ISDN issue only on inbound
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-10-2010 09:56 AM - edited 03-04-2019 10:25 AM
Hi all,
I'm a bit lost with an issue on ISDN interfaces...
I'm using ISDN for satellite needs and I'm facing a strange issue on one vessel. Let me explain the case :
- From the vessel to the HQ ISDN concentrator : everything is OK (here is the debug isdn q931) :
RTLIBERTY-204INMARSAT#ping 172.16.22.185 repeat 30
Sending 30, 100-byte ICMP Echos to 172.16.22.185, timeout is 2 seconds:
*May 22 20:56:03.531: ISDN BR0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 0033496110959#
*May 22 20:56:03.535: ISDN BR0 Q931: TX -> SETUP pd = 8 callref = 0x06
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '0033496110959#'
Plan:Unknown, Type:Unknown
*May 22 20:56:03.591: ISDN BR0 Q931: RX <- CALL_PROC pd = 8 callref = 0x86
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8481 - Call not end-to-end ISDN, may have in-band info ..
*May 22 20:56:07.023: %SEC-6-IPACCESSLOGDP: list 110 permitted icmp 172.16.22.150 -> 172.16.22.185 (8/0), 2 packets ...
*May 22 20:56:13.475: ISDN BR0 Q931: RX <- CONNECT pd = 8 callref = 0x86
*May 22 20:56:13.479: %DIALER-6-BIND: Interface BR0:1 bound to profile Di0
*May 22 20:56:13.479: ISDN BR0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x06..
*May 22 20:56:17.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to up!!!!!!!!!!!!!!!!!!!!!!!
Success rate is 76 percent (23/30), round-trip min/avg/max = 864/866/872 ms
*May 22 20:56:48.603: ISDN BR0 Q931: RX <- DISCONNECT pd = 8 callref = 0x86
Cause i = 0x8490 - Normal call clearing
*May 22 20:56:48.607: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di0
*May 22 20:56:48.611: ISDN BR0 Q931: TX -> RELEASE pd = 8 callref = 0x06
Cause i = 0x8090 - Normal call clearing
*May 22 20:56:48.651: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x86
*May 22 20:56:49.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to down
- From the HQ ISDN concentrator to the vessel to : nothing is working... I give you a quite detailed debug (debug isdn q921, debug isdn q931, debug dialer and debug ppp authentication) from both sides :
- From the Vessel :
RTLIBERTY-204INMARSAT#show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
*May 22 21:14:09.939: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=12
*May 22 21:14:09.951: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=20
*May 22 21:14:13.059: ISDN BR0 Q921: User RX <- UI sapi=0 tei=127
*May 22 21:14:13.059: ISDN BR0 Q931: SETUP pd = 8 callref = 0x40
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Called Party Number i = 0x80, '600971578'
*May 22 21:14:13.063: BR0:1: interface must be fifo queue, force fifo
*May 22 21:14:13.067: %DIALER-6-BIND: Interface BR0:1 bound to profile Di0
*May 22 21:14:13.067: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=20 nr=12
*May 22 21:14:13.071: ISDN BR0 Q931: CALL_PROC pd = 8 callref = 0xC0
Channel ID i = 0x89
Exclusive, B1
*May 22 21:14:13.071: BR0:1 PPP: Using dialer call direction
*May 22 21:14:13.071: BR0:1 PPP: Treating connection as a callin
*May 22 21:14:13.071: BR0:1 PPP: Session handle[18000025] Session id[26]
*May 22 21:14:13.083: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=69
*May 22 21:14:13.095: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=21
*May 22 21:14:13.099: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=21 nr=12
*May 22 21:14:13.099: ISDN BR0 Q931: CONNECT pd = 8 callref = 0xC0
*May 22 21:14:13.099: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=70
*May 22 21:14:13.119: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=64, ns=12 nr=21
*May 22 21:14:13.119: ISDN BR0 Q931: RELEASE pd = 8 callref = 0x40
Cause i = 0x849A - Non-selected user clearing
*May 22 21:14:13.119: ISDN BR0 Q921: User TX -> RR sapi=0 tei=64 nr=13
*May 22 21:14:13.123: BR0 DDR: has total 0 call(s), dial_out 0, dial_in 0
*May 22 21:14:13.123: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di0
*May 22 21:14:13.127: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=62 nr=70
*May 22 21:14:13.127: ISDN BR0 Q931: CONNECT_ACK pd = 8 callref = 0x40
*May 22 21:14:13.127: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=22
*May 22 21:14:13.127: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=22 nr=13
*May 22 21:14:13.131: ISDN BR0 Q931: RELEASE_COMP pd = 8 callref = 0xC0
*May 22 21:14:13.139: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=64, ns=13 nr=22
*May 22 21:14:13.139: ISDN BR0 Q931: STATUS pd = 8 callref = 0x40
Cause i = 0x84E5 - Message not compatible with call state
Call State i = 0x13
*May 22 21:14:13.143: ISDN BR0 Q921: User TX -> RR sapi=0 tei=64 nr=14
*May 22 21:14:13.143: ISDN BR0 **ERROR**: L3_BadPeerMsg: event 0x7D cr 0xC0 callid 0x0
*May 22 21:14:13.151: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=23
