OSPF Database & routing table
actkillerby
Why would there be discrepancies between the ospf database and the entries in the routing table. If I do show ip ospf database there are a significant number of entries that are not shown but are in the network list under router ospf....
Why would this be? We are having occasional connectivity problems with 2 of the subnets that are not in the ospf database but are in the network router list.
Any help you can give is appreciated.
Alex
32 Replies 32
Hi Sudeep
I can understand why the networks would only show when you issue the command show ip ospf database now and not when you do show ip ospf database
but i still think I have a problem in that the networks do not show on the other routers in the ospf area
regards
Hi Alex,
Can you please provide one IP which u are facing issue with and provide the show ip route from both source router and  problem router.
Also from both routers (source and the router on which u are not receiving the route), get this command output
show ip ospf data router
Sudeep
Morning Sudeep
One of the ip addresses we have issues with is 10.115.21.200
We have users on one of our remote sites who need access to this PC to support the software on there and they have probelms connecting.  However other devices on the 10.115.21.0 subnet can be reached without issue.
The remote WAN connection comes in via router 2 (192.168.162.2) and the vlan for 10.115.21.0 is also on router 2.
from the remote site I cannot ping 10.115.21.200
ping 10.115.21.200
Sending 5, 100-byte ICMP Echos to 10.115.21.200, timeout is 2 seconds:
Success rate is 0 percent (0/5)
a traceroute shows the following
traceroute 10.115.21.200
Tracing the route to 10.115.21.200
  1 10.209.244.2 0 msec 0 msec 0 msec
  2 10.100.81.137 0 msec 0 msec 0 msec
  3 10.100.80.86 5 msec 5 msec 5 msec
  4 10.100.80.81 0 msec 5 msec 0 msec
  5 10.100.80.74 0 msec 0 msec 0 msec
  6 10.115.0.5 0 msec 0 msec 0 msec
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11  *  *  *
12  *  *  *
however on router 2 i get the following
ping 10.115.21.200
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
On the traceroute 10.115.0.5 is router 2 so the data is getting to the router but then not the destination.
Here is the sh ip route information from the router 2
#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 10.115.96.211 to network 0.0.0.0
S    192.168.106.0/24 [1/0] via 0.0.0.0
S    192.168.123.0/24 [1/0] via 0.0.0.0
S    192.168.72.0/24 [1/0] via 0.0.0.0
S    192.168.89.0/24 [1/0] via 0.0.0.0
S    192.168.46.0/24 [1/0] via 0.0.0.0
S    192.168.63.0/24 [1/0] via 0.0.0.0
S    192.168.29.0/24 [1/0] via 0.0.0.0
S    192.168.192.0/24 [1/0] via 0.0.0.0
S    192.168.166.0/24 [1/0] via 0.0.0.0
S    192.168.183.0/24 [1/0] via 0.0.0.0
S    192.168.132.0/24 [1/0] via 0.0.0.0
S    192.168.149.0/24 [1/0] via 0.0.0.0
S    192.168.122.0/24 [1/0] via 0.0.0.0
S    192.168.107.0/24 [1/0] via 0.0.0.0
S    192.168.88.0/24 [1/0] via 0.0.0.0
S    192.168.73.0/24 [1/0] via 0.0.0.0
S    192.168.62.0/24 [1/0] via 0.0.0.0
S    192.168.47.0/24 [1/0] via 0.0.0.0
     193.227.106.0/32 is subnetted, 1 subnets
S       193.227.106.28 [1/0] via 10.115.0.1
S    192.168.28.0/24 [1/0] via 0.0.0.0
     212.196.162.0/32 is subnetted, 1 subnets
S       212.196.162.228 [1/0] via 10.115.96.211
S    192.168.193.0/24 [1/0] via 0.0.0.0
S    192.168.182.0/24 [1/0] via 0.0.0.0
S    192.168.167.0/24 [1/0] via 0.0.0.0
S    192.168.148.0/24 [1/0] via 0.0.0.0
S    192.168.133.0/24 [1/0] via 0.0.0.0
S    192.168.74.0/24 [1/0] via 0.0.0.0
S    192.168.91.0/24 [1/0] via 0.0.0.0
S    192.168.104.0/24 [1/0] via 0.0.0.0
S    192.168.121.0/24 [1/0] via 0.0.0.0
S    192.168.31.0/24 [1/0] via 0.0.0.0
     155.231.0.0/32 is subnetted, 2 subnets
S       155.231.63.217 [1/0] via 10.115.96.211
S       155.231.63.153 [1/0] via 10.115.96.211
S    192.168.44.0/24 [1/0] via 0.0.0.0
     87.0.0.0/32 is subnetted, 1 subnets
S       87.251.33.228 [1/0] via 10.115.0.1
S    192.168.61.0/24 [1/0] via 0.0.0.0
S    192.168.194.0/24 [1/0] via 0.0.0.0
S    192.168.151.0/24 [1/0] via 0.0.0.0
S    192.168.164.0/24 [1/0] via 0.0.0.0
S    192.168.181.0/24 [1/0] via 0.0.0.0
S    192.168.90.0/24 [1/0] via 0.0.0.0
S    192.168.75.0/24 [1/0] via 0.0.0.0
S    192.168.120.0/24 [1/0] via 0.0.0.0
S    192.168.105.0/24 [1/0] via 0.0.0.0
S    192.168.30.0/24 [1/0] via 0.0.0.0
S    192.168.60.0/24 [1/0] via 0.0.0.0
S    192.168.45.0/24 [1/0] via 0.0.0.0
S    192.168.195.0/24 [1/0] via 0.0.0.0
S    192.168.150.0/24 [1/0] via 0.0.0.0
S    192.168.135.0/24 [1/0] via 0.0.0.0
S    192.168.180.0/24 [1/0] via 0.0.0.0
S    192.168.42.0/24 [1/0] via 0.0.0.0
     81.0.0.0/32 is subnetted, 1 subnets
S       81.147.195.179 [1/0] via 10.115.96.211
S    192.168.59.0/24 [1/0] via 0.0.0.0
O    192.168.25.0/24 [110/16] via 172.20.1.5, 1w4d, Vlan1001
S    192.168.110.0/24 [1/0] via 0.0.0.0
S    192.168.127.0/24 [1/0] via 0.0.0.0
O    192.168.76.0/24 [110/16] via 172.20.1.5, 1w4d, Vlan1001
S    192.168.93.0/24 [1/0] via 0.0.0.0
     192.168.162.0/24 is variably subnetted, 7 subnets, 3 masks
C       192.168.162.64/28 is directly connected, Vlan501
C       192.168.162.2/32 is directly connected, Loopback0
O       192.168.162.3/32 [110/2] via 172.20.1.3, 1w4d, Vlan1001
                         [110/2] via 192.168.144.1, 1w4d, Vlan100
                         [110/2] via 10.115.64.147, 1w4d, Vlan501
O       192.168.162.1/32 [110/2] via 172.20.1.6, 1w4d, Vlan1001
                         [110/2] via 10.115.18.2, 1w4d, Vlan446
                         [110/2] via 10.115.32.1, 1w4d, Vlan460
                         [110/2] via 10.115.64.145, 1w4d, Vlan501
C       192.168.162.24/30 is directly connected, Vlan4
C       192.168.162.16/30 is directly connected, Vlan2
O       192.168.162.20/30 [110/6] via 10.115.18.2, 1w4d, Vlan446
                          [110/6] via 10.115.32.1, 1w4d, Vlan460
                          [110/6] via 172.20.1.6, 1w4d, Vlan1001
                          [110/6] via 172.20.1.3, 1w4d, Vlan1001
