Bookmark
Subscribe
6717
Issues with OSPF and ACL. Need Help
Sirah8499
I'm having some issues configuring ACL's in the following situation:
c.     Configure HQ and Branch with OSPF routing according to the following criteria:
·         Assign the process ID 1.
·         Advertise all three attached networks. Do not advertise the link to the Internet.
·         Configure appropriate interfaces as passive.
d.     Set a default route on HQ which directs traffic to S0/0/1 interface. Redistribute the route to Branch.
e.     Design a named access list HQServer to prevent any computers attached to the Gigabit Ethernet 0/0 interface of the Branch router from accessing HQServer.pka. All other traffic is permitted. Configure the access list on the appropriate router, apply it to the appropriate interface and in the appropriate direction.
f.      Design a named access list BranchServer to prevent any computers attached to the Gigabit Ethernet 0/0 interface of the HQ router from accessing the HTTP and HTTPS service of the Branch server. All other traffic is permitted. Configure the access list on the appropriate router, apply it to the appropriate interface and in the appropriate direction.
I dont know what I am missing or doing incorrectly. This is what I have done to configure this scenario:
Configuring HQ OSPF
HQ>enable
HQ#config t
Enter configuration commands, one per line. End with CNTL/Z.
HQ(config)#router ospf 1
HQ(config-router)#network 172.16.0.0 0.255.255.255 area 0
HQ(config-router)#interface s0/0/1
HQ(config-if)#router ospf 1
HQ(config-router)#passive-interface s0/0/1
HQ(config-router)#passive-interface g0/1
HQ(config-router)#passive-interface g0/0
HQ(config-router)#default-information originate
HQ(config-router)#exit
HQ(config)#ip route 0.0.0.0 0.0.0.0 s0/0/1
Configuring HQ ACL
HQ(config)#ip access-list extended BranchServer
HQ(config-ext-nacl)#deny tcp 172.16.64.0 0.0.0.255 172.16.128.1 0.0.15.255 eq 80
HQ(config-ext-nacl)#deny tcp 172.16.64.0 0.0.0.255 172.16.128.1 0.0.15.255 eq 443
HQ(config-ext-nacl)#permit ip any any
HQ(config-ext-nacl)#interface g0/0
HQ(config-if)#ip access-group BranchServer in
HQ(config-if)#exit
Configuring Branch OSPF
Branch>enable
Branch#config t
Branch(config)#router ospf 1
Branch(config-router)#network 172.16.0.0 0.0.255.255 area 0
Branch(config-router)#passive-interface g0/0
Branch(config-router)#passive-interface g0/1
Branch(config-router)#exit
Branch(config)#ip route 0.0.0.0 0.0.0.0 64.104.34.2
Branch(config)#no ip route 0.0.0.0 0.0.0.0 64.104.34.2
Configuring Branch ACL
Branch(config)#ip access-list extended HQServer
Branch(config-ext-nacl)#deny ip any 172.16.0.1 0.0.63.255
Branch(config-ext-nacl)#permit ip any any
Branch(config-ext-nacl)#interface g0/0
Branch(config-if)#ip access-group HQServer in
Branch(config-if)#exit
Branch(config)#exit
If anyone could please explain to me why I'm only get 43/100 after all these configurations? What am I missing? I've been working on this for hours looking over the chapter and various resources online and I'm just at a loss at this point. I have also attached the packet tracer file if anyone would like to take a look at it.
5 Replies 5
cadet alain
-first you omitted to enable OSPF on the link between Branch and HQ:
router os 1
netw 192.168.0.0 0.0.0.3 area 0
-The ACLs should be
HQ(config-ext-nacl)#do sh access-list
Extended IP access list BranchServer
    10 deny tcp 172.16.64.0 0.0.63.255 host 172.16.128.1 eq www
    20 deny tcp 172.16.64.0 0.0.63.255 host 172.16.128.1 eq 443
    30 permit ip any any
Branch(config-if)#do sh access-list
Extended IP access list HQServer
    10 deny ip 172.16.144.0 0.0.15.255 host 172.16.0.1
    20 permit ip any any
-B1 IP is not correct it should be 172.16.144.1 and not 172.168.143.1
I'm still stuck at 50% after this and I don't know why because the ACL do what they are meant to do and are applied as close to the source as possible.
Alain
Thank you for the reply. I fixed the IP on B1 and added the network between HQ and Branch and that bumped me up to 50%.
Sirah8499
Seriously does NOBODY know how to go about fixing this or configuring it the way it should be?
mfurnival
Level 4
Level 4
Maybe they want you to be more specific with your OSPF statements:
HQ(config-router)#network 172.16.0.0 0.0.63.255 area 0
HQ(config-router)#network 172.16.64.0 0.0.63.255 area 0
Branch(config-router)#network 172.16.128.0 0.0.31.255 area 0
M Ross
Configuring HQ ACL
HQ(config-ext-nacl)#deny tcp any host 172.16.128.1 eq 80
HQ(config-ext-nacl)#deny tcp any host 172.16.128.1 eq 443
HQ(config-if)#exit
1) While the 172.16.64.0 0.0.0.255  network is technically equivalent to any for the diagram the directions ask you to block all traffic on g0/0 including someone who decides to change their ip address 172.16.63.128.  If you want to block a whole LAN segment you need to use any.
2) You want to deny access to a single host 172.16.128.1 not 172.16.128.1 0.0.15.255 network
Branch(config-ext-nacl)#deny ip any host 172.16.0.1
Branch(config)#exit
1) You want to deny access to a single host 172.16.128.1 not 172.16.128.1 0.0.15.255 network
That should get you the last 50 points
