- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-11-2016 01:24 AM - edited 03-05-2019 07:27 AM
How to enable the IP accounting in ISR4321/K9.
Uptime for this control processor is 1 year, 2 weeks, 5 days, 19 hours, 27 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx appxk9 Permanent appxk9
uc None None None
security securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1687137K/6147K bytes of memory.
Processor board ID FDO1936A04T
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
Deepak
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2016 03:13 AM
Hi Deepak
You cant that command was removed in ios-xe , its not available in any of the 4000 series routers
You would need to use netflow instead
there were bugs even saying it shouldn't be there
Cisco Bug: CSCtx97298 - Remove unsupported CLI "show ip accounting"
Last Modified
Product
Known Affected Releases
Description (partial)
Symptom: As of IOS-XE 3.4.1S, the following CLI is still available: show ip accounting and this is misleading. Conditions: NA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-11-2016 03:13 AM
Hi Deepak
Last Modified
Product