S    192.168.179.0/24 [1/0] via 0.0.0.0
S    192.168.128.0/24 [1/0] via 0.0.0.0
S    192.168.145.0/24 [1/0] via 0.0.0.0
S    192.168.196.0/24 [1/0] via 0.0.0.0
S    192.168.58.0/24 [1/0] via 0.0.0.0
S    192.168.43.0/24 [1/0] via 0.0.0.0
S    192.168.24.0/24 [1/0] via 0.0.0.0
S    192.168.126.0/24 [1/0] via 0.0.0.0
S    192.168.111.0/24 [1/0] via 0.0.0.0
S    192.168.92.0/24 [1/0] via 0.0.0.0
S    192.168.77.0/24 [1/0] via 0.0.0.0
S    192.168.178.0/24 [1/0] via 0.0.0.0
S    192.168.163.0/24 [1/0] via 0.0.0.0
     192.168.144.0/25 is subnetted, 2 subnets
S       192.168.144.128 [1/0] via 0.0.0.0
C       192.168.144.0 is directly connected, Vlan100
S    192.168.129.0/24 [1/0] via 0.0.0.0
C    194.101.26.0/24 is directly connected, GigabitEthernet3/9
S    192.168.197.0/24 [1/0] via 0.0.0.0
S    192.168.10.0/24 [1/0] via 192.168.162.17
S    192.168.27.0/24 [1/0] via 0.0.0.0
S    192.168.40.0/24 [1/0] via 0.0.0.0
S    192.168.57.0/24 [1/0] via 0.0.0.0
S    192.168.78.0/24 [1/0] via 0.0.0.0
     159.170.0.0/32 is subnetted, 3 subnets
S       159.170.5.245 [1/0] via 10.115.96.211
S       159.170.6.211 [1/0] via 10.115.96.211
S       159.170.5.210 [1/0] via 10.115.96.211
S    192.168.95.0/24 [1/0] via 0.0.0.0
S    192.168.108.0/24 [1/0] via 0.0.0.0
S    192.168.125.0/24 [1/0] via 0.0.0.0
S    192.168.130.0/24 [1/0] via 0.0.0.0
S    192.168.147.0/24 [1/0] via 0.0.0.0
S    192.168.160.0/24 [1/0] via 0.0.0.0
C    192.168.177.0/24 is directly connected, Vlan177
     194.62.42.0/32 is subnetted, 1 subnets
S       194.62.42.123 [1/0] via 10.115.96.211
S    192.168.198.0/24 [1/0] via 0.0.0.0
     172.18.0.0/24 is subnetted, 1 subnets
S       172.18.236.0 [1/0] via 10.115.96.211
     172.20.0.0/16 is variably subnetted, 10 subnets, 5 masks
S       172.20.189.0/24 [1/0] via 10.115.96.211
S       172.20.190.0/24 [1/0] via 10.115.96.211
S       172.20.191.0/24 [1/0] via 10.115.96.211
S       172.20.250.30/32 [1/0] via 172.20.1.5
S       172.20.250.29/32 [1/0] via 172.20.1.5
S       172.20.192.0/24 [1/0] via 10.115.96.211
S       172.20.189.128/26 [1/0] via 10.115.96.211
S       172.20.190.128/26 [1/0] via 10.115.96.211
S       172.20.191.160/27 [1/0] via 10.115.96.211
C       172.20.0.0/16 is directly connected, Vlan1001
     172.23.0.0/24 is subnetted, 2 subnets
S       172.23.235.0 [1/0] via 10.115.96.211
S       172.23.234.0 [1/0] via 10.115.96.211
     172.31.0.0/16 is variably subnetted, 2 subnets, 2 masks
S       172.31.144.209/32 [1/0] via 10.115.64.5
S       172.31.64.0/24 [1/0] via 10.115.64.5
S    192.168.26.0/24 [1/0] via 0.0.0.0
S    192.168.56.0/24 [1/0] via 0.0.0.0
S    192.168.41.0/24 [1/0] via 0.0.0.0
S    192.168.94.0/24 [1/0] via 0.0.0.0
S    192.168.79.0/24 [1/0] via 0.0.0.0
S    192.168.124.0/24 [1/0] via 0.0.0.0
S    192.168.109.0/24 [1/0] via 0.0.0.0
S    192.168.146.0/24 [1/0] via 0.0.0.0
S    192.168.131.0/24 [1/0] via 0.0.0.0
O    192.168.176.0/24 [110/16] via 172.20.1.6, 1w4d, Vlan1001
                      [110/16] via 10.115.18.2, 1w4d, Vlan446
                      [110/16] via 10.115.32.1, 1w4d, Vlan460
                      [110/16] via 10.115.64.145, 1w4d, Vlan501
     192.168.161.0/25 is subnetted, 2 subnets
S       192.168.161.128 [1/0] via 0.0.0.0
C       192.168.161.0 is directly connected, Vlan500
S    192.168.199.0/24 [1/0] via 0.0.0.0
     192.168.200.0/24 is variably subnetted, 2 subnets, 2 masks
S       192.168.200.0/24 [1/0] via 0.0.0.0
S       192.168.200.4/32 [1/0] via 0.0.0.0
S    192.168.174.0/24 [1/0] via 0.0.0.0
S    192.168.191.0/24 [1/0] via 0.0.0.0
S    192.168.140.0/24 [1/0] via 0.0.0.0
S    192.168.157.0/24 [1/0] via 0.0.0.0
S    192.168.98.0/24 [1/0] via 0.0.0.0
S    192.168.115.0/24 [1/0] via 0.0.0.0
S    192.168.81.0/24 [1/0] via 0.0.0.0
S    192.168.38.0/24 [1/0] via 0.0.0.0
S    192.168.55.0/24 [1/0] via 0.0.0.0
S    192.168.21.0/24 [1/0] via 0.0.0.0
     194.72.7.0/32 is subnetted, 2 subnets
S       194.72.7.142 [1/0] via 10.115.0.1
S       194.72.7.137 [1/0] via 10.115.0.1
S    192.168.190.0/24 [1/0] via 0.0.0.0
S    192.168.175.0/24 [1/0] via 0.0.0.0
     129.73.0.0/29 is subnetted, 1 subnets
S       129.73.116.88 [1/0] via 10.115.64.5
S    192.168.156.0/24 [1/0] via 0.0.0.0
S    192.168.141.0/24 [1/0] via 0.0.0.0
S    192.168.114.0/24 [1/0] via 0.0.0.0
S    192.168.99.0/24 [1/0] via 0.0.0.0
S    192.168.80.0/24 [1/0] via 0.0.0.0
S    192.168.65.0/24 [1/0] via 0.0.0.0
S    192.168.54.0/24 [1/0] via 0.0.0.0
S    192.168.39.0/24 [1/0] via 0.0.0.0
S    192.168.20.0/24 [1/0] via 0.0.0.0
     192.168.5.0/25 is subnetted, 1 subnets
S       192.168.5.0 [1/0] via 10.115.76.20
S    192.168.142.0/24 [1/0] via 0.0.0.0
     192.168.159.0/26 is subnetted, 2 subnets
O       192.168.159.192 [110/2] via 172.20.1.3, 1w4d, Vlan1001
O       192.168.159.0 [110/26] via 172.20.1.3, 1w4d, Vlan1001
                      [110/26] via 192.168.144.1, 1w4d, Vlan100
                      [110/26] via 10.115.64.147, 1w4d, Vlan501
S    192.168.172.0/24 [1/0] via 0.0.0.0
S    192.168.189.0/24 [1/0] via 0.0.0.0
S    192.168.66.0/24 [1/0] via 0.0.0.0
S    192.168.83.0/24 [1/0] via 0.0.0.0
     10.0.0.0/8 is variably subnetted, 168 subnets, 11 masks
O       10.115.120.0/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.125.0/24 [110/16] via 172.20.1.5, 1w4d, Vlan1001
S       10.209.246.41/32 [1/0] via 10.115.0.1
O       10.115.113.0/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.112.0/24 [110/21] via 172.20.1.5, 1w4d, Vlan1001
O       10.115.115.0/26 [110/16] via 172.20.1.5, 1w4d, Vlan1001
O       10.115.114.0/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.117.0/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.116.0/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.119.0/25 [110/11] via 172.20.1.5, 1w4d, Vlan1001
O       10.115.118.0/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
C       10.115.104.0/21 is directly connected, Vlan303
O       10.115.97.0/24 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.96.0/24 [110/36] via 10.115.18.2, 1w4d, Vlan446