*May 22 21:14:13.155: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=23 nr=14
*May 22 21:14:13.155: ISDN BR0 Q931: RELEASE pd = 8 callref = 0xC0
Cause i = 0x80E5 - Message not compatible with call state
*May 22 21:14:13.171: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=24
*May 22 21:14:17.571: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=63 nr=70
*May 22 21:14:17.571: ISDN BR0 Q931: DISCONNECT pd = 8 callref = 0x40
*May 22 21:14:17.595: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=71
*May 22 21:14:17.603: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=64 nr=71
*May 22 21:14:17.603: ISDN BR0 Q931: RELEASE_COMP pd = 8 callref = 0x40
*May 22 21:14:23.171: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=14
*May 22 21:14:23.183: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=24
*May 22 21:14:27.487: ISDN BR0 Q921: User RX <- UI sapi=0 tei=127
*May 22 21:14:27.487: ISDN BR0 Q931: SETUP pd = 8 callref = 0x40
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
*May 22 21:14:27.491: BR0:1: interface must be fifo queue, force fifo
*May 22 21:14:27.491: %DIALER-6-BIND: Interface BR0:1 bound to profile Di0
*May 22 21:14:27.495: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=24 nr=14
*May 22 21:14:27.495: ISDN BR0 Q931: CALL_PROC pd = 8 callref = 0xC0
Channel ID i = 0x89
Exclusive, B1
*May 22 21:14:27.499: BR0:1 PPP: Using dialer call direction
*May 22 21:14:27.499: BR0:1 PPP: Treating connection as a callin
*May 22 21:14:27.499: BR0:1 PPP: Session handle[A9000026] Session id[27]
*May 22 21:14:27.511: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=72
*May 22 21:14:27.523: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=25
*May 22 21:14:27.523: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=25 nr=14
*May 22 21:14:27.523: ISDN BR0 Q931: CONNECT pd = 8 callref = 0xC0
*May 22 21:14:27.527: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=73
*May 22 21:14:27.547: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=64, ns=14 nr=25
*May 22 21:14:27.547: ISDN BR0 Q931: RELEASE pd = 8 callref = 0x40
*May 22 21:14:27.547: ISDN BR0 Q921: User TX -> RR sapi=0 tei=64 nr=15
*May 22 21:14:27.551: BR0 DDR: has total 0 call(s), dial_out 0, dial_in 0
*May 22 21:14:27.551: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di0
*May 22 21:14:27.551: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=65 nr=73
*May 22 21:14:27.551: ISDN BR0 Q931: CONNECT_ACK pd = 8 callref = 0x40
*May 22 21:14:27.555: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=26
*May 22 21:14:27.555: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=26 nr=15
*May 22 21:14:27.555: ISDN BR0 Q931: RELEASE_COMP pd = 8 callref = 0xC0
*May 22 21:14:27.567: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=64, ns=15 nr=26
*May 22 21:14:27.567: ISDN BR0 Q931: STATUS pd = 8 callref = 0x40
Call State i = 0x13
*May 22 21:14:27.571: ISDN BR0 Q921: User TX -> RR sapi=0 tei=64 nr=16
*May 22 21:14:27.571: ISDN BR0 **ERROR**: L3_BadPeerMsg: event 0x7D cr 0xC0 callid 0x0
*May 22 21:14:27.579: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=27
*May 22 21:14:27.579: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=64, ns=27 nr=16
*May 22 21:14:27.579: ISDN BR0 Q931: RELEASE pd = 8 callref = 0xC0
*May 22 21:14:27.599: ISDN BR0 Q921: User RX <- RR sapi=0 tei=64 nr=28
*May 22 21:14:31.999: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=66 nr=73
*May 22 21:14:31.999: ISDN BR0 Q931: DISCONNECT pd = 8 callref = 0x40
*May 22 21:14:32.023: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=74
*May 22 21:14:32.027: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=67 nr=74
*May 22 21:14:32.027: ISDN BR0 Q931: RELEASE_COMP pd = 8 callref = 0x40
*May 22 21:14:37.599: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=64 nr=16
*May 22 21:14:37.611: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=64 nr=28
RTLIBERTY-204INMARSAT#ter no mon
*May 22 21:14:42.039: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=66 nr=74
- From the HQ ISDN Concentrator :
MA2811#
*Nov 10 18:07:12.171: ISDN BR0/1/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Nov 10 18:07:12.331: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 65 changed to up
*Nov 10 18:07:12.335: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x05
Standard = CCITT
Channel ID i = 0x81
Called Party Number i = 0x80, '00870600971578'
*Nov 10 18:07:12.475: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x85
Channel ID i = 0x89
*Nov 10 18:07:12.767: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x85
Channel ID i = 0x89
*Nov 10 18:07:19.063: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8 callref = 0x85
*Nov 10 18:07:19.375: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8 callref = 0x85
*Nov 10 18:07:19.379: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to up
