30 VLAN-30-WAN active
40 VLAN-40-PRINT-WLAN active
41 VLAN-41-PDT-WLAN active
50 VLAN-50-VOICE active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7
51 WLAN-51-VOICE active
99 VLAN-99-NETMGT active
101 aume-ue-101 active
701 aume-ve-701 active
999 Management_Vlan active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
01-14-2013 07:15 AM
Hi Nica,
When you tried connecting pc in voice lan ,Did you try to ping any pc in data vlan.
I suggest you to restart he router or make default int fa0/0
and do interface configuration in router from scratch and try.
Pleas let me know it works or not
Praveen
01-13-2013 03:07 AM
Hi Nic,
You need to ensure that the CDP is enabled on the switch. Once CDP is enabled on switch, it will tell the ip phone about the voice vlan. You should be able see this by checking the operation vlan id on the phone screen. The operation vlan id should be the voice vlan. If some reason the operational vlan id is not showing up, you can configure the Admin Vlan id as the voice vlan manually.
Also hope you have configured as below on the ip phone.
IP Address:-192.102.50.4
Subnet Mask:-255.255.255.192
Gateway :- 192.102.50.1
For some reason I can see same interface repeated twice surprisingly as below :-)
interface FastEthernet0/0.50
description VLAN-50-VOICE
encapsulation dot1Q 50
ip address 192.102.50.1 255.255.255.192
no ip redirects
no ip proxy-arp
ip flow ingress
no ip redirects
no ip proxy-arp
ip flow ingress
Shutdown one of the sub interface if you have multiple interface showing up on the configuration.
Also when above points are corrected try pining the ip phone address and pc address from the router and verify if that works first before you try pinging from phone from PC.
Najaf
Please rate when applicable or helpful !!!
01-13-2013 05:47 AM
Remove this line from the router too:
duplex full
as it's auto on the switch side
01-14-2013 03:37 AM
Peter,
I have also switched the duplex from full to auto.
Nic.
01-14-2013 03:36 AM
Hi Najaf,
I don't think I need to enable CDP as the IP phone is already displaying correct IP, gateway subnet mask and operational VLAN ID 50 as you described. Should I enable it anyway? I originally had it off as a security measure. That extra duplicate interface does not exist on the router, it seems to be an error from when I was pasting my config into the reply. Pinging the IP Phone and PC address (and any other address) from the router works fine! I'm assuming we have an issue with the switch if this is the case? Thanks for all your help.
Nic.
01-14-2013 08:13 AM
Hi Nic,
I hope you have statically configured the ip address and other parameters on the phone. If your phone was suppose to pick an ip address from dhcp pool the you need to ensure the cdp is enabled on the switch.
show interface trunk still shows native vlan as 12, Please remove this line from trunk port configuration (as below) on switch and from router sub interface if it have it.
interface FastEthernet0/48
no switchport trunk native vlan 12
Najaf
01-19-2013 01:30 AM
Hi Najaf,
I have enabled cdp on both the router and switch using the cdp run command in global, and cdp run command on fa0/0 and all fa0/0 sub interfaces. I have also deleted vlan 12 subif from router and vlan 12 from switch. still no go. pings to every network are successful if I put a computer in the phone VLAN, but trying to ping devices from a computer in the data vlan still fails, unless the device has an ip address from the 20 network.
Nic.
01-19-2013 03:30 AM
Hello Nic,
If applicable can you do this on the switch:
1) remove the SVI vlan 50
2) disable ip routing
3) add default-gateway 192.102.20.1
res
Paul
01-19-2013 09:21 PM
Paul,
These changes have not made any difference. Should I just post my entire configuration of both switch and router to see if anyone can spot anything?
Nic.
01-19-2013 09:28 PM
Hi Nic,
Yes please...Also please mention which port what device is connected along with ip address
Thanks in advance
Najaf
01-20-2013 01:11 AM
Hello Nic
Yes can you do that, As i have just simulated your setup with the information you supplied and those changes and everything works..
res
Paul
01-20-2013 06:21 AM
You should reenable cdp from the router to the switch if your IP phones are cisco brand. If they are avaya or some other vender you should use lldp run. If your concerned about security then you can simply disable cdp/lldp on ports that it is not needed. Cdp/lldp should be enabled on all ip phone ports. cdp will help set qos policies and pass other needed information to your phones.
-Toby
Sent from Cisco Technical Support Android App
