ISDN BRI Backup
Afragoso2009
Does any body are already configure a ISDN BRI Interface as backup line for Serial connection?
I have two site that must be connect with ISDN BRI whe the main serial ling goes down.
Does any bony have a example ?
24 Replies 24
Giuseppe Larosa
Hello Antonio,
have a look here:
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_backup_serial_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001021
Note:
define interesting traffic carefully to avoid to pay high fees
don't use simple permit ip for the dialer list
Hope to help
Giuseppe
I had congifure the remote site
but I am seeing that its not dialing when I put the serial line down even the interface dialer goes up
I ahve the following configuration on the remote router
interface Serial0/0/0
ip address 192.168.253.14 255.255.255.252
ip accounting output-packets
ip accounting precedence input
ip accounting precedence output
ip nbar protocol-discovery
interface BRI0/1/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
interface Dialer1
no ip address
encapsulation ppp
dialer pool 1
dialer string 2601424
dialer string 2601425
dialer-group 1
ppp authentication chap
Hello Antonio,
your Dialer1 interface should have an ip address: a backup link is still an IP link
it is not possible to route ip traffic over an interface where IP is disabled
in this context you can assign a private ip subnet to the DDR service and you can give static ip addresses to the two sites.
Hope to help
Giuseppe
and make sure you set the admin distance of the static route to 200, otherwise everything will go across you dialer, causing a high telephone bill!
so ip route 0.0.0.0 0.0.0.0 dialer 1 200 (for instance)
Please remember to rate useful posts, by clicking on the stars below.
Hi everybody
I add an IP address to the dialer interface.
But when I put the main serial down the dialing its not happennig :
*Jun 30 16:48:33.693: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.253.1
3 (Serial0/0/0) is down: holding time expired
*Jun 30 16:48:55.393: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
0, changed state to down
*Jun 30 16:48:55.397: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to dow
n
*Jun 30 16:48:55.397: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to dow
n
*Jun 30 16:48:55.449: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
RT_AGN_ASA#
RT_AGN_ASA#
RT_AGN_ASA#
*Jun 30 16:51:35.393: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
*Jun 30 16:51:35.453: %LINK-5-CHANGED: Interface BRI0/1/0, changed state to stan
dby mode
*Jun 30 16:51:35.453: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to dow
n
*Jun 30 16:51:35.453: %LINK-3-UPDOWN: Interface BRI0/1/0:2, changed state to dow
n
*Jun 30 16:51:35.797: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.253.1
3 (Serial0/0/0) is up: new adjacency
Did you add the static route ?
Have you verifyed the ISDN switch type with the carrier ?
Hi below is the config...
End - A :
interface BRI0/1/0
no ip address
encapsulation ppp
interface Dialer1
ip address 10.10.10.1 255.255.255.252
encapsulation ppp
dialer pool 1
dialer caller 2601424
dialer caller 2601425
dialer-group 1
ip route 0.0.0.0 0.0.0.0 192.168.253.15
ip route 0.0.0.0 0.0.0.0 10.10.10.2 200
End - B config :
ip address 192.168.253.15 255.255.255.252
back-up interface bri 0/1/0
interface BRI0/1/0
no ip address
encapsulation ppp
interface Dialer1
ip address 10.10.10.2 255.255.255.252
encapsulation ppp
dialer pool 1
dialer-group 1
ip route 0.0.0.0 0.0.0.0 192.168.253.14
ip route 0.0.0.0 0.0.0.0 10.10.10.1 200
check with your provider about switch type which needs to configures on bri interface.
Satish
Hi Smot
Thanks for your help . I put the configuration you sugest but my BRI (End - B config ) its still no dialing whe the Serial goes down
Just to confirm , my switch type is net3
sounds like your dial string isn't correct. Is this a local call ? which country
see the info on the stuff below, Its pretty helpful:
http://www.cisco.com/en/US/docs/ios/12_1/debug/command/reference/dbdipx.html#wp1017611
Here is a list of supported switch types, Ididn't see yours.
http://www.cisco.com/en/US/docs/ios/12_2t/debug/command/reference/dbftisdn.html
Can you actually make a call over the BRI? Forget the config for the moment and use an interactive command to test. Turn on debug q931 and term mon (Or log con) then issue this command...
isdn test call int b0/1/0 xxxxxxxxxx
xxxxxxxxxx = the number you are trying to call.
View the debug output to confirm its even trying to call.
hello,
i think you better first manually test the isdn service before test the backup function.
- under bri interface, you need ppp authentication too.
- you need to send chap username password in dialer interface.
- you need local user database to authenticate remote device.
your floating static would be better this way:
ip route 10.10.10.1 255.255.255.255 dialer1
also, please provide sh isdn service and debug isdn q931 when dialing. Preferably in attachment.
Hi team
This is the result off my isdn call teste
*Jul 2 10:40:28.387: ISDN BR0/1/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inact
ive
*Jul 2 10:40:36.387: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jul 2 10:40:36.387: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Call rejected
cause Temporary failure(0x29) call id 0x8004
hello,
we need "sh isdn service" and full debug of "debug isdn q931" from start.
You do have layer 1 and 2 right? Post the output from the "show isdn status" command please.