                       [110/36] via 10.115.32.1, 1w4d, Vlan460
                       [110/36] via 172.20.1.6, 1w4d, Vlan1001
                       [110/36] via 10.115.64.145, 1w4d, Vlan501
O       10.115.98.0/23 [110/16] via 172.20.1.4, 1w4d, Vlan1001
S       10.209.246.54/32 [1/0] via 10.115.0.1
S       10.217.241.0/24 [1/0] via 10.115.96.211
S       10.213.244.14/32 [1/0] via 10.115.0.1
S       10.209.247.0/24 [1/0] via 10.115.0.1
S       10.209.246.0/24 [1/0] via 10.115.63.2
S       10.94.196.190/32 [1/0] via 10.115.0.1
S       10.209.245.0/24 [1/0] via 10.115.0.1
S       10.213.240.0/21 [1/0] via 10.115.63.2
S       10.209.244.0/24 [1/0] via 10.115.0.1
S       10.115.73.0/24 [1/0] via 10.115.96.14
S       10.115.72.0/24 [1/0] via 10.115.96.13
S       10.150.224.77/32 [1/0] via 10.115.0.1
S       10.115.75.0/24 [1/0] via 10.115.96.14
S       10.115.74.0/24 [1/0] via 10.115.96.13
C       10.115.76.0/22 is directly connected, Vlan1001
C       10.115.1.64/26 is directly connected, Vlan402
O       10.115.64.0/25 [110/2] via 172.20.1.6, 1w4d, Vlan1001
O       10.115.2.64/26 [110/16] via 172.20.1.3, 1w4d, Vlan1001
                       [110/16] via 192.168.144.1, 1w4d, Vlan100
                       [110/16] via 10.115.64.147, 1w4d, Vlan501
S       10.151.240.81/32 [1/0] via 10.115.0.1
S       10.100.80.0/24 [1/0] via 10.115.0.1
S       10.100.81.0/24 [1/0] via 10.115.0.1
C       10.115.60.0/23 is directly connected, Vlan177
O       10.115.63.0/24 [110/2] via 172.20.1.6, 1w4d, Vlan1001
S       10.157.129.81/32 [1/0] via 10.115.96.211
O       10.115.113.64/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
S       10.94.193.222/32 [1/0] via 10.115.0.1
C       10.115.50.0/24 is directly connected, Vlan205
S       10.84.18.0/24 [1/0] via 10.115.0.1
O       10.115.52.0/24 [110/16] via 172.20.1.6, 1w4d, Vlan1001
C       10.115.41.0/24 is directly connected, Vlan469
C       10.115.40.0/24 is directly connected, Vlan468
O       10.115.43.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.42.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.45.0/24 [110/2] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.44.0/24 [110/2] via 10.115.18.2, 1w4d, Vlan446
C       10.115.46.0/24 is directly connected, Vlan474
C       10.115.33.0/24 is directly connected, Vlan461
C       10.115.32.0/24 is directly connected, Vlan460
S       10.94.195.205/32 [1/0] via 10.115.0.1
O       10.115.34.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.37.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.203.195/32 [1/0] via 10.115.0.1
O       10.115.36.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.195.201/32 [1/0] via 10.115.0.1
C       10.115.39.0/24 is directly connected, Vlan467
O       10.115.38.0/24 [110/26] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.25.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.115.134.158/32 [1/0] via 10.115.0.1
O       10.115.24.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.115.134.157/32 [1/0] via 10.115.0.1
O       10.115.27.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.26.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.115.29.0/24 is directly connected, Vlan457
O       10.115.28.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.31.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.115.30.0/24 is directly connected, Vlan458
S       10.213.244.67/32 [1/0] via 10.115.0.1
S       10.151.240.5/32 [1/0] via 10.115.0.1
C       10.115.17.0/24 is directly connected, Vlan445
C       10.115.19.0/24 is directly connected, Vlan447
C       10.115.18.0/24 is directly connected, Vlan446
C       10.115.21.0/24 is directly connected, Vlan449
S       10.151.240.0/20 [1/0] via 10.115.96.211
O       10.115.20.0/24 [110/16] via 172.20.1.6, 1w4d, Vlan1001
O       10.115.23.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.115.22.0/24 is directly connected, Vlan450
O       10.115.9.0/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.89.163.128/26 is directly connected, Vlan827
O       10.115.8.0/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.11.0/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.115.10.0/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.89.160.128/26 is directly connected, Vlan815
O       10.115.12.0/25 [110/2] via 172.20.1.3, 1w4d, Vlan1001
C       10.89.164.128/25 is directly connected, Vlan831
O       10.115.1.0/26 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.115.0.0/24 is directly connected, Vlan400
S       10.150.224.6/32 [1/0] via 10.115.0.1
O       10.115.3.0/26 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.150.224.7/32 [1/0] via 10.115.0.1
O       10.115.2.0/26 [110/16] via 172.20.1.3, 1w4d, Vlan1001
C       10.115.5.0/26 is directly connected, Vlan205
S       10.151.224.0/20 [1/0] via 10.115.96.211
S       10.191.202.0/24 [1/0] via 10.115.96.211
O       10.115.6.0/26 [110/2] via 10.115.18.2, 1w4d, Vlan446
S       10.94.198.22/32 [1/0] via 10.115.63.2
S       10.94.196.22/32 [1/0] via 10.115.0.1
S       10.94.210.0/24 [1/0] via 10.115.63.2
O       10.115.113.128/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.115.128/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.114.128/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.117.128/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.116.128/25 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.119.128/25 [110/26] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.118.128/25 [110/16] via 172.20.1.5, 1w4d, Vlan1001
S       10.94.207.20/32 [1/0] via 10.115.0.1
S       10.94.196.0/23 [1/0] via 10.115.63.2
S       10.94.198.0/24 [1/0] via 10.115.0.1
S       10.94.199.1/32 [1/0] via 10.115.0.1
S       10.94.199.0/24 [1/0] via 10.115.63.2
S       10.94.198.6/32 [1/0] via 10.115.63.2
S       10.94.195.0/24 [1/0] via 10.115.0.1
S       10.94.199.11/32 [1/0] via 10.115.0.1
S       10.94.206.0/24 [1/0] via 10.115.96.211
S       10.94.207.0/24 [1/0] via 10.115.63.2
