MPLS support on 2600 familiy
ciscomv79
Hi I have a cisco 2611xm with this configuration:
2 FastEthernet interfaces (both used)
1 Serial interface
2 Voice FXS interfaces
Is it possible to replace the wic for a card with 1 ethernet port, in such case wich card? The only NM is being ocuppied by the PVDM for voice. What are my options?
paolo bevilacqua
Hola,
There are no ethernet or fastethernet cards for the 2600 series in form of WIC card.
You could get a switch that support 802.1q VLAN, then you can do as many "virtual ports" you want by connecting in trunk to one FA port on the router, and using subinterfaces and VLAn on said port.
mohammedmahmoud
Level 11
Level 11
AFAIK, the only WIC Ethernet ports are not compatible with the 2600 series, only 2800/3800:
http://www.cisco.com/en/US/products/ps6019/index.html
I am just curious what is the relation between your question and the subject of the post.
HTH,
Mohammed Mahmoud.