*Nov 10 18:07:19.383: %DIALER-6-BIND: Interface BR0/1/0:1 bound to profile Di150
*Nov 10 18:07:19.383: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 00870600971578 N/A
*Nov 10 18:07:19.383: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x05
*Nov 10 18:07:22.667: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 00870600971578 bourbon-liberty204
*Nov 10 18:07:22.667: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from 00870600971578 bourbon-liberty204, call lasted 3 seconds
*Nov 10 18:07:22.671: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x05
*Nov 10 18:07:22.831: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x85
*Nov 10 18:07:22.835: %LINK-3-UPDOWN: Interface BRI0/1/0:1, changed state to down
*Nov 10 18:07:22.839: %DIALER-6-UNBIND: Interface BR0/1/0:1 unbound from profile Di150
*Nov 10 18:07:22.839: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x05
*Nov 10 18:07:22.855: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 00870600971578
*Nov 10 18:07:22.855: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x06
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:22.995: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x86
Channel ID i = 0x89
*Nov 10 18:07:23.275: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x86
Cause i = 0x8791 - User busy
*Nov 10 18:07:23.283: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x06
Cause i = 0x8091 - User busy
*Nov 10 18:07:23.303: ISDN BR0/3/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 00870600971578
*Nov 10 18:07:23.315: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/3/0, TEI 65 changed to up
*Nov 10 18:07:23.319: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8 callref = 0x07
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:23.363: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x86
*Nov 10 18:07:23.455: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x87
Channel ID i = 0x89
*Nov 10 18:07:23.459: ISDN BR0/3/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x87
Channel ID i = 0x89
*Nov 10 18:07:23.747: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x87
*Nov 10 18:07:23.747: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x87
*Nov 10 18:07:23.751: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8 callref = 0x07
*Nov 10 18:07:23.839: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x87
*Nov 10 18:07:23.839: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x87
*Nov 10 18:07:23.863: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 00870600971578
*Nov 10 18:07:23.875: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 64 changed to up
*Nov 10 18:07:23.879: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x08
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:24.031: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x88
Channel ID i = 0x89
*Nov 10 18:07:24.031: ISDN BR0/3/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x88
Channel ID i = 0x89
*Nov 10 18:07:24.327: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x88
*Nov 10 18:07:24.327: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x88
*Nov 10 18:07:24.339: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8 callref = 0x08
*Nov 10 18:07:24.407: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x88
*Nov 10 18:07:24.407: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x88
*Nov 10 18:07:24.423: ISDN BR0/3/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 00870600971578
*Nov 10 18:07:24.423: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8 callref = 0x09
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:24.559: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x89
Channel ID i = 0x89
*Nov 10 18:07:24.559: ISDN BR0/3/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x89
Channel ID i = 0x89
*Nov 10 18:07:24.863: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x89
*Nov 10 18:07:24.863: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x89
*Nov 10 18:07:24.867: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8 callref = 0x09
*Nov 10 18:07:24.875: ISDN BR0/2/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Nov 10 18:07:24.939: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x89
*Nov 10 18:07:24.939: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x89
*Nov 10 18:07:25.043: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/2/0, TEI 64 changed to up
*Nov 10 18:07:25.047: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x0A
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:25.171: ISDN BR0/2/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8A
Channel ID i = 0x89
*Nov 10 18:07:25.443: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x8A
*Nov 10 18:07:25.447: ISDN BR0/2/0 Q931: TX -> RELEASE pd = 8 callref = 0x0A
*Nov 10 18:07:25.515: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8A
*Nov 10 18:07:25.543: ISDN BR0/3/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 00870600971578