S       10.94.202.0/24 [1/0] via 10.115.96.211
S       10.150.224.222/32 [1/0] via 10.115.0.1
S       10.150.224.223/32 [1/0] via 10.115.0.1
S       10.151.224.222/32 [1/0] via 10.115.0.1
S       10.150.224.218/32 [1/0] via 10.115.0.1
S       10.94.193.51/32 [1/0] via 10.115.0.1
C       10.115.64.144/28 is directly connected, Vlan501
S       10.94.228.0/25 [1/0] via 10.115.63.2
C       10.115.64.136/30 is directly connected, Vlan4
C       10.89.162.64/26 is directly connected, Vlan822
S       10.151.240.222/32 [1/0] via 10.115.0.1
C       10.89.160.64/26 is directly connected, Vlan814
S       10.151.240.217/32 [1/0] via 10.115.0.1
S       10.150.224.202/32 [1/0] via 10.115.0.1
S       10.151.240.219/32 [1/0] via 10.115.0.1
S       10.151.240.218/32 [1/0] via 10.115.0.1
O       10.115.1.192/26 [110/2] via 192.168.144.1, 1w4d, Vlan100
C       10.115.64.128/30 is directly connected, Vlan2
S       10.150.224.199/32 [1/0] via 10.115.0.1
S       10.151.240.214/32 [1/0] via 10.115.0.1
O       10.115.64.132/30 [110/6] via 10.115.18.2, 1w4d, Vlan446
O       10.115.113.192/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
O       10.115.114.192/26 [110/16] via 172.20.1.4, 1w4d, Vlan1001
S       10.138.16.92/32 [1/0] via 10.115.0.1
S       10.94.210.85/32 [1/0] via 10.115.0.1
S       10.213.244.248/32 [1/0] via 10.115.0.1
S       10.213.244.253/32 [1/0] via 10.115.0.1
O       10.89.179.0/24 [110/2] via 172.20.1.3, 1w4d, Vlan1001
O       10.89.176.0/24 [110/2] via 172.20.1.3, 1w4d, Vlan1001
O       10.89.184.0/24 [110/16] via 172.20.1.3, 1w4d, Vlan1001
O       10.89.190.0/27 [110/21] via 172.20.1.5, 1w4d, Vlan1001
S       10.94.199.125/32 [1/0] via 10.115.0.1
O       10.115.9.128/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.195.103/32 [1/0] via 10.115.0.1
O       10.115.8.128/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.195.102/32 [1/0] via 10.115.0.1
O       10.115.11.128/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.213.115/32 [1/0] via 10.115.0.1
O       10.115.10.128/25 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.213.114/32 [1/0] via 10.115.0.1
C       10.89.160.0/26 is directly connected, Vlan1001
O       10.115.12.128/25 [110/2] via 172.20.1.3, 1w4d, Vlan1001
C       10.89.164.0/25 is directly connected, Vlan830
C       10.89.171.0/25 is directly connected, Vlan844
O       10.115.2.128/26 [110/16] via 172.20.1.3, 1w4d, Vlan1001
S       10.94.210.125/32 [1/0] via 10.115.0.1
S       10.151.240.150/32 [1/0] via 10.115.0.1
C       10.89.174.0/24 is directly connected, Vlan850
C       10.115.7.128/25 is directly connected, Vlan426
S    192.168.96.0/24 [1/0] via 0.0.0.0
S    192.168.113.0/24 [1/0] via 0.0.0.0
S    192.168.23.0/24 [1/0] via 0.0.0.0
S    192.168.36.0/24 [1/0] via 0.0.0.0
S    192.168.53.0/24 [1/0] via 0.0.0.0
S    192.168.158.0/24 [1/0] via 0.0.0.0
O    192.168.143.0/24 [110/2] via 172.20.1.3, 1w4d, Vlan1001
S    192.168.188.0/24 [1/0] via 0.0.0.0
S    192.168.173.0/24 [1/0] via 0.0.0.0
S    192.168.82.0/24 [1/0] via 0.0.0.0
S    192.168.67.0/24 [1/0] via 0.0.0.0
     193.129.96.0/32 is subnetted, 2 subnets
S       193.129.96.235 [1/0] via 10.115.96.211
S       193.129.96.236 [1/0] via 10.115.96.211
S    192.168.112.0/24 [1/0] via 0.0.0.0
S    192.168.97.0/24 [1/0] via 0.0.0.0
S    192.168.22.0/24 [1/0] via 0.0.0.0
     109.0.0.0/32 is subnetted, 2 subnets
S       109.94.129.21 [1/0] via 10.115.96.211
S       109.94.137.21 [1/0] via 10.115.96.211
     194.138.39.0/29 is subnetted, 1 subnets
S       194.138.39.16 [1/0] via 10.115.64.5
     192.168.7.0/25 is subnetted, 1 subnets
S       192.168.7.0 [1/0] via 10.115.76.20
S    192.168.52.0/24 [1/0] via 0.0.0.0
S    192.168.37.0/24 [1/0] via 0.0.0.0
     195.104.234.0/32 is subnetted, 1 subnets
S       195.104.234.5 [1/0] via 10.115.96.211
S    192.168.170.0/24 [1/0] via 0.0.0.0
S    192.168.136.0/24 [1/0] via 0.0.0.0
S    192.168.153.0/24 [1/0] via 0.0.0.0
S    192.168.34.0/24 [1/0] via 0.0.0.0
S    192.168.51.0/24 [1/0] via 0.0.0.0
S    192.168.102.0/24 [1/0] via 0.0.0.0
S    192.168.119.0/24 [1/0] via 0.0.0.0
S    192.168.68.0/24 [1/0] via 0.0.0.0
S    192.168.85.0/24 [1/0] via 0.0.0.0
S    192.168.171.0/24 [1/0] via 0.0.0.0
S    192.168.152.0/24 [1/0] via 0.0.0.0
S    192.168.137.0/24 [1/0] via 0.0.0.0
C    192.168.205.0/24 is directly connected, Vlan205
S    192.168.50.0/24 [1/0] via 0.0.0.0
S    192.168.35.0/24 [1/0] via 0.0.0.0
S    192.168.118.0/24 [1/0] via 0.0.0.0
S    192.168.103.0/24 [1/0] via 0.0.0.0
     62.0.0.0/32 is subnetted, 2 subnets
S       62.249.215.49 [1/0] via 10.115.64.5
S       62.130.47.45 [1/0] via 10.115.96.211
S    192.168.84.0/24 [1/0] via 0.0.0.0
S    192.168.69.0/24 [1/0] via 0.0.0.0
S    192.168.138.0/24 [1/0] via 0.0.0.0
S    192.168.155.0/24 [1/0] via 0.0.0.0
O    192.168.168.0/24 [110/26] via 172.20.1.3, 1w4d, Vlan1001
     134.54.0.0/24 is subnetted, 1 subnets
S       134.54.120.0 [1/0] via 10.115.96.211
S    192.168.49.0/24 [1/0] via 0.0.0.0
S    192.168.70.0/24 [1/0] via 0.0.0.0
S    192.168.87.0/24 [1/0] via 0.0.0.0
S    192.168.100.0/24 [1/0] via 0.0.0.0
S    192.168.117.0/24 [1/0] via 0.0.0.0
S    192.168.154.0/24 [1/0] via 0.0.0.0
S    192.168.139.0/24 [1/0] via 0.0.0.0
S    192.168.169.0/24 [1/0] via 0.0.0.0
S    150.2.0.0/16 [1/0] via 10.115.64.5
S    192.168.48.0/24 [1/0] via 0.0.0.0
S    192.168.33.0/24 [1/0] via 0.0.0.0
S    192.168.86.0/24 [1/0] via 0.0.0.0
S    192.168.71.0/24 [1/0] via 0.0.0.0
S    192.168.116.0/24 [1/0] via 0.0.0.0
S    192.168.101.0/24 [1/0] via 0.0.0.0
S*   0.0.0.0/0 [1/0] via 10.115.96.211
O    192.168.240.0/22 [110/16] via 172.20.1.6, 1w4d, Vlan1001
S    192.168.184.0/22 [1/0] via 192.168.180.20
This is why it is so confusing
Hi Alex,
Since its a /24 subnet and u are able to reacxh other IPs in this subnet, the routing seems to be fine. Moreover you are reaching till router2.  Can you please try doing a reverse trace from 10.115.21.200 towards the source IP.  Check on Host 10.115.21.200, that the default gateway is set as Router-2.
