Bookmark
Subscribe
2779
PPPEO configuration on cisco 1921 Router
Yasir Imran
Dear All
I have been upgrade the software of this router but i am not able to get PPPOE command under vpdn group 1, Kindly advise
Router(config-vpdn)#request-dialin
Router(config-vpdn-req-in)#protocol ?
  l2tp  Use L2TP
Directory of usbflash0:/
    1  -rw-        3066  Jan 19 2016 15:13:32 +00:00  cpconfig-19xx.cfg
    2  -rw-    79603248  Apr 20 2016 08:23:00 +00:00  c1900-universalk9-mz.SPA.155-3.M2.bin
    3  drw-           0  Jan 19 2016 15:14:00 +00:00  ccpexp
  458  -rw-        2885  Jan 19 2016 15:17:30 +00:00  home.shtml
256585728 bytes total (169570304 bytes free)
Router#
Router#show  ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.5(3)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sun 07-Feb-16 02:36 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 10 minutes
System returned to ROM by reload at 08:43:06 UTC Wed Apr 20 2016
System image file is "usbflash0:c1900-universalk9-mz.SPA.155-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FGL20042153
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
Router#
Router#show  version
Router uptime is 15 minutes
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO1921/K9          FGL20042153
Suite License Information for Module:'c1900'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
datak9
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
data          None                 None           None
Router#
Router#
Meylaers Jan
do you want your 1921 as a pppoe server or a pppoe client?
This is the client configuration(briefly)
wan interface should look like
int gig0/0(for example)
pppoe enable group global
pppoe-client dial-pool-number 1
int dialer 1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username 'yourusername' password 0 'yourpassword'
no cdp enable
install a route towards pppoe interface
ip route 0.0.0.0 0.0.0.0 dialer 1
your host should send out a
PADI (discovery)
and receive a PADO (OFFER) from the server
and send out again a PADR (REQUEST)
and receive a PADS (SESSION)
You can debug with
debug pppoe events
debug ppp packets
terminal monitor
Kind Regards
Jan Meylaers
Thanks for your replay,
I did the same configuration which you share with me, But when i am connecting wan interface with ISP ONT device then i am not able to see my interface is coming up of wan interface.
Let me share with you my current config of my router
Router#show  running-config
Building configuration...
Current configuration : 6375 bytes
! Last configuration change at 17:28:21 UTC Wed Apr 20 2016 by admin
version 15.5
hostname Router
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.155-3.M2.bi
boot system usbflash0 c1900-universalk9-mz.SPA.155-3.M2.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$/O2e$SC.eJ/U/Y1UrLDxQiomrp/
aaa new-model
aaa authentication login default local enable
aaa authentication login SSH-LOCAL enable local
aaa session-id common
ethernet lmi ce
ip domain name AHBT.ae
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
cts logging verbose
crypto pki trustpoint TP-self-signed-2547223692
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2547223692
 revocation-check none
 rsakeypair TP-self-signed-2547223692
crypto pki certificate chain TP-self-signed-2547223692
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353437 32323336 3932301E 170D3136 30313139 31353231
  34355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35343732
  32333639 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A83C 0AC99726 9DB2EA00 E12A88B6 26FCDD31 8A05D84C ED039C3D 07EED127
  9214C6F5 BA5270EE FE599E59 7536267C ED96D74C ABC4AEAF BE069763 A8F27E5D
  1B7D4F50 3223216A 542E9149 8495EAC1 CB44624A 13B46AAF 455569D6 81825679
  39E846D3 B53B0192 E8B72675 6DE947EF D6E87912 A35C7C05 F5C2518E BFE60214
  B6430203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1448415A D6C6C8E0 CB02E309 3A7AD056 F7A65C41 0F301D06
  03551D0E 04160414 48415AD6 C6C8E0CB 02E3093A 7AD056F7 A65C410F 300D0609
  2A864886 F70D0101 05050003 81810081 9E070113 288B6C87 862C7308 305AD97D
  15F0DED2 056348A4 19B5AB9A 8C9DFEE8 C7D6574D 162C223F FCBA74D6 24CB875A
  60FBB340 4022DDBB AF78F927 1C2B88FC 927BBB43 D3974DE3 F63D4D3D 40EEFD27
  82DFC842 364DA9E3 D3CCC846 9F5FB7FE C118805B F81A2F2D 6BC44145 4A09BAEB
  EB8C2782 74B05CF3 9AF5D14A 60BA1F
        quit
license udi pid CISCO1921/K9 sn FGL20042153
username admin privilege 15 secret 5 $1$a0nC$9NaVwi/xQe/QhmvOshZSH.
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description LAN-Interface
 ip address 172.16.5.27 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface Dialer1
 mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap chap
 ppp pap sent-username ahbtl240 password 0 2ctyeep1
 no cdp enable
ip default-gateway 172.16.5.254
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 172.16.170.0 255.255.254.0 172.16.5.254
dialer-list 1 protocol ip permit
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login authentication SSH-LOCAL
 transport input ssh
line vty 5 15
 privilege level 15
 transport input ssh
scheduler allocate 20000 1000
end
Router#
hi,
can you share debug pppoe events and sh ip int brief please ?
thx