*Nov 10 18:07:25.543: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8 callref = 0x0B
Standard = CCITT
Channel ID i = 0x81
*Nov 10 18:07:25.679: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8B
Channel ID i = 0x89
*Nov 10 18:07:25.679: ISDN BR0/3/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8B
Channel ID i = 0x89
*Nov 10 18:07:25.975: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x8B
Channel ID i = 0x89
*Nov 10 18:07:25.979: ISDN BR0/3/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x8B
Channel ID i = 0x89
*Nov 10 18:07:27.279: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Nov 10 18:07:28.399: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 64 changed to down
*Nov 10 18:07:28.403: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Nov 10 18:07:29.475: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/2/0, TEI 64 changed to down
*Nov 10 18:07:29.479: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Nov 10 18:07:33.531: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8 callref = 0x8B
*Nov 10 18:07:33.531: ISDN BR0/3/0 Q931: RX <- ALERTING pd = 8 callref = 0x8B
*Nov 10 18:07:33.771: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x8B
*Nov 10 18:07:33.771: ISDN BR0/3/0 Q931: RX <- CONNECT pd = 8 callref = 0x8B
*Nov 10 18:07:33.775: %LINK-3-UPDOWN: Interface BRI0/3/0:1, changed state to up
*Nov 10 18:07:33.775: %DIALER-6-BIND: Interface BR0/3/0:1 bound to profile Di150
*Nov 10 18:07:33.775: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 00870600971578 N/A
*Nov 10 18:07:33.779: ISDN BR0/3/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0B
*Nov 10 18:07:37.063: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 00870600971578 bourbon-liberty204
*Nov 10 18:07:37.063: %ISDN-6-DISCONNECT: Interface BRI0/3/0:1 disconnected from 00870600971578 bourbon-liberty204, call lasted 3 seconds
*Nov 10 18:07:37.067: ISDN BR0/3/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x0B
*Nov 10 18:07:37.243: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x8B
*Nov 10 18:07:37.243: ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8 callref = 0x8B
*Nov 10 18:07:37.247: %LINK-3-UPDOWN: Interface BRI0/3/0:1, changed state to down
*Nov 10 18:07:37.247: %DIALER-6-UNBIND: Interface BR0/3/0:1 unbound from profile Di150
*Nov 10 18:07:37.251: ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0B
*Nov 10 18:07:41.203: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/3/0, TEI 65 changed to down
MA2811#
Another thing to add, there are only 3 or 4 vessels on which we are encountering this issue. Approximately a hundreed others are running quite well with exactly the same configs.
I give you the Vessel ISDN Config, a Cisco 876 router running (Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)) :
RTVESSELINMARSAT#sh run
Building configuration...
isdn switch-type basic-net3
username xxx privilege 15 secret 5 xxx
username xxx password 7 xxx
username xxx privilege 3 secret 5 xxx
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn point-to-point-setup
no keepalive
no cdp enable
interface Dialer0
description ### MARSEILLE 0033496110959 ###
ip address 172.16.22.150 255.255.255.0
ip nat inside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer remote-name ma2610b
dialer idle-timeout 15
dialer string "0033496110959#"
dialer-group 1
no keepalive
ppp chap hostname liberty-204
access-list 110 permit ip 172.16.150.228 0.0.0.1 172.16.18.126 0.0.0.1 log
access-list 110 permit tcp 172.16.22.150 0.0.1.0 eq telnet host 172.16.18.151 log
access-list 110 permit icmp 172.16.22.150 0.0.1.0 host 172.16.18.151 log
access-list 110 permit icmp 172.16.22.150 0.0.1.0 172.16.22.185 0.0.1.0 log
access-list 110 deny ip any any
dialer-list 1 protocol ip list 110
scheduler max-task-time 5000
ntp server 192.168.254.251
end
I give you the HQ ISDN Concentrator Config, a Cisco 2811 router with WIC-1B-S/T-V3 (3) running (Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(19), RELEASE SOFTWARE (fc1)) :
MA2811#sh run int dial150
Current configuration : 364 bytes
interface Dialer150
description ### LIBERTY-204 00870600971578 #V# ###
ip unnumbered Loopback1
ip access-group Acl_Dialer150-out out
encapsulation ppp
dialer pool 1
dialer remote-name liberty-204
dialer idle-timeout 10
dialer string 00870600971578
dialer-group 1
no keepalive
no cdp enable
ppp authentication chap pap
ppp chap hostname ma2610b
end
Many thanks for your help !!!
/plg
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-10-2010 11:38 AM
Hello Plg,
you may refer to the tables reported in the following link to decode the error message
http://www.cisco.com/en/US/docs/ios/11_3/debug/command/reference/disdn.html
"vessel side" is so fast in disconnecting that later other side is still attempting to proceed
Call State i = 0x13
Hope to help
Giuseppe