Please let me know the result.
Sudeep
Hi Sudeep
The gateway is correct and set by DHCP, also the reverse trace gets to router 2 then out onto the WAN but fails on reaching the end device.
I thisk we are getting lost here, I am trying to find out why some of the networks in the ospf area are not showing on all the routers in the ospf area.  I can now understand why the wouldnt appear when show ip sopf database is run on the host router, but then I think they should show on the other routers in the ospf area.
Am I correct in thinking this or not?
If they should appear then why are they not appearing?  I want to exclude this as being a reason why we have this connectivity issue.
Alex
Hi Alex,
The lnk state DB should be the same across all routers within an area.  The problem which u are facing, seems to be something else.  And even on other routers, you have to see it using the same command, not just the host router.
Sudeep
Morning Rick
Here is the output you require
Vlan449 is up, line protocol is up
  Internet Address 10.115.21.1/24, Area 0
  Process ID 2, Router ID 192.168.162.2, Network Type BROADCAST, Cost: 15
  Transmit Delay is 1 sec, State DR, Priority 1
  Designated Router (ID) 192.168.162.2, Interface address 10.115.21.1
  No backup designated router on this network
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    Hello due in 00:00:08
  Index 8/8, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 0
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 0, Adjacent neighbor count is 0
  Suppress hello for 0 neighbor(s)
Vlan468 is up, line protocol is up
  Internet Address 10.115.40.1/24, Area 0
  Designated Router (ID) 192.168.162.2, Interface address 10.115.40.1
    Hello due in 00:00:05
  Index 27/27, flood queue length 0
  Next 0x0(0)/0x0(0)
interface Vlan449
description Education_Centre
ip address 10.115.21.1 255.255.255.0
ip helper-address 10.115.96.55
ip helper-address 10.115.98.71
ip ospf cost 15
end
interface Vlan468
description CAb RR AA
ip address 10.115.40.1 255.255.255.0
ip ospf cost 15
end
Thanks for your help
actkillerby
Hi Sudeep
Thanks for all your help, I didnt think the ospf problem was necessarily the cause of my problems.  However I need to know whay the ospf is not correct.
Any help anyone can give is appreciated.
Alex
In looking at the routing table that you posted and at the results in traceroute I am not sure that I am seeing a routing problem. I wonder if there is any access list filtering on the router or any security policy on the host that is not responding to traceroute.
Rick
Rick
Hi Rick
I am not convinced it is a routing issue either but we have no access lists in place and there isnt a security policy on the end device that would stop connectivity.  Some devices on one subnet can connect and others cant so it is a really random fault.
However during the fault finding we can accross the missing entries on the ospf table and I want teo exclude that as being the issue.  I think I can now say it isnt the cause but would like to know whay we have missing entries in the ospf database.
Alex
sh run | sec ospf
sh ip protocols
might be useful.
Hope it will help.
Best regards,
Abzal
Hi Alex,
OSPA cannot be a cause of reachability issue here  bcoz, other IPs of the subnet are getting reached.  We are advertising  as /24 and if it was a routing issue, entire subnet would have got  affected.
Do you still feel we have missing entries in OSPF database.  Can you give more details of the missing entry , like "show ip route <>, show ip ospf database etc
Sudeep
Hi Sudeep
Router 1
router ospf 1
log-adjacency-changes
network 10.89.160.0 0.0.0.63 area 0
network 10.89.184.0 0.0.0.255 area 0
network 10.115.0.0 0.0.0.255 area 0
network 10.115.1.192 0.0.0.63 area 0
network 10.115.6.0 0.0.0.63 area 0
network 10.115.18.0 0.0.0.255 area 0
network 10.115.20.0 0.0.0.255 area 0
network 10.115.32.0 0.0.0.255 area 0
network 10.115.44.0 0.0.0.255 area 0
network 10.115.52.0 0.0.0.255 area 0
network 10.115.60.0 0.0.1.255 area 0
network 10.115.63.0 0.0.0.255 area 0
network 10.115.64.0 0.0.0.127 area 0
network 10.115.64.128 0.0.0.3 area 0
network 10.115.64.132 0.0.0.3 area 0
network 10.115.64.144 0.0.0.15 area 0
network 10.115.72.0 0.0.3.255 area 0
network 10.115.76.0 0.0.3.255 area 0
network 10.115.96.0 0.0.0.255 area 0
network 10.115.98.0 0.0.1.255 area 0
network 10.115.104.0 0.0.7.255 area 0
network 172.20.1.0 0.0.0.255 area 0
network 172.20.2.0 0.0.0.255 area 0
network 172.20.22.0 0.0.0.255 area 0
network 172.20.50.0 0.0.0.255 area 0
network 172.20.70.0 0.0.0.255 area 0
network 172.20.71.0 0.0.0.255 area 0
network 172.20.250.0 0.0.0.255 area 0
network 192.168.161.0 0.0.0.127 area 0
network 192.168.162.1 0.0.0.0 area 0
network 192.168.162.16 0.0.0.3 area 0
network 192.168.162.20 0.0.0.3 area 0
network 192.168.162.64 0.0.0.15 area 0
network 192.168.176.0 0.0.0.255 area 0
network 192.168.177.0 0.0.0.255 area 0
network 192.168.184.0 0.0.3.255 area 0
network 192.168.240.0 0.0.3.255 area 0
Show ip ospd database output
       OSPF Router with ID (192.168.162.1) (Process ID 1)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
192.168.162.1   192.168.162.1   1784        0x800260FA 0x4CAB   30
192.168.162.2   192.168.162.2   1838        0x80026220 0xEFE8   43
192.168.162.3   192.168.162.3   201         0x8001EF91 0x3293   58
192.168.162.7   192.168.162.7   1228        0x80004CBB 0x43B4   25
192.168.162.8   192.168.162.8   782         0x8001232B 0xFF8D   25
                Net Link States (Area 0)
10.89.164.3     192.168.162.3   223         0x80004249 0xC532
10.89.164.131   192.168.162.3   223         0x8000424A 0xBEB7
10.89.184.3     192.168.162.3   223         0x80000CBF 0x8D97
10.115.0.5      192.168.162.2   1867        0x80000225 0x7FE8
10.115.1.193    192.168.162.1   1819        0x8000022D 0xA140
10.115.6.2      192.168.162.3   223         0x80000CBF 0x906D
10.115.18.1     192.168.162.2   1867        0x80000CBF 0x8D28
10.115.32.2     192.168.162.2   1867        0x80000CBF 0xE8BD
10.115.46.3     192.168.162.3   224         0x8000424E 0x9639
10.115.50.2     192.168.162.3   224         0x80000CBF 0x345D
10.115.64.129   192.168.162.1   1820        0x80000225 0xD7D7
10.115.64.133   192.168.162.1   1820        0x80000250 0x6718
10.115.64.138   192.168.162.3   735         0x80000226 0x831E
10.115.64.145   192.168.162.1   1821        0x80000253 0x73F6
10.115.97.2     192.168.162.7   1245        0x800025F2 0xDF28
10.115.98.3     192.168.162.7   1245        0x800025F7 0x945C
10.115.104.4    192.168.162.3   225         0x80000CC0 0x67E6
10.115.112.8    192.168.162.7   1245        0x80001F5D 0x3B53
10.115.113.2    192.168.162.7   1245        0x800041A6 0xF76F
10.115.113.66   192.168.162.7   1245        0x800041A5 0x77B0
10.115.113.131  192.168.162.8   791         0x80001F5F 0xD37A
