04-04-2012 08:34 AM - edited 03-04-2019 03:54 PM
A client recently ordered another T1 between their locations. I don't believe they requested it to be bonded. I configured both ends to use ppp multilink but one of the T1s stays in a UP/DOWN state. I use the same config that I always use (its pretty simple..) but I can't get that other T1 to come online. We tried swapping the T1s and the UP/DOWN follows the specific line. ATT says the T1 is fine.
Does a T1 need to be specifically ordered as bonded through ATT? Any other ideas as to why one is up/down?
Solved! Go to Solution.
04-04-2012 08:37 AM
It's down due because faulty circuit.
It's normal that telco says otherwise. They always do, before being shown otherwise.
04-04-2012 08:37 AM
04-04-2012 09:03 AM
Thanks. Are you saying that nothing has to be specifically ordered to make them bonded? Is that all in my config?
04-04-2012 09:04 AM
You'll need to order MLP for them to configure it on their side before it will work on yours... Otherwise, it'll be considered as 2 separate circuits.
04-04-2012 09:45 AM
If the T1s are between your own locations, you don't have to order anything special, and will be two separate circuits.
If they are to ATT servicea, as j.blakley is assuming above, you will have to order them budled.
In both cases, interface up/down indicates faulty circuit, bonded or not.
04-04-2012 11:00 AM
It looks like everyone is correct. I called ATT again and forced them to run the tests and they were unable to loop the smartjack. They are dispatching.
I will post back with results.
04-04-2012 11:05 AM
Very good, please remember to rate useful posts clicking on the stars below.
