ISR 1100 features activation problem
AnzeZ
Hi.
We have two new ISR1111 (running on Version 17.5.1a) with bought licenses:
Cisco 1100 Series with 8 LAN Ports, 200 Mbps IPSEC Throughput License
Cisco 1100 Series with 8 LAN Ports, Security License
We converted PAK licences to Smart Licences. Both routers are visible in Smart Software Licensing portal under Product Instances, but won't retrieve licences for them. What is the problem?
Command: show license summ gives response "No licenses in use".
#show license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Smart
URL: https://smartreceiver.cisco.com/licservice/license
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: <none>
Reporting push interval: 0 (no reporting)
Next ACK push check: <none>
Next report push: <none>
Last report push: <none>
Last report file write: <none>
Trust Code Installed: Aug 12 07:48:31 2021 UTC
License Usage
No licenses in use
Product Information
UDI: PID:C1111-8P,SN:XXXXX
Agent Version
Smart Agent for Licensing: 5.1.10_rel/38
License Authorizations
Overall status:
Active: PID:C1111-8P,SN:XXXXX
Status: NOT INSTALLED
Purchased Licenses:
No Purchase Information Available
Any help would be much appreciated.
Kind regards
Hope I posted this in correct category.
AnzeZ
Hi.
Just to let everyone know what was the issue. We had to configure following commands:
  • (config)# license boot level securityk9 >>>>> to activate the Security license
  • (config)# platform hardware throughput crypto 200000 >>>>> to activate the IPSEC
  • Then save the configuration and reload the router,
Kind regards
9 Replies 9
balaji.bandi
Purchased Licenses:
May be quick fix contact cisco License Team over Phone, they can fix for you.
BB
how exactly did you start the license conversion ? I assume you used the below command:
--> license smart conversion start
Your output shows that no conversion has taken place. Try and run the above command again.
License Conversion:
Status: Not started
AnzeZ
I contacted TAC Smart licensing support and they said it takes about 24-48h for router to take licences. Somehow, I don't belive this is the problem here.
@Georg Pauwen there is not such command on my ISR 1111:
#license smart ?
authorization Authorization
clear Clear
export Get or return an export authorization key
factory Execute Smart Licensing Factory commands
import Import authcode, policies, trustcode etc
save Save
sync Sync with CSLU/CSSM.
trust Establish trust between PI and CSLU/CSSM.
(config)#license smart ?
custom_id Set a customer defined id
enable Smart licensing is Permanently configured, This cli
will have no effect
privacy privacy related commands
proxy proxy related commands
reservation Enable or disable the license reservation feature
server-identity-check Enable or disable the HTTP secure server identity
check
transport Select the type of message transport for Smart Agent
url Set the Smart Transport Primary and the Utility URL
usage Entitlement usage.
utility Enable or disable usage reporting on the device
Any idea?
the 24 - 48 hours sounds odd indeed, that would mean you cannot run your business for up to two days...
Not sure why the command is not there, I was just looking at the Smart Licensing Guide...
I know.
We got router with software Version 17.5.1a. As I read guides, from version 17.3 and later, there were some changes in Smart licencing. The problem is, that there is no guide for our version that works. Looks like I will have to go on with TAC a bit further.
KR
you can start with RTU License it last for 30days or more (technically) till the License fixes take place.
BB
AnzeZ
Hi.
Kind regards
doesn't work for me.
Do you have any suggestions?
Aria
Running into this same issue, both securityk9 and hseck9 show as active in the Smart Licensing portal, but they never show up on the device. Running the "license boot" and "platform hardware" commands, saving config and reloading changes nothing, still "No Purchase Information Available"..... so what do you do here??