10.115.113.194  192.168.162.7   1246        0x800041A5 0x7235
10.115.114.2    192.168.162.7   1246        0x800025F1 0xAA8C
10.115.114.130  192.168.162.7   1246        0x800041A5 0xE9FC
10.115.115.131  192.168.162.8   792         0x80001F5F 0x3C50
10.115.116.2    192.168.162.7   1246        0x800041A5 0x574E
10.115.116.130  192.168.162.7   1246        0x800041A5 0x52D2
10.115.117.2    192.168.162.7   1246        0x800041A5 0x4C58
10.115.117.130  192.168.162.7   1246        0x800041A5 0x47DC
10.115.118.2    192.168.162.7   1246        0x800025F2 0xFA77
10.115.118.130  192.168.162.7   1246        0x800041A4 0x3EE5
10.115.119.2    192.168.162.7   1246        0x800025F2 0xEF81
10.115.120.2    192.168.162.7   1246        0x800041A5 0x2B76
10.115.125.2    192.168.162.8   793         0x80000CC6 0x44EB
172.20.1.4      192.168.162.7   1247        0x800025F9 0x7D68
192.168.76.3    192.168.162.7   1247        0x800041A5 0x3E23
192.168.144.2   192.168.162.2   1870        0x8000022D 0xB0B3
192.168.161.3   192.168.162.1   1823        0x80000225 0xE874
192.168.176.14  192.168.162.3   227         0x80000CBF 0x78A3
192.168.177.3   192.168.162.2   1871        0x80000CBF 0xD750
sh ip route output
S    192.168.12.0/24 [1/0] via 192.168.170.20
R    194.101.28.0/24 [120/1] via 10.1.254.254, 00:00:24, GigabitEthernet3/16
O    192.168.25.0/24 [110/16] via 172.20.1.5, 1w5d, Vlan1001
O    192.168.76.0/24 [110/16] via 172.20.1.5, 1w5d, Vlan1001
O       192.168.162.2/32 [110/2] via 172.20.1.2, 1w5d, Vlan1001
                         [110/2] via 10.115.18.1, 1w5d, Vlan446
                         [110/2] via 10.115.32.2, 1w5d, Vlan460
                         [110/2] via 10.115.64.146, 1w5d, Vlan501
O       192.168.162.3/32 [110/2] via 172.20.1.3, 1w5d, Vlan1001
                         [110/2] via 10.115.6.2, 1w5d, Vlan421
                         [110/2] via 10.115.64.147, 1w5d, Vlan501
C       192.168.162.1/32 is directly connected, Loopback0
O       192.168.162.24/30 [110/6] via 172.20.1.3, 1w5d, Vlan1001
                          [110/6] via 10.115.64.147, 1w5d, Vlan501
                          [110/6] via 10.115.6.2, 1w5d, Vlan421
                          [110/6] via 10.115.18.1, 1w5d, Vlan446
C       192.168.162.20/30 is directly connected, Vlan3
O       192.168.144.0 [110/2] via 10.115.64.147, 1w5d, Vlan501
O    194.101.26.0/24 [110/2] via 172.20.1.2, 1w5d, Vlan1001
R    194.61.247.0/24 [120/1] via 10.1.254.253, 00:00:25, GigabitEthernet3/16
     194.62.42.0/32 is subnetted, 3 subnets
R       194.62.42.66 [120/1] via 10.1.254.253, 00:00:25, GigabitEthernet3/16
R       194.62.42.67 [120/1] via 10.1.254.253, 00:00:25, GigabitEthernet3/16
R    194.101.25.0/24 [120/1] via 10.1.254.253, 00:00:25, GigabitEthernet3/16
C    192.168.176.0/24 is directly connected, Vlan176
R    128.1.0.0/16 [120/1] via 10.1.254.254, 00:00:26, GigabitEthernet3/16
R    192.9.200.0/24 [120/1] via 10.1.254.254, 00:00:26, GigabitEthernet3/16
O       192.168.159.192 [110/2] via 172.20.1.3, 1w5d, Vlan1001
O       192.168.159.0 [110/26] via 172.20.1.3, 1w5d, Vlan1001
                      [110/26] via 10.115.6.2, 1w5d, Vlan421
                      [110/26] via 10.115.64.147, 1w5d, Vlan501
     10.0.0.0/8 is variably subnetted, 168 subnets, 12 masks
O       10.115.120.0/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.125.0/24 [110/16] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.113.0/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.112.0/24 [110/21] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.115.0/26 [110/16] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.114.0/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
C       10.1.0.0/16 is directly connected, GigabitEthernet3/16
O       10.115.117.0/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.116.0/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.119.0/25 [110/11] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.118.0/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.97.0/24 [110/16] via 172.20.1.4, 1w5d, Vlan1001
S       10.18.0.0/16 [1/0] via 10.1.254.254
C       10.115.96.0/24 is directly connected, Vlan600
C       10.115.98.0/23 is directly connected, Vlan602
O       10.115.1.64/26 [110/16] via 172.20.1.2, 1w5d, Vlan1001
                       [110/16] via 10.115.18.1, 1w5d, Vlan446
                       [110/16] via 10.115.32.2, 1w5d, Vlan460
                       [110/16] via 10.115.64.146, 1w5d, Vlan501
C       10.115.64.0/25 is directly connected, Vlan254
O       10.115.2.64/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
                       [110/16] via 10.115.6.2, 1w5d, Vlan421
                       [110/16] via 10.115.64.147, 1w5d, Vlan501
C       10.115.63.0/24 is directly connected, Vlan491
O       10.115.113.64/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.50.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
C       10.115.52.0/24 is directly connected, Vlan176
O       10.115.41.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.40.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.43.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.42.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.45.0/24 [110/2] via 172.20.1.3, 1w5d, Vlan1001
C       10.115.44.0/24 is directly connected, Vlan472
O       10.115.46.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.33.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.34.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.37.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.36.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.39.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.38.0/24 [110/26] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.25.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.24.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.27.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.26.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.29.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.28.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.31.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.30.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.17.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.19.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.21.0/24 [110/16] via 172.20.1.2, 1w5d, Vlan1001
C       10.115.20.0/24 is directly connected, Vlan448
