IOS 12.4(T) support BGP ??
anjaneesh
I had a Cisco 2811 router whose ios image is ios 12.4(T) with advanced security. This image doesn't support BGP.
error message it gives when I m trying to configure BGP is::
Protocol not in this ios image.
williamwbishop
BGP is supported on both older hardware and older ios versions. Most likely the image you have applied just doesn't support bgp. You will need an image that does. If you will post your show ver we will know more about what your ios version supports.
anjaneesh
This is the show version output
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
ghaziabad uptime is 23 minutes
System restarted at 09:51:49 UTC Mon Aug 22 2005
System image file is "flash:c2800nm-advsecurityk9-mz.124-1a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found
at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK0931F01W
2 FastEthernet interfaces
6 Serial(sync/async) interfaces
4 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Hi anjaneesh,
Sorry to say the code you are running does not support BGP. It do support EIGRP, OSPF, RIp but not BGP.
Check this link
Open this link first
1) http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Then click on
2) Search by Software/Image Name/Product Code/Platform
Then enter your full image name under section Image Name
and serach it will give u 3 optiosn for router and selct your router and it will show you the features it supports and it doe snot support BGP.
Ankur
anjaneesh
Thankx Ankur
That solved my problem.
