Saving router configuration
lam32123
I enter what's shown below, yet upon router rebooting (power off/on) I'm taken to Router> prompt instead of
R1 prompt ! What am I missing in saving a boot configuration to the router ? If I can't save my work,
what's the point ? (host name is one word without space, but not allowed here)
Router>enable Router#configure terminal Enter configuration commands, one per line. End with Control/Z. Router(config)#host name R1 R1(config)#exit R1# *Mar 1 00:07:14: %SYS-5-CONFIG_I: Configured from console by console R1#copy running-config startup-config Destination filename [startup-config]? Building configuration... [OK] R1#
2 Accepted Solutions
This symptom is usually caused when the config register is set to 0x2142 rather than to the default of 0x2102. The best way to check this is in the output of show version.
Rick
You are correct ----- show version revealed the config register was set to 0x2142.  I used the following to change it:
router>enable
router#configure terminal
router(config)#config-register 0x2102
After reboot, it worked !  Thank you very much !  Programming this router makes me feel like I've gone back in time to the late 80's with
MS-DOS v3.3 and programming in Basic A  or assembly language.
6 Replies 6
Leo Laohoo
Config registy.
post the output of:
sh ver
dir flash:
balaji.bandi
post show version and show loggs if any obnormal give indication.
BB
Rick
router>enable
I am glad that my suggestion was helpful. Appreciate that you confirm that this was the problem and that you included the steps you took to fix the problem. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