O       10.115.23.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.22.0/24 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.9.0/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.163.128/26 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.8.0/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.11.0/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.10.0/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.160.128/26 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.12.0/25 [110/2] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.164.128/25 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.1.0/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.3.0/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.2.0/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.5.0/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
C       10.115.6.0/26 is directly connected, Vlan421
O       10.115.113.128/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.115.128/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.114.128/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.117.128/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.116.128/25 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.119.128/25 [110/26] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.118.128/25 [110/16] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.64.136/30 [110/6] via 10.115.64.147, 1w5d, Vlan501
O       10.89.162.64/26 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.89.160.64/26 [110/2] via 172.20.1.2, 1w5d, Vlan1001
C       10.115.1.192/26 is directly connected, Vlan404
C       10.115.64.132/30 is directly connected, Vlan3
O       10.115.113.192/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.114.192/26 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.89.179.0/24 [110/2] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.176.0/24 [110/2] via 172.20.1.3, 1w5d, Vlan1001
C       10.89.184.0/24 is directly connected, Vlan860
O       10.89.190.0/27 [110/21] via 172.20.1.5, 1w5d, Vlan1001
O       10.115.9.128/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.8.128/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.11.128/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.10.128/25 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.115.12.128/25 [110/2] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.164.0/25 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O       10.89.171.0/25 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.2.128/26 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O       10.89.174.0/24 [110/2] via 172.20.1.2, 1w5d, Vlan1001
O       10.115.7.128/25 [110/16] via 172.20.1.2, 1w5d, Vlan1001
O    192.168.143.0/24 [110/2] via 172.20.1.3, 1w5d, Vlan1001
     192.168.7.0/24 is variably subnetted, 2 subnets, 2 masks
R       192.168.7.0/24 [120/1] via 10.1.254.254, 00:00:28, GigabitEthernet3/16
S       192.168.7.0/25 [1/0] via 10.115.76.20
O    192.168.205.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O    192.168.168.0/24 [110/26] via 172.20.1.3, 1w5d, Vlan1001
C    192.168.240.0/22 is directly connected, GigabitEthernet3/9
Router 2
router ospf 2
network 10.2.0.0 0.0.255.255 area 0
network 10.89.160.64 0.0.0.63 area 0
network 10.89.160.128 0.0.0.63 area 0
network 10.89.162.64 0.0.0.63 area 0
network 10.89.163.128 0.0.0.63 area 0
network 10.89.164.0 0.0.0.127 area 0
network 10.89.164.128 0.0.0.127 area 0
network 10.89.171.0 0.0.0.127 area 0
network 10.89.174.0 0.0.0.255 area 0
network 10.115.1.64 0.0.0.63 area 0
network 10.115.5.0 0.0.0.63 area 0
network 10.115.7.128 0.0.0.127 area 0
network 10.115.17.0 0.0.0.127 area 0
network 10.115.19.0 0.0.0.255 area 0
network 10.115.21.0 0.0.0.255 area 0
network 10.115.22.0 0.0.0.255 area 0
network 10.115.29.0 0.0.0.255 area 0
network 10.115.30.0 0.0.0.255 area 0
network 10.115.33.0 0.0.0.255 area 0
network 10.115.39.0 0.0.0.255 area 0
network 10.115.40.0 0.0.0.255 area 0
network 10.115.41.0 0.0.0.255 area 0
network 10.115.45.0 0.0.0.255 area 0
network 10.115.46.0 0.0.0.255 area 0
network 10.115.50.0 0.0.0.255 area 0
network 10.115.64.136 0.0.0.3 area 0
network 192.168.144.0 0.0.0.127 area 0
network 192.168.162.2 0.0.0.0 area 0
network 192.168.162.24 0.0.0.3 area 0
network 192.168.205.0 0.0.0.255 area 0
network 194.101.26.0 0.0.0.255 area 0
sh ip ospf database output
       OSPF Router with ID (192.168.162.2) (Process ID 2)
192.168.162.1   192.168.162.1   1984        0x800260FA 0x4CAB   30
192.168.162.2   192.168.162.2   12          0x80026221 0xEDE9   43
192.168.162.3   192.168.162.3   387         0x8001EF91 0x3293   58
192.168.162.7   192.168.162.7   1407        0x80004CBB 0x43B4   25
192.168.162.8   192.168.162.8   953         0x8001232B 0xFF8D   25
10.89.164.3     192.168.162.3   387         0x80004249 0xC532
10.89.164.131   192.168.162.3   387         0x8000424A 0xBEB7
10.89.184.3     192.168.162.3   387         0x80000CBF 0x8D97
10.115.0.5      192.168.162.2   12          0x80000226 0x7DE9
10.115.1.193    192.168.162.1   1984        0x8000022D 0xA140
10.115.6.2      192.168.162.3   387         0x80000CBF 0x906D
10.115.18.1     192.168.162.2   12          0x80000CC0 0x8B29
10.115.32.2     192.168.162.2   12          0x80000CC0 0xE6BE
10.115.46.3     192.168.162.3   387         0x8000424E 0x9639
10.115.50.2     192.168.162.3   387         0x80000CBF 0x345D
10.115.64.129   192.168.162.1   1984        0x80000225 0xD7D7
10.115.64.133   192.168.162.1   1984        0x80000250 0x6718
10.115.64.138   192.168.162.3   898         0x80000226 0x831E
10.115.64.145   192.168.162.1   1984        0x80000253 0x73F6
10.115.97.2     192.168.162.7   1407        0x800025F2 0xDF28
10.115.98.3     192.168.162.7   1407        0x800025F7 0x945C
10.115.104.4    192.168.162.3   387         0x80000CC0 0x67E6
10.115.112.8    192.168.162.7   1407        0x80001F5D 0x3B53
10.115.113.2    192.168.162.7   1407        0x800041A6 0xF76F
10.115.113.66   192.168.162.7   1407        0x800041A5 0x77B0
10.115.113.131  192.168.162.8   953         0x80001F5F 0xD37A
10.115.113.194  192.168.162.7   1407        0x800041A5 0x7235
10.115.114.2    192.168.162.7   1407        0x800025F1 0xAA8C
10.115.114.130  192.168.162.7   1407        0x800041A5 0xE9FC
10.115.115.131  192.168.162.8   953         0x80001F5F 0x3C50
10.115.116.2    192.168.162.7   1407        0x800041A5 0x574E
10.115.116.130  192.168.162.7   1407        0x800041A5 0x52D2
10.115.117.2    192.168.162.7   1407        0x800041A5 0x4C58
10.115.117.130  192.168.162.7   1407        0x800041A5 0x47DC
10.115.118.2    192.168.162.7   1407        0x800025F2 0xFA77
10.115.118.130  192.168.162.7   1407        0x800041A4 0x3EE5
10.115.119.2    192.168.162.7   1407        0x800025F2 0xEF81
10.115.120.2    192.168.162.7   1407        0x800041A5 0x2B76
10.115.125.2    192.168.162.8   953         0x80000CC6 0x44EB
172.20.1.4      192.168.162.7   1407        0x800025F9 0x7D68
192.168.76.3    192.168.162.7   1407        0x800041A5 0x3E23
192.168.144.2   192.168.162.2   12          0x8000022E 0xAEB4
192.168.161.3   192.168.162.1   1984        0x80000225 0xE874
192.168.176.14  192.168.162.3   387         0x80000CBF 0x78A3
192.168.177.3   192.168.162.2   12          0x80000CC0 0xD551
sh ip route output
                         [110/2] via 192.168.144.1, 1w5d, Vlan100
O       192.168.162.1/32 [110/2] via 172.20.1.6, 1w5d, Vlan1001
                         [110/2] via 10.115.18.2, 1w5d, Vlan446
                         [110/2] via 10.115.32.1, 1w5d, Vlan460
                         [110/2] via 10.115.64.145, 1w5d, Vlan501
O       192.168.162.20/30 [110/6] via 10.115.18.2, 1w5d, Vlan446
                          [110/6] via 10.115.32.1, 1w5d, Vlan460
                          [110/6] via 172.20.1.6, 1w5d, Vlan1001
O    192.168.176.0/24 [110/16] via 172.20.1.6, 1w5d, Vlan1001
                      [110/16] via 10.115.18.2, 1w5d, Vlan446
                      [110/16] via 10.115.32.1, 1w5d, Vlan460
                      [110/16] via 10.115.64.145, 1w5d, Vlan501
                      [110/26] via 192.168.144.1, 1w5d, Vlan100
O       10.115.96.0/24 [110/36] via 10.115.18.2, 1w5d, Vlan446
                       [110/36] via 10.115.32.1, 1w5d, Vlan460
                       [110/36] via 172.20.1.6, 1w5d, Vlan1001
                       [110/36] via 10.115.64.145, 1w5d, Vlan501
O       10.115.98.0/23 [110/16] via 172.20.1.4, 1w5d, Vlan1001
O       10.115.64.0/25 [110/2] via 172.20.1.6, 1w5d, Vlan1001
                       [110/16] via 192.168.144.1, 1w5d, Vlan100
O       10.115.63.0/24 [110/2] via 172.20.1.6, 1w5d, Vlan1001
O       10.115.52.0/24 [110/16] via 172.20.1.6, 1w5d, Vlan1001
O       10.115.44.0/24 [110/2] via 10.115.18.2, 1w5d, Vlan446
O       10.115.20.0/24 [110/16] via 172.20.1.6, 1w5d, Vlan1001
O       10.115.6.0/26 [110/2] via 10.115.18.2, 1w5d, Vlan446
O       10.115.1.192/26 [110/2] via 192.168.144.1, 1w5d, Vlan100
O       10.115.64.132/30 [110/6] via 10.115.18.2, 1w5d, Vlan446
O       10.89.184.0/24 [110/16] via 172.20.1.3, 1w5d, Vlan1001
O    192.168.240.0/22 [110/16] via 172.20.1.6, 1w5d, Vlan1001
On router 2 I cannot see the fowwowing networks when i do the sh ip ospf database command
10.115.44.0
10.115.52.0
10.115.63.0
10.115.72.0
these are not all of them but show that some networks do not appear in the ospf
Looking at the output of sh ip route on router 2 it says that it has learned 10.115.63.0/24 via ospf but this does not show when I do sh ip ospf datbase.
Hi Alex,
Lets take prefx 10.115.44.0/24 for now.  Its there in routing table via ospf, means it should be there in OSPF database.
Can you please get the output of "show ip route 10.115.44.0".  I need to know who is  the advertising router (which router is originating it).  Once you know which router is originating this route, get below command output
show ip ospf databse router
Sudeep
Hi Sudeep
As requested
#sh ip route 10.115.44.0
Routing entry for 10.115.44.0/24
  Known via "ospf 2", distance 110, metric 2, type intra area
  Last update from 10.115.18.2 on Vlan446, 1w5d ago
  Routing Descriptor Blocks:
  * 10.115.18.2, from 192.168.162.1, 1w5d ago, via Vlan446
      Route metric is 2, traffic share count is 1
    10.115.32.1, from 192.168.162.1, 1w5d ago, via Vlan460
    172.20.1.6, from 192.168.162.1, 1w5d ago, via Vlan1001
    10.115.64.145, from 192.168.162.1, 1w5d ago, via Vlan501
sh ip ospf database router 192.168.162.1
Routing Bit Set on this LSA
LS age: 379
Options: (No TOS-capability, DC)
LS Type: Router Links
Link State ID: 192.168.162.1
Advertising Router: 192.168.162.1
LS Seq Number: 80026103
Checksum: 0x39B5
Length: 384
AS Boundary Router
Number of Links: 30
  Link connected to: a Transit Network
   (Link ID) Designated Router address: 10.115.64.133
   (Link Data) Router Interface address: 10.115.64.133
    Number of TOS metrics: 0
     TOS 0 Metrics: 5
  Link connected to: a Stub Network
   (Link ID) Network/subnet number: 192.168.162.20
   (Link Data) Network Mask: 255.255.255.252
     TOS 0 Metrics: 5
   (Link ID) Designated Router address: 10.115.64.129
   (Link Data) Router Interface address: 10.115.64.129
     TOS 0 Metrics: 5
   (Link ID) Network/subnet number: 192.168.162.16
     TOS 0 Metrics: 5
   (Link ID) Network/subnet number: 10.115.44.0
   (Link Data) Network Mask: 255.255.255.0
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 10.115.64.145
   (Link Data) Router Interface address: 10.115.64.145
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 192.168.162.64
   (Link Data) Network Mask: 255.255.255.240
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 192.168.240.0
   (Link Data) Network Mask: 255.255.252.0
     TOS 0 Metrics: 15
     TOS 0 Metrics: 15
   (Link ID) Designated Router address: 192.168.177.3
   (Link Data) Router Interface address: 192.168.177.2
     TOS 0 Metrics: 15
   (Link ID) Network/subnet number: 10.115.60.0
   (Link Data) Network Mask: 255.255.254.0
     TOS 0 Metrics: 15
   (Link ID) Designated Router address: 192.168.176.14
   (Link Data) Router Interface address: 192.168.176.13
     TOS 0 Metrics: 15
   (Link ID) Network/subnet number: 10.115.52.0
     TOS 0 Metrics: 15
   (Link Data) Network Mask: 255.255.255.255
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 192.168.161.3
   (Link Data) Router Interface address: 192.168.161.3
     TOS 0 Metrics: 15
   (Link ID) Designated Router address: 172.20.1.4
   (Link Data) Router Interface address: 172.20.1.6
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 10.115.76.0
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 10.89.160.0
   (Link Data) Network Mask: 255.255.255.192
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 10.115.104.4
   (Link Data) Router Interface address: 10.115.104.2
     TOS 0 Metrics: 20
   (Link ID) Designated Router address: 10.115.98.3
   (Link Data) Router Interface address: 10.115.98.2
     TOS 0 Metrics: 25
   (Link ID) Network/subnet number: 10.115.96.0
     TOS 0 Metrics: 35
   (Link ID) Network/subnet number: 10.115.64.0
   (Link Data) Network Mask: 255.255.255.128
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 10.115.63.0
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 10.115.32.2
   (Link Data) Router Interface address: 10.115.32.1
     TOS 0 Metrics: 1
   (Link ID) Network/subnet number: 10.115.20.0
     TOS 0 Metrics: 15
   (Link ID) Designated Router address: 10.115.18.1
   (Link Data) Router Interface address: 10.115.18.2
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 10.115.6.2
   (Link Data) Router Interface address: 10.115.6.1
     TOS 0 Metrics: 1
   (Link ID) Designated Router address: 10.115.1.193
   (Link Data) Router Interface address: 10.115.1.193
     TOS 0 Metrics: 15
   (Link ID) Designated Router address: 10.115.0.5
   (Link Data) Router Interface address: 10.115.0.6
     TOS 0 Metrics: 25
   (Link ID) Designated Router address: 10.89.184.3
   (Link Data) Router Interface address: 10.89.184.2
     TOS 0 Metrics: 25
Alex
